Compilation error: 'NOTE_C1' was not declared in this scope
Hi all, I'm having a strange problem that I can't figure out
C:\Users\Kamil\AppData\Local\Temp.arduinoIDE-unsaved202429-3452-1g9tsa6.m17rh\sketch_mar9a\sketch_mar9a.ino: In function 'void loop()':
C:\Users\Kamil\AppData\Local\Temp.arduinoIDE-unsaved202429-3452-1g9tsa6.m17rh\sketch_mar9a\sketch_mar9a.ino:79:3: error: 'NOTE_C1' was not declared in this scope
NOTE_C1, NOTE_G3, NOTE_G3, NOTE_A3, NOTE_G3, 0, NOTE_B3, NOTE_C4
C:\Users\Kamil\AppData\Local\Temp.arduinoIDE-unsaved202429-3452-1g9tsa6.m17rh\sketch_mar9a\sketch_mar9a.ino:79:12: error: 'NOTE_G3' was not declared in this scope
C:\Users\Kamil\AppData\Local\Temp.arduinoIDE-unsaved202429-3452-1g9tsa6.m17rh\sketch_mar9a\sketch_mar9a.ino:79:30: error: 'NOTE_A3' was not declared in this scope
C:\Users\Kamil\AppData\Local\Temp.arduinoIDE-unsaved202429-3452-1g9tsa6.m17rh\sketch_mar9a\sketch_mar9a.ino:79:51: error: 'NOTE_B3' was not declared in this scope
C:\Users\Kamil\AppData\Local\Temp.arduinoIDE-unsaved202429-3452-1g9tsa6.m17rh\sketch_mar9a\sketch_mar9a.ino:79:60: error: 'NOTE_C4' was not declared in this scope
C:\Users\Kamil\AppData\Local\Temp.arduinoIDE-unsaved202429-3452-1g9tsa6.m17rh\sketch_mar9a\sketch_mar9a.ino:88:14: error: a function-definition is not allowed here before '{' token
C:\Users\Kamil\AppData\Local\Temp.arduinoIDE-unsaved202429-3452-1g9tsa6.m17rh\sketch_mar9a\sketch_mar9a.ino:117:13: error: a function-definition is not allowed here before '{' token
exit status 1
`#include <Keypad.h> //Libraries needed
#include <virtuabotixRTC.h>
#define I2C_ADDR 0x27 //LCD i2c stuff
#define BACKLIGHT_PIN 3
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
LiquidCrystal_I2C lcd(I2C_ADDR,En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
virtuabotixRTC myRTC(2, 3, 4); //Wiring of the RTC (CLK,DAT,RST)
                               //If you change the wiring change the pins here also
const byte numRows= 4; //number of rows on the keypad
const byte numCols= 4; //number of columns on the keypad
//keymap defines the key pressed according to the row and columns just as appears on the keypad
char keymap[numRows][numCols]=
{'1', '2', '3', 'A'},
{'4', '5', '6', 'B'},
{'7', '8', '9', 'C'},
{'*', '0', '#', 'D'}
byte rowPins[numRows] = {12,11,10,9}; //Rows 0 to 3 //if you modify your pins you should modify this too
byte colPins[numCols]= {8,7,6,5}; //Columns 0 to 3
int i1,i2,i3,i4;
char c1,c2,c3,c4;
char keypressed,keypressedx;
int A_hour=NULL;
int A_minute=NULL;
int AlarmIsActive=NULL;
int buzzer = 13;
Keypad myKeypad= Keypad(makeKeymap(keymap), rowPins, colPins, numRows, numCols);
  lcd.begin (16,2); //Initialize the LCD
  lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.home ();
  while(keypressed == NO_KEY){ //As long as no key is pressed we keep showing the date and time, I'm obliged to clear the screen everytime so the numbers don't get confused
                               //And I should add that little delay so the screen shows correctly otherwise it didn't work for me
  keypressed = myKeypad.getKey();
  lcd.clear(); //Here after clearing the LCD we take the time from the module and print it on the screen with usual LCD functions
  myRTC.updateTime();
  if(myRTC.hours==A_hour && myRTC.minutes==A_minute && AlarmIsActive==1 && myRTC.seconds >= 0 && myRTC.seconds <= 2){
    while(keypressedx == NO_KEY){
    int melody[] = {
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] = {
  4, 8, 8, 4, 4, 4, 4, 4
  // iterate over the notes of the melody:
  for (int thisNote = 0; thisNote < 8; thisNote++) {
    // to calculate the note duration, take one second divided by the note type.
