Hello everybody,
I'm trying to copy a RF remote for garage doors. The remote is a rolling code one. I don't bother at this moment about the rolling code as i'm stuck with recording and transmitting the signal (ones i make progress on copying and retransmitting the signal, i will try to obtain the encryption key and registering the remote with the garage door). I'm able to capture the signal and record it, but i can't understand the way to send it. I'm using a couple of cheap receiver and transmitter bought from ebay for 4$. The frequency is 433mhz.
The code i receive is composed with short and long ones separated by zeros (Ex: 1110011111). From that code i found the following sequence:
Each short ones equal to a LOW and each long ones equal to a HIGH. Applying that logic to the code captured i obtained this:
000000000000110001001100101000100110111000101101001010011100111011111111101111
000000000000110001001100101000100110111000101101001010011100111011111111101110
As you see, the signal is repeated three times with the second bit of last two repetitions turned zero.
By registering a couple more signals i found that the last 34 bits of every signal is the same. Below are three different captures:
000000000000000011010010100011001000001100001101001010011100111011111111101111
000000000000000011010010100011001000001100001101001010011100111011111111101110
000000000000101111100000000101110101111010101101001010011100111011111111101111
000000000000101111100000000101110101111010101101001010011100111011111111101110
Now, when i transmit the signal i captured and registers it. I don't get the same sequence i registered from the remote. What am i doing wrong when transmitting it? Below is the code i wrote to capture and transmit the RF signal:
short rxPin = 2;
short txPin = 4;
short ledPin = 12;
short btnPin = 6;
bool receiving = false;
const long receiveThreshold = 50000;
const long endThreshold = 20000;
const long maxSignalLength = 100500;
long pulseWidth = 0;
const short maxSignalArraySize = 1500;
byte pulseType[maxSignalArraySize]; //0 = LOW, 1 = HIGH
//short pulseDuration[maxSignalArraySize]; //Stores the length of each pulse
short pulseIndex = 0;
unsigned long pulseStart = -1;
unsigned long lastPulseEnd = -1;
unsigned long signalStart = -1;
byte lastPulseType = 0;
bool receiveCompleted = false;
int buttonState = 0;
short signalCount = 0;
short lowCount = 4;
bool zeroStarted = false;
bool signalStarted = false;
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
pinMode(ledPin, OUTPUT);
byte b = digitalRead(rxPin);
delayMicroseconds(110);
//Serial.print(b);
//Check the beginning of the signal
if (!receiving)
//Signal begins with a long HIGH pulse, detect the start of the HIGH pulse
if (b == 1)
if (pulseStart == -1)
pulseStart = micros();
else if (pulseStart != -1)
pulseWidth = (lastPulseEnd - pulseStart);
//If the first pulse of HIGH exceeds the receiveThreshold, then we're receiving a signal
if (pulseWidth > receiveThreshold)
//Signal transmission has already started with the first HIGH pulse
//setPulseValue(1, pulseWidth);
/*pulseType[pulseIndex] = b;
pulseIndex++;*/
signalStart = pulseStart;
receiving = true;
digitalWrite(ledPin, HIGH);
pulseStart = -1;
if (!receiveCompleted)
if (pulseIndex < 1500)
if (b == 1)
if (!signalStarted)
signalStarted = true;
signalCount++;
if (zeroStarted)
else if (!zeroStarted && signalStarted)
zeroStarted = true;
if (signalCount < lowCount)
pulseType[pulseIndex] = 0;
pulseIndex++;
pulseType[pulseIndex] = 1;
pulseIndex++;
signalCount = 0;
receiveCompleted = true;
for (int i = 0; i < 1500; i++)
Serial.print(pulseType[i]);
if (b != lastPulseType)
pulseWidth = lastPulseEnd - pulseStart;
lastPulseType = b;
//If the pulse of LOW exceeds the endThreshold, the signal transmission is completed
if (b == 1 && pulseWidth > endThreshold)
for (int i = 0; i < pulseIndex; i++)
delay(3000);
digitalWrite(ledPin, LOW);
//If the user press the button, send the signal
if (buttonState == 0 && digitalRead(btnPin) == 1)
buttonState = 1;
byte cBit = pulseType[i];
digitalWrite(txPin, HIGH);
if (cBit == 1)
delayMicroseconds(100);
delayMicroseconds(80);
digitalWrite(txPin, LOW);
delay(3000);
lastPulseEnd = micros();
Thanks for any help.
