Guys,
I'm not sure if this is the best place to post this, but here goes...
I have an issue with the Maple mini code for Arduino, where because the main sketch re-uses the same ram that the bootloader was using, I'm getting strange issues where the main sketch doesnt run unless I power cycle the board
Just a bit of background. On the Maple mini board (by leaflabs) which was developed to work with the Arduino IDE.
The bootloader seems similar to the Arduino bootloader, in that it waits a second after start for an upload (in this case via USB directly) and if no upload, it runs the sketch in the flash
Looking at the linker sections, the MEMORY - RAM section is offset from the base by 3K, so we are wasting 3k of the total 20k ram on the board.
However if I change the linker file to use Ram from the base address of the RAM, I get strange results.
If power cycle it works fine, runs the bootloader and the bootloader runs the existing code
If however I press reset, the bootloader runs, but the sketch doesnt run. Restting again doesnt help
I have to power cycle to get it to work
I'm pretty sure the bootloader does not continue to run after the sketch is running (well its not supposed to)
So the issue appears to be that the RAM that the sketch is using, is somehow corrupted, and only a power cycle allows it to run.
I don't know quite what in the RAM (3k area) could be causing this, as I expect the bottom of ram is full of all sorts of stuff that isn't variables e.g. vector tables etc.
So my guess would be that my best course of action would be to somehow set the linker script to fill the :data section with zero's or perhaps FF
Or somehow otherwise initialise the RAM so that this issue doesnt occur
But I've no idea how to do this in the linker script, or even if this is possible in the pre-init code perhaps ??
I've attached the linker include that sets the data section up
Does anyone know any way to approach fixing this ?
Thanks
Roger
Edit.
The BB doesnt support that file type
Here is the file
* Linker script for libmaple.
* Original author "lanchon" from ST forums, with modifications by LeafLabs.
OUTPUT_FORMAT ("elf32-littlearm", "elf32-bigarm", "elf32-littlearm")
* Configure other libraries we want in the link.
* libgcc, libc, and libm are common across supported toolchains.
* However, some toolchains require additional archives which aren't
* present everywhere (e.g. ARM's gcc-arm-embedded releases).
* To hack around this, we let the build system specify additional
* archives by putting the right extra_libs.inc (in a directory under
* toolchains/) in our search path.
GROUP(libgcc.a libc.a libm.a)
INCLUDE extra_libs.inc
* These force the linker to search for vector table symbols.
* These symbols vary by STM32 family (and also within families).
* It's up to the build system to configure the link's search path
* properly for the target MCU.
INCLUDE vector_symbols.inc
/* STM32 vector table. */
EXTERN(__stm32_vector_table)
/* C runtime initialization function. */
EXTERN(start_c)
/* main entry point */
EXTERN(main)
/* Initial stack pointer value. */
EXTERN(__msp_init)
PROVIDE(__msp_init = ORIGIN(ram) + LENGTH(ram));
/* Reset vector and chip reset entry point */
EXTERN(__start__)
ENTRY(__start__)
PROVIDE(__exc_reset = __start__);
/* Heap boundaries, for libmaple */
EXTERN(_lm_heap_start);
EXTERN(_lm_heap_end);
SECTIONS
.text :
__text_start__ = .;
* STM32 vector table. Leave this here. Yes, really.
