I have built the CNC Control Pendant for Mach4, connected through USB Serial originated by Simon Rafferty on GitHub https://github.com/SimonRafferty/Mach4-Serial-Pendant
This is my first post, so please excuse any missteps.
I am using a basic Nano board but am receiving coding errors in the Arduin IDE.
This is the code.
// This is a Pendant for Mach4 which runs over Serial / USB
// Attach an MPG Wheel to your Arduino Nano. I'm using A to D3
// & B to D4. D3 is important as it maps to Interrupt 1
// There's an I2C Touch display for the Pendant buttons.
// When a button is pressed or the MPG moved, a single character
// command is sent to Mach4 over Serial. When it's acted upon,
// Mach4 sends the button state or DRO value back which is updated
// on the display. This gives a remote confirmation of the command.
// Sent Commands:
// I : MPG Increment D : MPG Decrement
// X : Jog X Axis Y : Jog Y Axis Z : Jog Z Axis F : Feed Rate Override Q : Spindle Override N : Move No Axis (disable MPG)
// 1 : Jog Inc 0.001 2 : Jog Inc 0.010 3 : Jog Inc 0.100 4 : Jog Inc 1.000
// E : E-Stop
// C : Coolant
// H : Feed Hold
// S : Start Cycle
// T : Stop Cycle
// K : In resopnse to a sent 'O' - used to check comms
// Received Commands. The Parser (https://github.com/pvizeli/CmdParser)
// Expects "Command<space>Param1<space>Param2....etc..\n"
// D ? #.#### : DRO Count [X,Y,Z,S,F]
// J ? : [X,Y,Z,S,F,N] Which Axis Mach4 thinks is Active for Jogging
// I # : [1,2,3,4] Active Jog Increment
// B E # : 1=E-Stop 0=Not E-Stop
// B C # : 1=Coolant Active 0=Coolant Inactive
// B H # : 1=Feed Hold Active 0=Feed Hold Inactive
// B S # : 1=Start Cycle Active 0=Stopped
// O : Replies with K - used to check comms
#include <CmdBuffer.hpp>
#include <CmdCallback.hpp>
#include <CmdParser.hpp>
CmdCallback<5> cmdCallback;
CmdBuffer<32> myBuffer;
CmdParser myParser;
float XDRO = 0; //Store for current X Position
float YDRO = 0; //Store for current X Position
float ZDRO = 0; //Store for current X Position
float LastXDRO = 0; //Store for current X Position
float LastYDRO = 0; //Store for current X Position
float LastZDRO = 0; //Store for current X Position
int SDRO = 0; //Store for Spindle Speed
int FDRO = 0; //Store for Feed Rate Override
char DROVal[9]; // Buffer big enough for 8-character float
int32_t MPGCount = 0; //Last MPG Count Value
int step_state = 1;
#include "LiquidCrystalDisplay.h"
const uint8_t User01[]="USER"; //Text for user defined button
const uint8_t User02[]="USER"; //Text for user defined button
const uint8_t InitStep[]="0.0000"; //Initialisation of text labels
const uint8_t InitDisp[]="0000.0000"; //Initialisation of text labels
const uint8_t String01[]="Password ok!";
const uint8_t String02[]="Password error!";
const uint8_t String03[]="Error";
const uint8_t String04[]="Input number ok!";
const uint8_t String05[]="Input number error!";
uint16_t HighlightColour = 0xFEA0; //Yellow
uint16_t DROTextColour = 0xFFFF; //Light Yellow
uint16_t TransparentColour = 0xC618;
int EnabledState = 0;
uint8_t identifier,cnt;
uint8_t cmd_buffer[CMD_MAX_SIZE];
uint8_t data_size;
