Hi guys,
I am having problem connecting my Arduino to my computer.
When i want to update the driver to recognize the arduino card, i have an error (code 52) below two picture may show the problem.
Please can anyone help me please, i spend so much time to find a solution but i can't find it..
Thanks in advance.
what Arduino is it? What OS on the PC?
Code 52 in Windows is a driver problem and it suggests getting the drivers from the manufacturer of the board.
I had to find CH341 drivers for mine and I got them from a Chinese site.
Peter
Please READ THIS POST to help you get the best out of the forum.
SIMPLE TROUBLESHOOTING.
These steps may also save you some unnecessary time and effort in the forum.
- Always provide as much detail as possible to your issue it may be important.
- If applicable provide your SKETCH inside CODE TAGS ( </> ) or a CREATE share link.
- If applicable provide a schematic even if hand drawn.
- How to insert a picture into your post
- If applicable provide a proper LINK to the hardware / sensors etc. you are using.
COMMON ISSUES
- Check you have a COMMON GROUND where required.
- Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
- Try other computers where possible.
- Try other USB leads where possible.
- You may not have the correct driver installed. CH340/341 or CP2102
- There may be a problem with the board check your wiring first.
- Remove any items connected to pins 0 and 1.
COMPUTER RELATED
- close any other serial programs before opening the IDE.
- Ensure you turn off any additional security / antivirus just to test.
- There may be a problem with the PC try RESTARTING it.
- You may be selecting the wrong COM port.
- Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
- Clear your browsers CACHE.
- Close the IDE before using any other serial programs.
- Preferably install IDE's as ADMINISTRATOR or your OS equivalent
Arduino specific boards
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Bob.
