VectorFontROM.h
VectorFontROM.h
Created on: Jul 13, 2017
Author: EdAndrews
This is a vector stroke font data file for use with the XYscope library. The FontROM
data structure (below) to specify graphics elements, coordinates, and graphic feature parameters.
Each character is defined using graphics primatives within a 16x16 XY coordinate
character cell. Graphics "Opcode" primatives define NOP, POINT, LINE, CIRCLE, ELLIPSE, & RECTANGLE
features that are used to "plot the character" into the XY point list. Coordinate &
Radius values are held as 4-bit (0-15) values, double packed two to a byte.
Lines & Rectangles (Opcodes LIN & REC) are defined by corner end points.
Variable [P1]: Defines the feature start point (x0,y0)
Variable [P2]: Defines the feature end point (x1,y1)
Variable [P3]: Not used
Circles & Arcs (Opcode CIR) are defined by a center coordinate, feature radius, & segment flag.
Variable [P1]: Defines the circlular feature center point (x),y0)
Variable [P2]: Defines the circle radius (radius).
Variable [P3]: Defines the 'segment' flag bits.
By setting bits within the segment flag to 1, whole or partial circlular features can be plotted.
When segment bits are set to 1 (value=255), a full circle is drawn.
Ellipses (Opcode ELP) are defined by a center coordinate, feature radius, & segment flag.
Variable [P1]: Defines the ellipse feature center point (x0,y0),
Variable [P2]: Defines the ellipse X & Y radius values (x_radius,y_radius).
By setting bits within the segment flag to 1, whole or partial ellipical features can be plotted.
When segment bits are set to 1 (value=255), a full ellipse is drawn.
A cross reference array, (Ascii2font[]) is used as a pointer to the Starting primative
to each character.
Since the graphical definition of a given character varies based on the graphics complexity required
to draw the symbol, the MSB of the Opcode is used as an End-Of-Character (EOC) flag bit. When EOC is set,
the character plotting routine that is scanning and executing the graphics primatives stops when it sees
the EOC bit set.
#ifndef VECTORFONTROM_H_
#define VECTORFONTROM_H_
//Define Stroke_Font EOC (End_Of_Character) flag.
//This flag tells plotChar when the end of a character in the FontROM has been reached (time to plotting data for the current character)
uint8_t const EOC = 0x80; //End of Character Flag (hi-order bit=1)
//Define Stroke_Font OpCodes (with EOC flag NOT SET); These codes are used within the FontROM data structure and which is the core of the plotChar routine
uint8_t const NOP = 0x0, PNT = 0x1, LIN = 0x2, REC = 0x3, CIR = 0x4, ELP = 0x5; //NOP = No Operation, PNT = plot a single POINT, LIN = Plot a LINE
//REC = Plot a Rectangle, CIR = Plot a fully closed Cirecle or just some circular segment(s)
//ELP = Plot a fully closed Ellipse or just some ellipical segment(s).
//Define Stroke_Font OpCodes with EOC flag SET (Opcodes OR EOC_Flag)
uint8_t const NOP_E = NOP | EOC, PNT_E = PNT | EOC, LIN_E = LIN | EOC, REC_E =
REC | EOC, CIR_E = CIR | EOC, ELP_E = ELP | EOC;
//This is the structure definition for the FontROM lookup table
struct FontROM {
uint8_t Opcode; //D7 = EOC Flag, D0-4 = Stroke Font Code (ie: NOP,Point,Line,Circle,Elipse,Rectangle, etc)
uint8_t P1; //D4-7= x0, D0-3= y0
uint8_t P2; //For LINE & RECT: D4-7= x1, D0-3= y1 For CIR & ELP: D4-7= radius_X, for ELP: D0-3= radius_Y
uint8_t P3; //for CIR & ELP (not used for others); D0-7 = Segment Flags.
