Class static variables and functions
I want to move class variables to static as they are common to all instances of the class. I keep getting an "undefined reference" error when I compile. I made up the following test. The variable _species is shared by all class members. This is the main sketch:
//  static class variable and function test
#include <SoftwareSerial.h>
#include "MFF.h"
int sp = 3;
MFF fly = MFF(sp);
  delay(200);
  MFF::set_species(4);
  while(1);
This is the header file MFF.h.
//  MFF header
#ifndef GUARD_MFF
#define GUARD_MFF
#if (ARDUINO > 100)
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
class MFF {
  private:
    static int _species;
    int mff_var;
  public:
    MFF(const int var);
  //  setters
    static void MFF::set_species(const int species);
  //  getters
    static int MFF::get_species();
#endif
And this is the implementation file MFF.cpp.
#include "MFF.h"
MFF::MFF(const int var) {
  mff_var = var;
//  setter
void MFF::set_species(const int species) { _species = species; }
//  getter
int MFF::get_species() { return _species; }
The error messages is as follows:
Arduino: 1.8.12 (Mac OS X), Board: "Arduino/Genuino Uno"
/var/folders/bx/71cpj8fw8xl046001s79p93h0000gp/T//ccahHDyc.ltrans0.ltrans.o: In function `set_species':
sketch/MFF.cpp:8: undefined reference to `MFF::_species'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
I don't understand why the public set_species() function can't be found.
dfitterman:
I don't understand why you think that.
The problem is with the static member variable.
You haven't defined (i.e. allocated storage space for) the static variable. Add to the .cpp file:
int MFF::_species;
gfvalvo: Thanks! That solved the problem. Much appreciated.
