Changing the default pins for usage of microSD card
I have a microSD adapter that has pins for CS, CLK, MOSI and MISO.
The CS pin can be changed to be whatever digital pin number I want it to be, but it seems that the SCK, MOSI, and MISO have pre-set pin numbers that they are assigned (MOSI - pin 11, MISO - pin 12, CLK - pin 13).
I was wondering if it were possible for me to change the pin numbers for the SCK, MOSI, and MISO from the default numbers to different pin numbers that I choose.
What is your arduino board?
It's an Arduino nano.
The short answer is NO
The Arduino Nano controller has a fixed SPI pins that you can't change.
Okay, thanks for the help.
I know that this is solved. But the big question is why you might want to change those pins?