    //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
    int noteDuration = 1000 / noteDurations[thisNote];
    tone(8, melody[thisNote], noteDuration);
    // to distinguish the notes, set a minimum time between them.
    // the note's duration + 30% seems to work well:
    int pauseBetweenNotes = noteDuration * 1.30;
    delay(pauseBetweenNotes);
    // stop the tone playing:
    noTone(8);
  // no need to repeat the melody.
    lcd.print("Get up !!!"); //Message to show when the alarm is ringing
    keypressedx = myKeypad.getKey();
  keypressedx = NO_KEY;
  noTone(buzzer);
  lcd.setCursor(0,0);
  lcd.print(myRTC.dayofmonth);
  lcd.print("/");
  lcd.print(myRTC.month);
  lcd.print("/");
  lcd.print(myRTC.year);
  lcd.setCursor(0,1);
  lcd.print(myRTC.hours);
  lcd.print(":");
  lcd.print(myRTC.minutes);
  lcd.print(":");
  lcd.print(myRTC.seconds);
  delay(100);
         if (keypressed == '*') //As we everytime check the key pressed we only proceed to setup if we press "*"
              lcd.clear();
              lcd.print("     Setup");
              lcd.clear();
              lcd.print("Setup year");
              //So you can understand how this works, first it shows us "setup" then it prints "setup year" and now you can write your year normally (2-0-1-8)
              //It automatically passes to setting up the month...until it's finished
              //The keys from keypad are all considered chars (c) so we should convert them to int that's what I did then we store them (i)
              //We do some math and we get the year, month... as int so we can inject them to the RTC otherwise it will not be compiled
              //Months like April you should write 04, 03 for March... otherwise it will not pass to the next parameter
              //The RTC virtuabotix library is already set to not accept strange time and dates (45/17/1990) (58:90:70), and yes old dates are considered as errors
             char keypressed2 = myKeypad.waitForKey();
                    if (keypressed2 != NO_KEY && keypressed2 !='*' && keypressed2 !='#' && keypressed2 !='A' && keypressed2 !='B' && keypressed2 !='C' && keypressed2 !='D' )
                       c1 = keypressed2;
                       lcd.setCursor(0, 1);
                       lcd.print(c1);
                 char      keypressed3 = myKeypad.waitForKey();
                    if (keypressed3 != NO_KEY && keypressed3 !='*' && keypressed3 !='#' && keypressed3 !='A' && keypressed3 !='B' && keypressed3 !='C' && keypressed3 !='D' )
                       c2 = keypressed3;
                       lcd.setCursor(1, 1);
                       lcd.print(c2);
                   char  keypressed4 = myKeypad.waitForKey();
                   if (keypressed4 != NO_KEY && keypressed4 !='*' && keypressed4 !='#' && keypressed4 !='A' && keypressed4 !='B' && keypressed4 !='C' && keypressed4 !='D' )
                       c3 = keypressed4;
                       lcd.setCursor(2, 1);
                       lcd.print(c3);
                   char   keypressed5 = myKeypad.waitForKey();
                   if (keypressed5 != NO_KEY && keypressed5 !='*' && keypressed5 !='#' && keypressed5 !='A' && keypressed5 !='B' && keypressed5 !='C' && keypressed5 !='D' )
                       c4 = keypressed5;
                       lcd.setCursor(3, 1);
                       lcd.print(c4);
                     i1=(c1-48)*1000;        //the keys pressed are stored into chars I convert them to int then i did some multiplication to get the code as an int of xxxx
                     i2=(c2-48)*100;
                     i3=(c3-48)*10;
                     i4=c4-48;
                     int N_year=i1+i2+i3+i4;
                     lcd.clear();
                     lcd.print("Setup month");
                     char keypressed6 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed6 != NO_KEY && keypressed6 !='*' && keypressed6 !='#' && keypressed6 !='A' && keypressed6 !='B' && keypressed6 !='C' && keypressed6 !='D' )
                       c1 = keypressed6;
                       lcd.print(c1);
                    char   keypressed7 = myKeypad.waitForKey();
                    if (keypressed7 != NO_KEY && keypressed7 !='*' && keypressed7 !='#' && keypressed7 !='A' && keypressed7 !='B' && keypressed7 !='C' && keypressed7 !='D' )
                       c2 = keypressed7;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_month=i1+i2;
                     lcd.clear();
                     lcd.print("Setup Day");
                      char keypressed8 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed8 != NO_KEY && keypressed8 !='*' && keypressed8 !='#' && keypressed8 !='A' && keypressed8 !='B' && keypressed8 !='C' && keypressed8 !='D' )
