Comparator LM339 not accurate ?
I'm feeding 5V from an arduino to the circuit. I'm comparing the voltages across 2 trimpots. I use 4K7 as a pullup resistor.
I measure 2.5V at the Positive Input (Pin 10) and 2.503V at the Negative Input (Pin 9).
The Output (Pin 16) reads HIGH, but it should read LOW, since 2.5<2.503
Only at 2.508 is the switch happening, and the Ouput isn't a steady LOW but it's fluctuating, I guess because of noise. At 2.509V and above it is steadily LOW.
Is this behavior normal for a LM339 ? Meaning, is there always a delta?
Look in the datasheet for "Input offset voltage".
For removing jitter, google "LM339 hysteresis".
A circuit diagram will to.
What is the application you need the comparator for?
As @MK1888 has said you need some hysteresis.
google lm339 applications.
js-:
The datasheet shows the worst case DC offset for the LM339 is 5mV and for the LM339A is 3mV, at 25C.
If you need a precision comparator you'll need a difference device, or amplify the signals with a precision
opamp before comparing them.
You can also consider trimming the device to compensate - this won't be perfect, but its doable.
I understand. However, the delta I'm measuring is rather 10mV and not 5mV like mentioned in the datasheet (at Vcc=5V)...
Are you using a 0.1 uF bypass capacitor between Vcc and ground right at Vcc? If not I would add one. Also where are the remaining input pins going?
Ron
If you are measuring those voltages with a multimeter, keep in mind that the multimeter has internal noise and that the meter leads pick up environmental electrical noise, introducing that into the circuit.