uint8_t update_en;
uint8_t command_cmd;
uint8_t command_statu;
uint8_t command_length;
uint8_t page_Id_bk = 0;
uint8_t page_Id = 1;
uint8_t targe_Id = 0;
long DROUpdate = 0;
LiquidCrystal TFTlcd(13);//RST pin13
update_en =0;
data_size =0;
TFTlcd.queue_reset();
pinMode(3,INPUT_PULLUP); //MPG A Signal
pinMode(4,INPUT_PULLUP); //MPG B Signal
Serial.println(F("Pendant Started"));
TFTlcd.begin();
TFTlcd.SetBackLight(100); //Set the backlight
delay(100);
TFTlcd.SetBackLight(30); //Set the backlight
attachInterrupt(0,LcdIICInterrupt,FALLING);//Interrupt 0 is D2 PIN
attachInterrupt(1,UpdateMPG,RISING);//Interrupt 1 is D3 PIN
TFTlcd.SetPage(1);//main page id is 4
//Setup command parser callback functions
cmdCallback.addCmd("B", &fUpdateButton);
cmdCallback.addCmd("D", &fUpdateDRO);
cmdCallback.addCmd("J", &fUpdateMove);
cmdCallback.addCmd("I", &fUpdateJogInc);
cmdCallback.addCmd("O", &fEcho);
myBuffer.setEcho(false);
//Clear Jog Indicators
TFTlcd.RectangleFill(80,15, 20,35, TransparentColour);
TFTlcd.RectangleFill(80,75, 20,35, TransparentColour);
TFTlcd.RectangleFill(80,135, 20,35, TransparentColour);
TFTlcd.PutString(110,10,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)InitDisp); //X DRO
TFTlcd.PutString(110,70,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)InitDisp); //Y DRO
TFTlcd.PutString(110,130,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)InitDisp); //Z DRO
TFTlcd.PutString(120,330,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)InitStep); //Step DRO
drawEnableButton(0);
TFTlcd.PutString(125,270,0x02,0x20,0x00,0x00,0x00, (unsigned char *)User01);
TFTlcd.PutString(235,270,0x02,0x20,0x00,0x00,0x00, (unsigned char *)User02);
data_size = TFTlcd.queue_find_cmd(cmd_buffer,CMD_MAX_SIZE);
if(data_size>0)//receive command
//Serial.println(data_size, HEX);
//Serial.println(F("ProcessMessage"));
ProcessMessage((PCTRL_MSG)cmd_buffer, data_size);//command process
// Check for new char on serial and call function if command was entered
cmdCallback.updateCmdProcessing(&myParser, &myBuffer, &Serial);
//Update DROs every 100ms
if(millis()-DROUpdate>100) {
if(LastXDRO!=XDRO) {
dtostrf(XDRO, 8, 4, DROVal);
TFTlcd.DisplayCut_Image(110,10,200,40,0x01); //Clear box
TFTlcd.PutString(110,10,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)DROVal); //X DRO
LastXDRO=XDRO;
if(LastYDRO!=YDRO) {
dtostrf(YDRO, 8, 4, DROVal);
TFTlcd.DisplayCut_Image(110,70,200,40,0x01); //Clear box
TFTlcd.PutString(110,70,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)DROVal); //Y DRO
LastYDRO=YDRO;
if(LastZDRO!=ZDRO) {
dtostrf(ZDRO, 8, 4, DROVal);
TFTlcd.DisplayCut_Image(110,130,200,40,0x01); //Clear box
TFTlcd.PutString(110,130,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)DROVal); //Z DRO
LastZDRO=ZDRO;
DROUpdate = millis();
void UpdateMPG() {
//Send Serial command to Mach4 to Jog Triggered on rising edge of MPG A line
//This is a very simple, single interrupt, quadrature decoder
if(digitalRead(4)) {
Serial.println("D");
Serial.println("I");
void LcdIICInterrupt()
//Serial.println("IRQ 0");
command_cmd = TFTlcd.I2C_Read();