                        c1 = keypressed8;
                       lcd.print(c1);
                      char keypressed9 = myKeypad.waitForKey();
                    if (keypressed9 != NO_KEY && keypressed9 !='*' && keypressed9 !='#' && keypressed9 !='A' && keypressed9 !='B' && keypressed9 !='C' && keypressed9 !='D' )
                        c2 = keypressed9;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_day=i1+i2;
                     lcd.clear();
                     lcd.print("Setup hour");
                     char keypressed10 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed10 != NO_KEY && keypressed10 !='*' && keypressed10 !='#' && keypressed10 !='A' && keypressed10 !='B' && keypressed10 !='C' && keypressed10 !='D' )
                       c1 = keypressed10;
                       lcd.print(c1);
                    char   keypressed11 = myKeypad.waitForKey();
                    if (keypressed11 != NO_KEY && keypressed11 !='*' && keypressed11 !='#' && keypressed11 !='A' && keypressed11 !='B' && keypressed11 !='C' && keypressed11 !='D' )
                        c2 = keypressed11;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_hour=i1+i2;
                     lcd.clear();
                     lcd.print("Setup minutes");
                    char keypressed12 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed12 != NO_KEY && keypressed12 !='*' && keypressed12 !='#' && keypressed12 !='A' && keypressed12 !='B' && keypressed12 !='C' && keypressed12 !='D' )
                        c1 = keypressed12;
                       lcd.print(c1);
                   char    keypressed13 = myKeypad.waitForKey();
                    if (keypressed13 != NO_KEY && keypressed13 !='*' && keypressed13 !='#' && keypressed13 !='A' && keypressed13 !='B' && keypressed13 !='C' && keypressed13 !='D' )
                        c2 = keypressed13;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_minutes=i1+i2;
                     lcd.clear();
                    myRTC.setDS1302Time(22, N_minutes, N_hour, 1, N_day, N_month, N_year); //once we're done setting the date and time we transfer to values to the RTC module
        //the 22 stands for seconds you can add a setup for it too if you want
        //the 1 stands for day of the week, as long I don't show it on the screen I don't change it
                    keypressed=NO_KEY; //the "*" key is stored in "keypressed" so I remove that value from it otherwise it will get me in the setup again
/////////////////////////////////////////Alarme setup/////////////////////////////////
             if (keypressed == 'A'){
              lcd.clear();
              lcd.print("  Alarm setup  ");
              lcd.clear();
              lcd.print("Set alarm hour");
               char keypressed14 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed14 != NO_KEY && keypressed14 !='*' && keypressed14 !='#' && keypressed14 !='A' && keypressed14 !='B' && keypressed14 !='C' && keypressed14 !='D' )
                       c1 = keypressed14;
                       lcd.print(c1);
                    char   keypressed15 = myKeypad.waitForKey();
                    if (keypressed15 != NO_KEY && keypressed15 !='*' && keypressed15 !='#' && keypressed15 !='A' && keypressed15 !='B' && keypressed15 !='C' && keypressed15 !='D' )
                        c2 = keypressed15;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                     A_hour=i1+i2;
                     lcd.clear();
                     lcd.print("Set alarm minutes");
                      char keypressed16 = myKeypad.waitForKey();  // here all programs are stopped until you enter the four digits then it gets compared to the code above
                    if (keypressed16 != NO_KEY && keypressed16 !='*' && keypressed16 !='#' && keypressed16 !='A' && keypressed16 !='B' && keypressed16 !='C' && keypressed16 !='D' )
                       c1 = keypressed16;
                       lcd.print(c1);
                    char   keypressed17 = myKeypad.waitForKey();
                    if (keypressed17 != NO_KEY && keypressed17 !='*' && keypressed17 !='#' && keypressed17 !='A' && keypressed17 !='B' && keypressed17 !='C' && keypressed17 !='D' )
                        c2 = keypressed17;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                     A_minute=i1+i2;
                     lcd.clear();
                      AlarmIsActive=1;
                      keypressed=NO_KEY;
             if (keypressed == 'B')
              lcd.clear();
              lcd.print("Alarm deactivated");
              AlarmIsActive=0;
              keypressed=NO_KEY;
             else {
              myRTC.updateTime();
              keypressed=NO_KEY;
Where are all those "NOTE_xx" symbols defined?