*(.stm32.interrupt_vector)
* Program code and vague linking
*(.text .text.* .gnu.linkonce.t.*)
*(.plt)
*(.gnu.warning)
*(.glue_7t) *(.glue_7) *(.vfp11_veneer)
*(.ARM.extab* .gnu.linkonce.armextab.*)
*(.gcc_except_table)
*(.eh_frame_hdr)
*(.eh_frame)
. = ALIGN(4);
KEEP(*(.init))
. = ALIGN(4);
__preinit_array_start = .;
KEEP (*(.preinit_array))
__preinit_array_end = .;
. = ALIGN(4);
__init_array_start = .;
KEEP (*(SORT(.init_array.*)))
KEEP (*(.init_array))
__init_array_end = .;
. = ALIGN(0x4);
KEEP (*crtbegin.o(.ctors))
KEEP (*(EXCLUDE_FILE (*crtend.o) .ctors))
KEEP (*(SORT(.ctors.*)))
KEEP (*crtend.o(.ctors))
. = ALIGN(4);
KEEP(*(.fini))
. = ALIGN(4);
__fini_array_start = .;
KEEP (*(.fini_array))
KEEP (*(SORT(.fini_array.*)))
__fini_array_end = .;
KEEP (*crtbegin.o(.dtors))
KEEP (*(EXCLUDE_FILE (*crtend.o) .dtors))
KEEP (*(SORT(.dtors.*)))
KEEP (*crtend.o(.dtors))
} > REGION_TEXT
* End of text
.text.align :
. = ALIGN(8);
__text_end__ = .;
} > REGION_TEXT
* .ARM.exidx exception unwinding; mandated by ARM's C++ ABI
__exidx_start = .;
.ARM.exidx :
*(.ARM.exidx* .gnu.linkonce.armexidx.*)
} > REGION_RODATA
__exidx_end = .;
* .data
.data :
__data_start__ = .;
LONG(0)
. = ALIGN(8);
*(.got.plt) *(.got)
*(.data .data.* .gnu.linkonce.d.*)
. = ALIGN(8);
__data_end__ = .;
} > REGION_DATA AT> REGION_RODATA
* Read-only data
.rodata :
*(.rodata .rodata.* .gnu.linkonce.r.*)
/* .USER_FLASH: We allow users to allocate into Flash here */
*(.USER_FLASH)
/* ROM image configuration; for C startup */
. = ALIGN(4);
_lm_rom_img_cfgp = .;
LONG(LOADADDR(.data));
* Heap: Linker scripts may choose a custom heap by overriding
* _lm_heap_start and _lm_heap_end. Otherwise, the heap is in
* internal SRAM, beginning after .bss, and growing towards
* the stack.
* I'm shoving these here naively; there's probably a cleaner way
* to go about this. [mbolivar]
_lm_heap_start = DEFINED(_lm_heap_start) ? _lm_heap_start : _end;
_lm_heap_end = DEFINED(_lm_heap_end) ? _lm_heap_end : __msp_init;
} > REGION_RODATA
* .bss
.bss :
. = ALIGN(8);
__bss_start__ = .;
*(.bss .bss.* .gnu.linkonce.b.*)
*(COMMON)
. = ALIGN (8);
__bss_end__ = .;
_end = __bss_end__;
} > REGION_BSS
* Debugging sections
.stab 0 (NOLOAD) : { *(.stab) }
.stabstr 0 (NOLOAD) : { *(.stabstr) }
/* DWARF debug sections.
* Symbols in the DWARF debugging sections are relative to the beginning
* of the section so we begin them at 0. */
/* DWARF 1 */
.debug 0 : { *(.debug) }
.line 0 : { *(.line) }
/* GNU DWARF 1 extensions */
.debug_srcinfo 0 : { *(.debug_srcinfo) }
.debug_sfnames 0 : { *(.debug_sfnames) }
/* DWARF 1.1 and DWARF 2 */
.debug_aranges 0 : { *(.debug_aranges) }
.debug_pubnames 0 : { *(.debug_pubnames) }
/* DWARF 2 */
.debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) }
.debug_abbrev 0 : { *(.debug_abbrev) }
.debug_line 0 : { *(.debug_line) }
.debug_frame 0 : { *(.debug_frame) }
.debug_str 0 : { *(.debug_str) }
.debug_loc 0 : { *(.debug_loc) }
.debug_macinfo 0 : { *(.debug_macinfo) }
/* SGI/MIPS DWARF 2 extensions */
.debug_weaknames 0 : { *(.debug_weaknames) }
.debug_funcnames 0 : { *(.debug_funcnames) }
.debug_typenames 0 : { *(.debug_typenames) }
.debug_varnames 0 : { *(.debug_varnames) }
.note.gnu.arm.ident 0 : { KEEP (*(.note.gnu.arm.ident)) }
.ARM.attributes 0 : { KEEP (*(.ARM.attributes)) }
/DISCARD/ : { *(.note.GNU-stack) }