TFTlcd.queue_push(command_cmd);
for(cnt =0;cnt <2;cnt++)
identifier = TFTlcd.I2C_Read();
TFTlcd.queue_push(identifier);
//Serial.println(identifier, HEX);
command_statu = TFTlcd.I2C_Read();
TFTlcd.queue_push(command_statu);
command_length = TFTlcd.I2C_Read();
TFTlcd.queue_push(command_length);
if((command_cmd == GET_EDIT_VALUE && command_statu == 0x6f)||(command_cmd == GET_TOUCH_EDIT_VALUE && command_statu == 0x6f))
for(cnt =0;cnt <command_length;cnt++)
void fEcho(CmdParser *myParser) {
//Comms check. An 'O' has been received, send 'K'
Serial.println("K");
void fUpdateDRO(CmdParser *myParser) {
//Command will have two parameters - The Axis Name [X,Y,Z,S,F] and a Value
if (myParser->equalCmdParam(1, "X")) {
XDRO = atof(myParser->getCmdParam(2));
//Set X DRO value on screen
//Serial.print("Set X DRO To: "); Serial.println(XDRO);
if (myParser->equalCmdParam(1, "Y")) {
YDRO = atof(myParser->getCmdParam(2));
if (myParser->equalCmdParam(1, "Z")) {
ZDRO = atof(myParser->getCmdParam(2));
if (myParser->equalCmdParam(1, "S")) {
SDRO = atoi(myParser->getCmdParam(2));
dtostrf(SDRO, 8, 4, DROVal);
//Not implemented
if (myParser->equalCmdParam(1, "F")) {
FDRO = atoi(myParser->getCmdParam(2));
dtostrf(FDRO, 8, 4, DROVal);
//Not implemented
void fUpdateMove(CmdParser *myParser)
//Command will have one parameter - The Axis Name [X,Y,Z,S,F,N] for which Jog is active N=None
//Clear
//Set indicator active (and others inactive)
//Draw filled rectangle next to X
TFTlcd.RectangleFill(80,15, 20,35, HighlightColour);
//Serial.println("Jog X");
//Draw filled rectangle next to Y
TFTlcd.RectangleFill(80,75, 20,35, HighlightColour);
//Serial.println("Jog Y");
//Draw filled rectangle next to Z
TFTlcd.RectangleFill(80,135, 20,35, HighlightColour);
//Serial.println("Jog Z");
//Serial.println("Jog S");
Serial.println("Jog FRO");
if (myParser->equalCmdParam(1, "N")) {
//Set all indicators Inactive
//Clear
//Serial.println("Jog NONE");
void fUpdateJogInc(CmdParser *myParser)
//Command will have one parameter - 1,2,3,4 indicating the joc increment
const uint8_t sInc1[]="0.0010";
const uint8_t sInc2[]="0.0100";
const uint8_t sInc3[]="0.1000";
const uint8_t sInc4[]="1.0000";
TFTlcd.DisplayCut_Image(120,330,200,40,0x01); //Clear box
if (myParser->equalCmdParam(1, "1")) {
//Set Jog Increment to 0.001
//Serial.println("Update Jog DRO 0.0010");
TFTlcd.PutString(120,330,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)sInc1); //Step DRO
if (myParser->equalCmdParam(1, "2")) {
//Set Jog Increment to 0.010
TFTlcd.PutString(120,330,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)sInc2); //Step DRO
if (myParser->equalCmdParam(1, "3")) {
//Set Jog Increment to 0.100
TFTlcd.PutString(120,330,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)sInc3); //Step DRO
if (myParser->equalCmdParam(1, "4")) {
//Set Jog Increment to 1.000
TFTlcd.PutString(120,330,0x02,0x30,0x01,0x00,DROTextColour, (unsigned char *)sInc4); //Step DRO
void drawEnableButton(int Active)
if(Active==1) {
//Draw rectangle on ENABLE Button
TFTlcd.RectangleFill(5,405,310,70, 0xF800); //Colour button RED