in new TAB pitches.h
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_GS2 104
#define NOTE_A2  110
#define NOTE_AS2 117
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_CS3 139
#define NOTE_D3  147
#define NOTE_DS3 156
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_FS3 185
#define NOTE_G3  196
#define NOTE_GS3 208
#define NOTE_A3  220
#define NOTE_AS3 233
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_CS4 277
#define NOTE_D4  294
#define NOTE_DS4 311
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_FS4 370
#define NOTE_G4  392
#define NOTE_GS4 415
#define NOTE_A4  440
#define NOTE_AS4 466
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_CS5 554
#define NOTE_D5  587
#define NOTE_DS5 622
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_FS5 740
#define NOTE_G5  784
#define NOTE_GS5 831
#define NOTE_A5  880
#define NOTE_AS5 932
#define NOTE_B5  988
#define NOTE_C6  1047
#define NOTE_CS6 1109
#define NOTE_D6  1175
#define NOTE_DS6 1245
#define NOTE_E6  1319
#define NOTE_F6  1397
#define NOTE_FS6 1480
#define NOTE_G6  1568
#define NOTE_GS6 1661
#define NOTE_A6  1760
#define NOTE_AS6 1865
#define NOTE_B6  1976
#define NOTE_C7  2093
#define NOTE_CS7 2217
#define NOTE_D7  2349
#define NOTE_DS7 2489
#define NOTE_E7  2637
#define NOTE_F7  2794
#define NOTE_FS7 2960
#define NOTE_G7  3136
#define NOTE_GS7 3322
#define NOTE_A7  3520
#define NOTE_AS7 3729
#define NOTE_B7  3951
#define NOTE_C8  4186
#define NOTE_CS8 4435
#define NOTE_D8  4699
#define NOTE_DS8 4978
where is the line to include the pitches.h file?
#include "pitches.h"
i add it and i noticet that i have not enought };
Now i'm on
C:\Users\Kamil\AppData\Local\Temp\ccFVPkmX.ltrans0.ltrans.o: In function main': C:\Users\Kamil\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\cores\arduino/main.cpp:43: undefined reference to setup'
collect2.exe: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
My code now looks like this
#define En_pin 2
#define Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define D6_pin 6
#define D7_pin 7
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_A2  110
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_D3  147
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_G3  196
#define NOTE_A3  220
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_D4  294
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_G4  392
#define NOTE_A4  440
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_D5  587
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_G5  784
#define NOTE_A5  880
#define NOTE_B5  988
int i1,i2,i3,i4;
char c1,c2,c3,c4;
int A_hour=NULL;
int A_minute=NULL;
int buzzer = 13;
void setup_lcd() {
  lcd.home ();
  myRTC.updateTime();
    int melody[] = {
void setup_notes() {
    noTone(8);
void loop2() {
  noTone(buzzer);
  lcd.setCursor(0,0);
  lcd.print("/");
  lcd.print("/");
  lcd.setCursor(0,1);
  lcd.print(":");
  lcd.print(":");
  delay(100);
              lcd.clear();
              lcd.clear();
                       c1 = keypressed2;
                       lcd.print(c1);
                       c2 = keypressed3;
                       lcd.print(c2);
                       c3 = keypressed4;
                       lcd.print(c3);
                       c4 = keypressed5;
                       lcd.print(c4);
                     i2=(c2-48)*100;
                     i3=(c3-48)*10;
                     i4=c4-48;
                     lcd.clear();
                       c1 = keypressed6;
                       lcd.print(c1);
                       c2 = keypressed7;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_month=i1+i2;
                     lcd.clear();
                        c1 = keypressed8;
                       lcd.print(c1);
                        c2 = keypressed9;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_day=i1+i2;
                     lcd.clear();
                       c1 = keypressed10;
                       lcd.print(c1);
                        c2 = keypressed11;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_hour=i1+i2;
                     lcd.clear();
                        c1 = keypressed12;
                       lcd.print(c1);
                        c2 = keypressed13;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                     lcd.clear();
              lcd.clear();
              lcd.clear();
                       c1 = keypressed14;
                       lcd.print(c1);
