'class SoftwareSerial' has no member named 'readByte'
First of all I am sorry for my English. but I hope you guys are understand.
My project is reading Byte by serial communication from PC to Arduino. for example I send some serial packet data and Arduino must receive then send back that data to the PC.
Diagram: PC (use VB.net) -> USB to RS485 -> MAX485 Module (RS485 to TTL) -> Arduino Nano
#include <SoftwareSerial.h>   // Using software serial library
#define SSerialRX        10   // Serial Receive pin  (RO)
#define SSerialTX        11   // Serial Transmit pin (DI)
#define SSerialTxControl 3    // RS485 Direction control
                              //(DE & RE) pin to digital pin 3
#define RS485Transmit    HIGH // to open direction of MAX485 module
#define RS485Receive     LOW  // to close direction of MAX485 module
#define Pin13LED         13   // Built in LED to indicate command has recieved
SoftwareSerial RS485Serial(SSerialRX, SSerialTX); // initialize RX and TX
  pinMode(Pin13LED, OUTPUT);                    // Pin13LED as OUTPUT
  pinMode(SSerialTxControl, OUTPUT);            // SSerialTxControl as OUTPUT
  digitalWrite(SSerialTxControl, RS485Receive); // initial set SSerialTxControl are closed
  RS485Serial.begin(115200);
if (RS485Serial.available() > 0 )
     inputString = RS485Serial.readByte();
     digitalWrite(SSerialTxControl, RS485Transmit);
     RS485Serial.println(inputString);
But i getting this error:
exit status 1
I have to try to readString and it is working well, but this problem come when i am readByte.
anyone can help? Thank you for your attention.
readBytes ?
What is inputString? It is stupid to post snippets.
The read() method returns a byte.
Why do you think that the SoftwareSerial class has a readByte() method?
SoftwareSerial will never work at 115200 baud.
pylon:
In practice, SoftwareSerial works well at 115200 Bd.
Not if you need to do anything else.
PaulS:
Have you wanted to mean 'multi-tasking?'
GolamMostafa:
No. Add ANYTHING else for the Arduino to do, other than reading and writing serial data, and SoftwareSerial will not be able to keep up.
PaulS:
Please, clarify the meaning of 'not be able to keep up.'
In the loop() function of the Master-NANO, I have included two tasks in series : (a) receiving charcaters from the InputBox of the Serial Monitor and transferring them to SlaveUNO using SUART at 115200 Bd (b) temperature logging from LM35 sensor at 1-sec interval.
The network works in respect of data acquisition/presentation and transfer; however, the Slave receives data slowly due to delay insertion in the acquisition of LM35's data. There is no change in the behavior of the network even at 9600 Bd.