TFTlcd.PutString(90,415,0x01,0x30,0x01,0xF800,DROTextColour, (unsigned char *)"E-STOP"); //E-Stop
//Clear rectangle
//TFTlcd.DisplayCut_Image(5,405,310,70,0x01); //Clear box
TFTlcd.RectangleFill(5,405,310,70, 0xC618); //Colour button GREY
TFTlcd.PutString(80,415,0x01,0x30,0x01,0xC618,0x00, (unsigned char *)"MPG OFF"); //E-Stop
void fUpdateButton(CmdParser *myParser)
int Active = 0;
//Serial.println("Button Pressed");
//Command will have two parameters - A character indicating the Button then 1 to indicate Active, 0 for Inactive
if (myParser->equalCmdParam(1, "E")) {
Active = atoi(myParser->getCmdParam(2));
drawEnableButton(Active);
EnabledState = Active;
if (myParser->equalCmdParam(1, "C")) {
//Serial.print("Coolant "); Serial.println(Active);
if(Active==1) {
//Draw rectangle on Coolant Button
TFTlcd.RectangleFill(15,260,75,10, HighlightColour);
//Clear rectangle
TFTlcd.DisplayCut_Image(15,260,75,10,0x00); //Clear box
if (myParser->equalCmdParam(1, "H")) {
if(Active==1) {
//Draw rectangle on Hold Button
TFTlcd.RectangleFill(120,200,75,10, HighlightColour);
//Clear rectangle
TFTlcd.DisplayCut_Image(120,200,75,10,0x00); //Clear box
if(Active==1) {
//Draw rectangle on START Button
TFTlcd.RectangleFill(15,200,75,10, HighlightColour);
// Clear Rectangle on STOP Button
TFTlcd.DisplayCut_Image(230,200,75,10,0x00); //Clear box
//Draw rectangle on STOP Button
TFTlcd.RectangleFill(230,200,75,10, HighlightColour);
//Clear rectangle on START
TFTlcd.DisplayCut_Image(15,200,75,10,0x00); //Clear box
void ProcessMessage( PCTRL_MSG msg, uint16_t dataSize )
uint8_t cmd_type = msg->cmd_type;
uint8_t control_id = msg->control_id;
uint8_t page_id = msg->page_id;
uint8_t _status = msg->status;
uint8_t key_type = msg->key_type;
uint8_t key_value = msg->key_value;
Serial.println("Process Message");
Serial.print("cmd_type"); Serial.println(cmd_type);
Serial.print("control_id"); Serial.println(control_id);
Serial.print("page_id"); Serial.println(page_id);
Serial.print("_status"); Serial.println(_status);
Serial.print("key_type"); Serial.println(key_type);
Serial.print("key_value"); Serial.println(key_value);
if(cmd_type==NOTIFY_TOUCH_BUTTON){
NotifyTouchButton(page_id,control_id,_status,key_type,key_value);
void NotifyTouchButton(uint8_t page_id, uint8_t control_id, uint8_t state,uint8_t type,uint8_t value)
//Serial.println("Touch Button:");
if(state== KEY_DOWN && control_id==100 )
{ //X Button pressed.
Serial.println("X"); //Send command to Mach4
if(state== KEY_DOWN && control_id==101 )
{ //Y Button pressed.
Serial.println("Y"); //Send command to Mach4
if(state== KEY_DOWN && control_id==102 )
{ //Z Button pressed.
Serial.println("Z"); //Send command to Mach4
if(state== KEY_DOWN && control_id==103 )
{ //START Button pressed.
Serial.println("S"); //Send command to Mach4
if(state== KEY_DOWN && control_id==104 )
{ //HOLD Button pressed.
update_en=true;
Serial.println("H"); //Send command to Mach4
if(state== KEY_DOWN && control_id==105 )
{ //STOP Button pressed.
Serial.println("T"); //Send command to Mach4
if(state== KEY_DOWN && control_id==106 )
{ //COOLANT Button pressed.
