Using same sensors in arduino
hello everyone, i have three cjmcu-101 sensors. how can i connect these sensors arduino together? is this code is right?
/* Irradiation meter using Solar Cell by Solarduino */
// Note :  Safety is very important when dealing with electricity. We take no responsibilities while you do it at your own risk.
// Note :  Irradiation meter is designed to measure and record the irradiation level for PV system performance check and feasibility study.
// Note :  Irradiation can measure and record (in SD card) instantaneous short circuit current (Isc) of panel, instantaneous Irradiation (W/m2) and daily Irradiation Energy in (W/m2/day)
// Note :  The daily Irradiation Energy is reset everyday or reset upon power outage (power supply to Arduino).
// Note :  The accuracy of the Irradiation is subject to the quality of user's solar cell and current module sensor.
// Note :  The Short Circuit Current of panel is recommended to be slightly lower or near the maximum range of current sensor for better accuracy results.
// Note :  The Irradiation is 100% subject to measured current and temperature coeffecient is neglected as it has almost negligible effect
// Note :  The temperature coefficient is neglected so that do not need additional temperature probe, furthermore 65 degree celcius under hot sun (40 degree temperature diference from STC) only performing 2.5% difference.
// Note :  The unit provides reasonable accuracy and may not be comparable with other expensive branded and commercial irradiation meter.
// Note :  All credit shall be given to Solarduino.
        /* 0- General */
        int decimalPrecision = 2;                   /* decimal places for only for current value shown in LED Display */
        /* 1- DC Current & Irradiation */
        int CurrentAnalogInputPin = A1;             // Which pin to measure Current Value
        float mVperAmpValue = 185;                  // If using ACS712 current module : for 5A module key in 185, for 20A module key in 100, for 30A module key in 66
                                                    // If using WCS current module : for 0.25A module key in 7000, for 0.5A module key in 3500, for 1.0A module key in 2000, for 2.0A module key in 1000.
        float moduleMiddleVoltage = 2500;           // key in middle voltage value in mV. For 5V power supply key in 2500, for 3.3V power supply, key in 1650 mV
        float moduleSupplyVoltage = 5000;           // supply voltage to current sensor module in mV, default 5000mV, may use 3300mV
        float currentSampleRead  = 0;               /* to read the value of a sample*/
        float currentLastSample  = 0;               /* to count time for each sample. Technically 1 milli second 1 sample is taken */
        float currentSampleSum   = 0;               /* accumulation of sample readings */
        float currentSampleCount = 0;               /* to count number of sample. */
        float currentMean ;                         /* to calculate the average value from all samples*/
        float finalCurrent ;                        /* the final current reading without taking offset value*/
        float finalCurrent2 ;                       /* the final current reading*/
        float ShortCircuitCurrentSTC = 2.9   ;      // Key in the Short Circuit Current (At STC condition) of your Solar Panel or Solar Cell. Value 9 showing 9.0A Isc Panel.
        float Irradiation = 0.00;                   /* This shows the irradiation level in W/m2.
            /* 1.1 - Offset DC Current */
            int   OffsetRead = 0;                   /* To switch between functions for auto callibation purpose */
            float currentOffset =0.00;              // to Offset deviation and accuracy. Offset any fake current when no current operates.
                                                    // the offset will automatically done when you press the <SELECT> button on the LCD display module.
                                                    // you may manually set offset here if you do not have LCD shield
            float offsetLastSample = 0;             /* to count time for each sample. Technically 1 milli second 1 sample is taken */
            float offsetSampleCount = 0;            /* to count number of sample. */
            /* 1.2 - Average Accumulate Irradiation */
            float accumulateIrradiation = 0;                          /* Amount of accumulate irradiation*/
            unsigned long startMillisIrradiation;                     /* start counting time for irradiation energy */
            unsigned long currentMillisIrradiation;                   /* current counting time for irradiation energy */
            const unsigned long periodIrradiation = 1000;             // refresh every X seconds (in seconds) Default 1000 = 1 second
            float FinalAccumulateIrradiationValue = 0;                /* shows the final accumulate irradiation reading*/
        /* 2 - LCD Display  */
        //#include<LiquidCrystal.h>                                   /*Load the liquid Crystal Library (by default already built-it with arduino solftware)*/
        //LiquidCrystal LCD(8,9,4,5,6,7);                             /*Creating the LiquidCrystal object named LCD */
        LiquidCrystal_I2C LCD(0x27, 16, 2);
        unsigned long startMillisLCD;                               /* start counting time for LCD Display */
        unsigned long currentMillisLCD;                             /* current counting time for LCD Display */
        const unsigned long periodLCD = 1000;                       // refresh every X seconds (in seconds) in LED Display. Default 1000 = 1 second
        /* 0- General */
        Serial.begin(9600);                               /* In order to see value in serial monitor */
        startMillisIrradiation = millis();                /* Record initial starting time for daily irradiation */
        //LCD.begin(16,2);                                  /* Tell Arduino that our LCD has 16 columns and 2 rows*/
        LCD.init();
        LCD.setCursor(0,0);                               /* Set LCD to upper left corner to start display*/
        startMillisLCD = millis();                        /* Record initial starting time for LCD Display refresh rate. */
  /* 0.1- Button Function */
              int buttonRead;
              buttonRead = analogRead (0);                                    // Read analog pin A0. By default the LCD Display shield already assigned A0 as button function. Cannot change.