                        c2 = keypressed15;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                     A_hour=i1+i2;
                     lcd.clear();
                       c1 = keypressed16;
                       lcd.print(c1);
                        c2 = keypressed17;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                     A_minute=i1+i2;
                     lcd.clear();
                      AlarmIsActive=1;
                      keypressed=NO_KEY;
              lcd.clear();
              AlarmIsActive=0;
              keypressed=NO_KEY;
             else {
              myRTC.updateTime();
              keypressed=NO_KEY;
your compiler is right.
Where is setup()?
furthermore, press CTRL-T to format your sketch. You will see the errors in your }
It disappeared from Post #1. : (
there can't be 2 of theme
there should be one setup.
your code in #5 has none.
I combine two codes into one. However, I still don't know how. I have errors. Maybe one of you will know how to do it.
Below are these two codes
//This code is to use with DS1302 RTC module + 4*4 Keypad + LCD i2c +  Arduino + Buzzer
//After wiring the modules, the LCD will show the default date  and time or the one set before
//The objective of this project is that you can  set the RTC module from the keypad, and sure it will stay stored
//Then show  it on the screen and after you can set your alarm.
//Refer to Surtrtech.com or  SurtrTech youtube channel for more information
#include <Wire.h>
#define En_pin 2
#define  Rw_pin 1
#define Rs_pin 0
#define D4_pin 4
#define D5_pin 5
#define  D6_pin 6
#define D7_pin 7
int i1,i2,i3,i4;
char c1,c2,c3,c4;
int  A_hour=NULL;
int A_minute=NULL;
int buzzer  = 13;
  lcd.home ();
void  loop() {
  myRTC.updateTime();
    tone(buzzer, 1000); //You can modify the tone or make your own  sound
    delay(100);
    tone(buzzer, 2000);
    delay(100);
    lcd.clear();
  noTone(buzzer);
  lcd.setCursor(0,0);
  lcd.print("/");
  lcd.print("/");
  lcd.setCursor(0,1);
  lcd.print(":");
  lcd.print(":");
  delay(100);
              lcd.clear();
              lcd.clear();
                       c1 = keypressed2;
                       lcd.print(c1);
                       c2 = keypressed3;
                       lcd.print(c2);
                       c3 = keypressed4;
                       lcd.print(c3);
                       c4 = keypressed5;
                       lcd.print(c4);
                     i2=(c2-48)*100;
                     i3=(c3-48)*10;
                     i4=c4-48;
                     lcd.clear();
                       c1 = keypressed6;
                       lcd.print(c1);
                       c2 = keypressed7;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_month=i1+i2;
                     lcd.clear();
                        c1  = keypressed8;
                       lcd.print(c1);
                        c2 = keypressed9;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_day=i1+i2;
                     lcd.clear();
                       c1  = keypressed10;
                       lcd.print(c1);
                        c2 = keypressed11;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                    int N_hour=i1+i2;
                     lcd.clear();
                        c1 = keypressed12;
                       lcd.print(c1);
                        c2 = keypressed13;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                     lcd.clear();
              lcd.clear();
              lcd.clear();
                       c1  = keypressed14;
                       lcd.print(c1);
                        c2 = keypressed15;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                     A_hour=i1+i2;
                     lcd.clear();
                       c1 = keypressed16;
                       lcd.print(c1);
                        c2 = keypressed17;
                       lcd.print(c2);
                     i1=(c1-48)*10;
                     i2=c2-48;
                     A_minute=i1+i2;
                     lcd.clear();
                      AlarmIsActive=1;
                      keypressed=NO_KEY;
              lcd.clear();
              AlarmIsActive=0;
              keypressed=NO_KEY;
             else {
              myRTC.updateTime();
              keypressed=NO_KEY;
second one
  Imperial March - Star Wars
  Connect a piezo buzzer or speaker to pin 11 or select a new pin.