Serial.println("C"); //Send command to Mach4
if(state== KEY_DOWN && control_id==107 )
{ //User 1 Button pressed.
Serial.println("U"); //Send command to Mach4
if(state== KEY_DOWN && control_id==108 )
{ //User 2 Button pressed.
Serial.println("V"); //Send command to Mach4
if(state== KEY_RELEASE && (control_id==108 || control_id==107))
{ //User Button released.
if(state== KEY_DOWN && control_id==109 )
{ //STEP Increment Button pressed.
update_en=true;
step_state++;
if(step_state>4) step_state=1;
//Send serial command to Mach4
Serial.println(step_state); //Send command to Mach4
if(state== KEY_DOWN && control_id==110 )
{ //ENABLE Increment Button pressed.
Serial.println("E"); //Send command to Mach4
drawEnableButton(EnabledState);
if(state== KEY_RELEASE && control_id==110 )
//Serial.println("E"); //Send command to Mach4
The code compiles & can be uploaded to the Nano board. This is the Arduino IDE Output response
FQBN: arduino:avr:nano
Using board 'nano' from platform in folder: C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs C:\Users\Owner\AppData\Local\Temp\arduino\sketches\967716CE7C891935B172261C72CA56EC\sketch\SerialPendant2.ino.cpp -o nul
Alternatives for CmdBuffer.hpp: [CmdParser@1.7]
ResolveLibrary(CmdBuffer.hpp)
-> candidates: [CmdParser@1.7]
C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -Id:\Users\Owner\Documents\Arduino\Sketchbook\libraries\CmdParser\src C:\Users\Owner\AppData\Local\Temp\arduino\sketches\967716CE7C891935B172261C72CA56EC\sketch\SerialPendant2.ino.cpp -o nul
Using cached library dependencies for file: C:\Users\Owner\AppData\Local\Temp\arduino\sketches\967716CE7C891935B172261C72CA56EC\sketch\I2C.cpp
Using cached library dependencies for file: C:\Users\Owner\AppData\Local\Temp\arduino\sketches\967716CE7C891935B172261C72CA56EC\sketch\LiquidCrystalDisplay.cpp
Using cached library dependencies for file: d:\Users\Owner\Documents\Arduino\Sketchbook\libraries\CmdParser\src\CmdBuffer.cpp
Using cached library dependencies for file: d:\Users\Owner\Documents\Arduino\Sketchbook\libraries\CmdParser\src\CmdCallback.cpp
Using cached library dependencies for file: d:\Users\Owner\Documents\Arduino\Sketchbook\libraries\CmdParser\src\CmdParser.cpp
Generating function prototypes...
C:\Users\Owner\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino -IC:\Users\Owner\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\variants\eightanaloginputs -Id:\Users\Owner\Documents\Arduino\Sketchbook\libraries\CmdParser\src C:\Users\Owner\AppData\Local\Temp\arduino\sketches\967716CE7C891935B172261C72CA56EC\sketch\SerialPendant2.ino.cpp -o C:\Users\Owner\AppData\Local\Temp\4092349813\sketch_merged.cpp
C:\Users\Owner\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Owner\AppData\Local\Temp\4092349813\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Owner\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Users\\Owner\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\Owner\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\eightanaloginputs" "-Id:\\Users\\Owner\\Documents\\Arduino\\Sketchbook\\libraries\\CmdParser\\src" "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC\\sketch\\SerialPendant2.ino.cpp" -o "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC\\sketch\\SerialPendant2.ino.cpp.o"
Using previously compiled file: C:\Users\Owner\AppData\Local\Temp\arduino\sketches\967716CE7C891935B172261C72CA56EC\sketch\I2C.cpp.o
Using previously compiled file: C:\Users\Owner\AppData\Local\Temp\arduino\sketches\967716CE7C891935B172261C72CA56EC\sketch\LiquidCrystalDisplay.cpp.o