              /*Right button is pressed */
              if (buttonRead < 60)
              {   LCD.setCursor(0,0); LCD.print ("PRESS <SELECT>   ");      }
              /* Up button is pressed */
              else if (buttonRead < 200)
              /* Down button is pressed */
              else if (buttonRead < 400)
              /* Left button is pressed */
              else if (buttonRead < 600)
              /* Select button is pressed */
              else if (buttonRead < 800)
              OffsetRead = 1;                                                 // to activate offset when button <SELECT> is pressed
              LCD.setCursor(0,0);
              LCD.print ("INITIALIZING..... ");
              LCD.setCursor(0,1);
              LCD.print ("WAIT 5 SEC ..... ");
        if(millis() >= currentLastSample + 1 )        /* every 1 milli second taking 1 reading */
            currentSampleRead = analogRead(CurrentAnalogInputPin)-((moduleMiddleVoltage/moduleSupplyVoltage)*1024);      /* read the sample value */
            currentSampleSum = currentSampleSum + currentSampleRead ;                                         /* accumulate value with older sample readings*/
            currentSampleCount = currentSampleCount + 1;                                                      /* to move on to the next following count */
            currentLastSample = millis();        /* to reset the time again so that next cycle can start again*/
        if(currentSampleCount == 1000)        /* after 1000 count or 1000 milli seconds (1 second), do the calculation and display value*/
            currentMean = currentSampleSum/currentSampleCount;                                                /* calculate average value of all sample readings taken*/
            finalCurrent = (((currentMean /1024)*moduleSupplyVoltage)/mVperAmpValue);                         /* calculate the final current (without offset)*/
            finalCurrent2 = finalCurrent+currentOffset;                                                       /* The final current */
            Irradiation = (finalCurrent2/ShortCircuitCurrentSTC*1000);
            Serial.print(finalCurrent2,decimalPrecision);
            Serial.print(" A  ");
            Serial.print(Irradiation,decimalPrecision);
            Serial.print(" W/m2  ");
            currentSampleSum =0;        /* to reset accumulate sample values for the next cycle */
            currentSampleCount=0;        /* to reset number of sample for the next cycle */
            if(OffsetRead == 1)
                currentOffset = 0;                                                             /* set back currentOffset as default first*/
                if(millis() >= offsetLastSample + 1)                                           /* offset 1 - to centralise analogRead waveform*/
                    offsetSampleCount = offsetSampleCount + 1;
                    offsetLastSample = millis();
                   if(offsetSampleCount == 2500)                                             /* need to wait awhile as to get new value before offset take into calculation.  */
                {        /* So this code is to delay 2.5 seconds after button pressed */
                  currentOffset = - finalCurrent;                                             /* to offset values */
                  OffsetRead = 0;                                                             /* until next offset button is pressed*/
                  offsetSampleCount = 0;                                                      /* to reset the time again so that next cycle can start again */
                  LCD.setCursor(0,0);
                  LCD.print ("OFFSET.....     ");
                  LCD.setCursor(0,1);
                  LCD.print ("DONE  .....     ");
         currentMillisIrradiation = millis();        /* Count the time for current */
        if (currentMillisIrradiation - startMillisIrradiation >= periodIrradiation)
            accumulateIrradiation = Irradiation/3600*(periodIrradiation/1000);                                /* for smoothing calculation*/
            FinalAccumulateIrradiationValue =  FinalAccumulateIrradiationValue + accumulateIrradiation ;
            Serial.print(FinalAccumulateIrradiationValue,decimalPrecision);
            Serial.println(" Wh/m2/day");
            startMillisIrradiation = currentMillisIrradiation ;                                               /* Set the starting point again for next counting time */
        currentMillisLCD = millis();
        if (currentMillisLCD - startMillisLCD >= periodLCD)
            LCD.setCursor(0,0);        /* Set cursor to first colum 0 and second row 1  */
            LCD.print(finalCurrent2,decimalPrecision);                                                    /* display voltage value in LCD in first row  */
            LCD.print(" A   ");
            LCD.setCursor(8,0);
            LCD.print(Irradiation,0);        /* display current value in LCD in first row */
            LCD.print(" W/m2   ");
            LCD.setCursor(0,1);
            LCD.print(FinalAccumulateIrradiationValue,0);                                                 /* display current value in LCD in first row */
            LCD.print(" Wh/m2/day        ");
            startMillisLCD = currentMillisLCD ;                                                           /* Set the starting point again for next counting time */
Are you using this same sensor?
If yes, you'll have to connect 3 output pins of the 3 sensors to 3 different analog pins of the Arduino.
Look up the data sheet of your sensor. See what its output is. Look at the data sheet for the arduino. See which pin can accept that output. If none look at why and see if there is a circuit that can convert output to appropriate input
yes it is same , i will try
Apparently that sensor connects to an analog input pin. 3 sensors should connect to 3 analog pins.
How would we know if the code is right when we don't know what you want it to do?
This is a link to the data sheet used on the module you have. You may also want to explain exactly in detail what your project is and a link to the schematic that goes with the code sample you posted.
Can you connect 3 of these modules to a single Arduino? Yes, using three analog input channels and creating new code Can you configure it per Post #2? I doubt it because you will run out of digital outputs. The code you posted is actually for an ACS 712 current sensor module and the reference to 185 mV/Amp leads me to believe the 0.0 to 5.0 version.
Then the code goes into Irradiation which would fit with the light sensor. Where id this code come from?
Can you have three sensors? Again yes just ID each one all through the code.
Ron
