Code Millis
hello,
I am a beginner and I am trying to introduce the millis () function in a program but cannot do.
I have no idea how to use it.
Could you show me how to code with the millis () function so that:
If my sensor is less than 200: it is the RED LED ON: // this I succeeded.
If my sensor is greater than 200 for more than 5s since the change of state of my sensor: the GREEN LED lights up
If my sensor is greater than 200 for less than 5s since the change of state of my sensor: the RED LED lights up
Here is my code. I thank you in advance.
// initialize serial communications at 9600 bps:
// initialize l'entrée capteur
pinMode(9, INPUT_PULLUP);
// initialize la sortie led
pinMode (10, OUTPUT) ; // 10 : LED rouge
pinMode (12, OUTPUT) ; // 12 : LED vert
digitalWrite(10,LOW);
digitalWrite(12,HIGH);
// read the analog in value:
sensorValue = analogRead(analogInPin);
Serial.println(sensorValue) ;
// si detection
if (sensorValue < 200){
digitalWrite(10,HIGH);
digitalWrite(12,LOW) ;}
if (sensorValue > 200) && ((millis() - temps) < 5000)
{ temps = millis();
// Si pas de detection
else {
digitalWrite(12
Your code is incomplete.
Please remember to use code tags when posting code
Using millis() for timing tutorials:
Several things at a time.
Beginner's guide to millis().
Blink without delay().
Please modify your first post and remove the [ left ] and [ pre ] tags and use code-tags for the sketch.
Here's an untested (but compiles) example of how you might do such things with a state machine.
enum
    WAIT_LESS_THAN_200 = 0,
    WAIT_FOR_MORE_THAN_200,
    CHECK_TIME_ELAPSED_SINCE_CHANGE,
const uint8_t pinSensorInput = 9;       //unused?
const uint8_t pinRougeLED = 10;
const uint8_t pinVertLED = 12;
const uint8_t analogInPin = A0;         //correct pin? was not previously defined
int sensorValue;
    pinMode( pinSensorInput, INPUT_PULLUP );
    pinMode( pinRougeLED, OUTPUT ) ; //  10 : LED rouge
    pinMode( pinVertLED, OUTPUT ) ; // 12 : LED vert
    digitalWrite( pinRougeLED,LOW );
    digitalWrite( pinVertLED, HIGH );
}//setup
    static uint8_t
        state = WAIT_LESS_THAN_200;
    static uint32_t
        timeStateChange,
        timeReadSensor = 0;
    uint32_t
        timeNow = millis();
    // si detection 20x/sec
    if( (timeNow - timeReadSensor) >= 50ul )
        timeReadSensor = timeNow;
    }//if
    switch( state )
        case    WAIT_LESS_THAN_200:
            //we wait here for the sensor to read < 200
            if( sensorValue < 200 )
                //If my sensor is less than 200: it is the RED LED ON
                digitalWrite( pinVertLED, LOW );
                digitalWrite( pinRougeLED, HIGH );
                //then go to the state waiting for the sensor to read >= 200
                state = WAIT_FOR_MORE_THAN_200;
            }//if
        case    WAIT_FOR_MORE_THAN_200:
            //sensor is less than 200 now; here we wait for it to go >= 200
            if( sensorValue >= 200 )
                //If my sensor is greater than 200 for less than 5s since the change of state of my sensor: the RED LED lights up
                //this is same LED state as <200 (?)
                //get the time we saw this transition to >= 200
                timeStateChange = timeNow;
                //and move to time the 5-sec period
                state = CHECK_TIME_ELAPSED_SINCE_CHANGE;
            }//if
        case    CHECK_TIME_ELAPSED_SINCE_CHANGE:
            //value had increased to >=200; if it falls below 200 again, go back to the first state
            //otherwise check to see if 5-second has elapsed...
            else if( (timeNow - timeStateChange) >= 5000ul )
                //If my sensor is greater than 200 for more than 5s since
                //the change of state of my sensor: the GREEN LED lights up
                digitalWrite( pinRougeLED, LOW );
                //I'm guessing you can go back to wait for <200 again
            }//else
    }//switch
}//loop
Hello Blackfin,
Thanks so much for the code.
This works !!! I'm happy.
Have a good day.