D:\Users\Owner\Documents\Arduino\Sketchbook\SerialPendant2\SerialPendant2.ino: In function 'void fEcho(CmdParser*)':
D:\Users\Owner\Documents\Arduino\Sketchbook\SerialPendant2\SerialPendant2.ino:230:23: warning: unused parameter 'myParser' [-Wunused-parameter]
D:\Users\Owner\Documents\Arduino\Sketchbook\SerialPendant2\SerialPendant2.ino: In function 'void ProcessMessage(PCTRL_MSG, uint16_t)':
D:\Users\Owner\Documents\Arduino\Sketchbook\SerialPendant2\SerialPendant2.ino:400:46: warning: unused parameter 'dataSize' [-Wunused-parameter]
D:\Users\Owner\Documents\Arduino\Sketchbook\SerialPendant2\SerialPendant2.ino: In function 'void NotifyTouchButton(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)':
D:\Users\Owner\Documents\Arduino\Sketchbook\SerialPendant2\SerialPendant2.ino:424:32: warning: unused parameter 'page_id' [-Wunused-parameter]
D:\Users\Owner\Documents\Arduino\Sketchbook\SerialPendant2\SerialPendant2.ino:424:84: warning: unused parameter 'type' [-Wunused-parameter]
D:\Users\Owner\Documents\Arduino\Sketchbook\SerialPendant2\SerialPendant2.ino:424:97: warning: unused parameter 'value' [-Wunused-parameter]
Compiling libraries...
Compiling library "CmdParser"
Using previously compiled file: C:\Users\Owner\AppData\Local\Temp\arduino\sketches\967716CE7C891935B172261C72CA56EC\libraries\CmdParser\CmdParser.cpp.o
Using previously compiled file: C:\Users\Owner\AppData\Local\Temp\arduino\sketches\967716CE7C891935B172261C72CA56EC\libraries\CmdParser\CmdBuffer.cpp.o
Using previously compiled file: C:\Users\Owner\AppData\Local\Temp\arduino\sketches\967716CE7C891935B172261C72CA56EC\libraries\CmdParser\CmdCallback.cpp.o
Compiling core...
Using precompiled core: C:\Users\Owner\AppData\Local\Temp\arduino\cores\arduino_avr_nano_cpu_atmega328_5738e5a66cf7c5db5d65c685878846d9\core.a
Linking everything together...
"C:\\Users\\Owner\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC/SerialPendant2.ino.elf" "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC\\sketch\\I2C.cpp.o" "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC\\sketch\\LiquidCrystalDisplay.cpp.o" "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC\\sketch\\SerialPendant2.ino.cpp.o" "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC\\libraries\\CmdParser\\CmdBuffer.cpp.o" "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC\\libraries\\CmdParser\\CmdCallback.cpp.o" "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC\\libraries\\CmdParser\\CmdParser.cpp.o" "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC/..\\..\\cores\\arduino_avr_nano_cpu_atmega328_5738e5a66cf7c5db5d65c685878846d9\\core.a" "-LC:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC" -lm
"C:\\Users\\Owner\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC/SerialPendant2.ino.elf" "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC/SerialPendant2.ino.eep"
"C:\\Users\\Owner\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC/SerialPendant2.ino.elf" "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC/SerialPendant2.ino.hex"
Using library CmdParser at version 1.7 in folder: D:\Users\Owner\Documents\Arduino\Sketchbook\libraries\CmdParser
"C:\\Users\\Owner\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\Owner\\AppData\\Local\\Temp\\arduino\\sketches\\967716CE7C891935B172261C72CA56EC/SerialPendant2.ino.elf"
Sketch uses 11164 bytes (36%) of program storage space. Maximum is 30720 bytes.
Global variables use 904 bytes (44%) of dynamic memory, leaving 1144 bytes for local variables. Maximum is 2048 bytes.
Any insights to my problem would be greatly appreciated.