  More songs available at https://github.com/robsoncouto/arduino-songs
                                              Robson Couto, 2019
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_A2  110
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_D3  147
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_G3  196
#define NOTE_A3  220
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_D4  294
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_G4  392
#define NOTE_A4  440
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_D5  587
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_G5  784
#define NOTE_A5  880
#define NOTE_B5  988
#define REST      0
// change this to make the song slower or faster
int tempo = 120;
// change this to whichever pin you want to use
int buzzer = 11;
// notes of the moledy followed by the duration.
// a 4 means a quarter note, 8 an eighteenth , 16 sixteenth, so on
// !!negative numbers are used to represent dotted notes,
// so -4 means a dotted quarter note, that is, a quarter plus an eighteenth!!
int melody[] = {
  // Dart Vader theme (Imperial March) - Star wars
  // Score available at https://musescore.com/user/202909/scores/1141521
  // The tenor saxophone part was used
  NOTE_A4,-4, NOTE_A4,-4, NOTE_A4,16, NOTE_A4,16, NOTE_A4,16, NOTE_A4,16, NOTE_F4,8, REST,8,
  NOTE_A4,4, NOTE_A4,4, NOTE_A4,4, NOTE_F4,-8, NOTE_C5,16,
  NOTE_A4,4, NOTE_F4,-8, NOTE_C5,16, NOTE_A4,2,//4
  NOTE_E5,4, NOTE_E5,4, NOTE_E5,4, NOTE_F5,-8, NOTE_C5,16,
  NOTE_A5,4, NOTE_A4,-8, NOTE_A4,16, NOTE_A5,4, NOTE_GS5,-8, NOTE_G5,16, //7
  NOTE_DS5,16, NOTE_D5,16, NOTE_DS5,8, REST,8, NOTE_A4,8, NOTE_DS5,4, NOTE_D5,-8, NOTE_CS5,16,
  NOTE_C5,16, NOTE_B4,16, NOTE_C5,16, REST,8, NOTE_F4,8, NOTE_GS4,4, NOTE_F4,-8, NOTE_A4,-16,//9
  NOTE_C5,4, NOTE_A4,-8, NOTE_C5,16, NOTE_E5,2,
// sizeof gives the number of bytes, each int value is composed of two bytes (16 bits)
// there are two values per note (pitch and duration), so for each note there are four bytes
int notes = sizeof(melody) / sizeof(melody[0]) / 2;
// this calculates the duration of a whole note in ms
int wholenote = (60000 * 4) / tempo;
int divider = 0, noteDuration = 0;
  // iterate over the notes of the melody.
  // Remember, the array is twice the number of notes (notes + durations)
  for (int thisNote = 0; thisNote < notes * 2; thisNote = thisNote + 2) {
    // calculates the duration of each note
    divider = melody[thisNote + 1];
    if (divider > 0) {
      // regular note, just proceed
      noteDuration = (wholenote) / divider;
    } else if (divider < 0) {
      // dotted notes are represented with negative durations!!
      noteDuration = (wholenote) / abs(divider);
      noteDuration *= 1.5; // increases the duration in half for dotted notes
    // we only play the note for 90% of the duration, leaving 10% as a pause
    tone(buzzer, melody[thisNote], noteDuration*0.9);
    // Wait for the specief duration before playing the next note.
    delay(noteDuration);
    // stop the waveform generation before the next note.
    noTone(buzzer);
i want to change sound to the one above
delay(100);
tone(buzzer, 2000);
delay(100);
lcd.clear();
