Here's the code being used. It's kinda cobbled together from a couple different sources and TBH I'm not 100% certain about what some of it does. My background is in art and I'm just trying to get this done as part of a children's interactive piece so yeah, i'm a bit lost/frustrated.
Would REALLY appreciate any input or possible fixes you have for this code though!
#include <Wire.h>
#include "Adafruit_TCS34725.h"
#include "Flora_Pianoglove.h"
// we only play a note when the clear response is higher than a certain number
//#define CLEARTHRESHHOLD 1300
// our RGB -> eye-recognized gamma color
byte gammatable[256];
// color sensor
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_2_4MS, TCS34725_GAIN_4X); // integreation times can be 2_4MS, 24MS, 50MS, 101MS, 154MS, 700MS -gain can be 1X, 4X, 16X, 60X
// one pixel on pin 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(24, 6, NEO_GRB + NEO_KHZ800);
if (tcs.begin()) {
Serial.println("Found sensor");
Serial.println("No TCS34725 found ... check your connections");
while (1); // halt!
strip.begin();
strip.show(); // Initialize all pixels to 'off'
// thanks PhilB for this gamma table!
// it helps convert RGB colors to what humans see
for (int i=0; i<256; i++) {
float x = i;
x /= 255;
x = pow(x, 3.3); //WAS 3.3
x *= 255;
gammatable[i] = x;
//Serial.println(gammatable[i]);
uint16_t clear, red, green, blue;
delay(80); // takes 50ms to read
tcs.getRawData(&red, &green, &blue, &clear);
delay(40);
/* // not close enough to colorful item
if (clear < CLEARTHRESHHOLD) {
for(int i = 0; i < 25 ; i++)
strip.setPixelColor(i, strip.Color(22, 222, 0)); // turn off the LED
strip.show();
return;
// Figure out some basic hex code for visualization
uint32_t
sum = red;
sum += green;
sum += blue;
sum = clear;
float r, g, b;
r = red; r /= sum;
g = green; g /= sum;
b = blue; b /= sum;
r *= 620; g *= 555; b *= 510; //HERE IS WHERE WE LIVE NOW WAS 255, 240, 220
if (r > 255) r = 255;
if (g > 255) g = 255;
if (b > 255) b = 255;
// OK we have to find the two primary colors
// check if blue is smallest. MEME: fix for 'white'
float remove, normalize;
if ((b < g) && (b < r)) {
remove = b;
normalize = max(r-b, g-b);
} else if ((g < b) && (g < r)) {
remove = g;
normalize = max(r-g, b-g);
remove = r;
normalize = max(b-r, g-r);
// get rid of minority report
float rednorm = r - remove;
float greennorm = g - remove;
float bluenorm = b - remove;
// now normalize for the highest number
rednorm /= normalize;
greennorm /= normalize;
bluenorm /= normalize;
strip.setPixelColor(i, strip.Color(gammatable[(int)r], gammatable[(int)g], gammatable[(int)b]));
strip.show();
delay(20);
RgbColor HsvToRgb(HsvColor hsv)
RgbColor rgb;
unsigned char region, remainder, p, q, t;
if (hsv.s == 0)
rgb.r = hsv.v;
rgb.g = hsv.v;
rgb.b = hsv.v;
return rgb;
region = hsv.h / 43;
remainder = (hsv.h - (region * 43)) * 6;
p = (hsv.v * (255 - hsv.s)) >> 8;
q = (hsv.v * (255 - ((hsv.s * remainder) >> 8))) >> 8;
t = (hsv.v * (255 - ((hsv.s * (255 - remainder)) >> 8))) >> 8;
switch (region)
case 0:
rgb.r = hsv.v; rgb.g = t; rgb.b = p;
case 1:
rgb.r = q; rgb.g = hsv.v; rgb.b = p;
case 2:
rgb.r = p; rgb.g = hsv.v; rgb.b = t;
case 3:
rgb.r = p; rgb.g = q; rgb.b = hsv.v;
case 4:
rgb.r = t; rgb.g = p; rgb.b = hsv.v;
default:
rgb.r = hsv.v; rgb.g = p; rgb.b = q;
return rgb;
HsvColor RgbToHsv(RgbColor rgb)
HsvColor hsv;
unsigned char rgbMin, rgbMax;
rgbMin = rgb.r < rgb.g ? (rgb.r < rgb.b ? rgb.r : rgb.b) : (rgb.g < rgb.b ? rgb.g : rgb.b);
rgbMax = rgb.r > rgb.g ? (rgb.r > rgb.b ? rgb.r : rgb.b) : (rgb.g > rgb.b ? rgb.g : rgb.b);
hsv.v = rgbMax;
if (hsv.v == 0)
hsv.h = 0;
hsv.s = 0;
return hsv;
hsv.s = 255 * long(rgbMax - rgbMin) / hsv.v;
if (hsv.s == 0)
hsv.h = 0;
return hsv;
if (rgbMax == rgb.r)
hsv.h = 0 + 43 * (rgb.g - rgb.b) / (rgbMax - rgbMin);
else if (rgbMax == rgb.g)
hsv.h = 85 + 43 * (rgb.b - rgb.r) / (rgbMax - rgbMin);
hsv.h = 171 + 43 * (rgb.r - rgb.g) / (rgbMax - rgbMin);
return hsv;