// When a SegmentFlag is set to 1, plot the segment; when set to 0, do not plot (skip) the segment
FontROM DigitFont[280] PROGMEM= {
{ NOP_E,0x0,0x0,0x00}, // ASCII: 32 SP (Space)
{ LIN ,0x2E,0x28,0x00}, // ASCII: 33 ! (Exclamation mark)
{ CIR_E,0x25,0x11,0xFF}, // ASCII: 33 ! (Exclamation mark)
{ LIN ,0x2D,0x2B,0x00}, // ASCII: 34 " (Quotation mark (" in HTML))
{ LIN_E,0x4D,0x4B,0x00}, // ASCII: 34 " (Quotation mark (" in HTML))
{ LIN ,0x3D,0x26,0x3E}, // ASCII: 35 # (Cross hatch (number sign))
{ LIN ,0x5D,0x46,0x7C}, // ASCII: 35 # (Cross hatch (number sign))
{ LIN ,0x1B,0x6B,0x00}, // ASCII: 35 # (Cross hatch (number sign))
{ LIN_E,0x18,0x68,0x00}, // ASCII: 35 # (Cross hatch (number sign))
{ CIR ,0x3B,0x22,0xC7}, // ASCII: 36 $ (Dollar sign)
{ CIR ,0x37,0x22,0x7C}, // ASCII: 36 $ (Dollar sign)
{ LIN_E,0x3E,0x34,0x00}, // ASCII: 36 $ (Dollar sign)
{ LIN ,0x6E,0x14,0xFC}, // ASCII: 37 % (Percent sign)
{ CIR ,0x2C,0x11,0xFF}, // ASCII: 37 % (Percent sign)
{ CIR_E,0x55,0x11,0xFF}, // ASCII: 37 % (Percent sign)
{ CIR ,0x3C,0x11,0x4F}, // ASCII: 38 & (Ampersand)
{ CIR ,0x37,0x22,0xE1}, // ASCII: 38 & (Ampersand)
{ LIN ,0x65,0x2B,0x00}, // ASCII: 38 & (Ampersand)
{ LIN ,0x4B,0x18,0x00}, // ASCII: 38 & (Ampersand)
{ LIN_E,0x56,0x67,0x00}, // ASCII: 38 & (Ampersand)
{ LIN_E,0x2D,0x2B,0x80}, // ASCII: 39 ` (Closing single quote (apostrophe))
{ ELP_E,0x39,0x25,0xC3}, // ASCII: 40 ( (Opening parentheses)
{ ELP_E,0x19,0x25,0x3C}, // ASCII: 41 ) (Closing parentheses)
{ LIN ,0x19,0x79,0x00}, // ASCII: 42 * (Asterisk (star, multiply))
{ LIN ,0x27,0x6B,0x00}, // ASCII: 42 * (Asterisk (star, multiply))
{ LIN ,0x46,0x4C,0x00}, // ASCII: 42 * (Asterisk (star, multiply))
{ LIN_E,0x2B,0x67,0x00}, // ASCII: 42 * (Asterisk (star, multiply))
{ LIN ,0x19,0x79,0x00}, // ASCII: 43 + (Plus)
{ LIN_E,0x46,0x4C,0x00}, // ASCII: 43 + (Plus)
{ CIR ,0x25,0x11,0xFF}, // ASCII: 44 , (Comma)
{ ELP_E,0x25,0x13,0x30}, // ASCII: 44 , (Comma)
{ LIN_E,0x19,0x79,0x00}, // ASCII: 45 - (Hyphen, dash, minus)
{ CIR_E,0x35,0x11,0xFF}, // ASCII: 46 . (Period)
{ LIN_E,0x6E,0x14,0x00}, // ASCII: 47 / (Slant (forward slash, divide))
{ ELP ,0x49,0x35,0xFF}, // ASCII: 48 0 (Zero)
{ LIN_E,0x14,0x7E,0x00}, // ASCII: 48 0 (Zero)
{ LIN ,0x2C,0x4E,0x00}, // ASCII: 49 1 (One)
{ LIN ,0x4E,0x44,0x00}, // ASCII: 49 1 (One)
{ LIN_E,0x24,0x64,0x00}, // ASCII: 49 1 (One)
{ ELP ,0x3C,0x22,0x03}, // ASCII: 50 2 (Two)
{ ELP ,0x4C,0x22,0x1C}, // ASCII: 50 2 (Two)
{ LIN ,0x3E,0x4E,0x00}, // ASCII: 50 2 (Two)
{ LIN ,0x6B,0x15,0x00}, // ASCII: 50 2 (Two)
{ ELP ,0x34,0x22,0x01}, // ASCII: 50 2 (Two)
{ LIN_E,0x14,0x64,0x00}, // ASCII: 50 2 (Two)
{ ELP ,0x3C,0x22,0x3E}, // ASCII: 51 3 (Three)
{ ELP_E,0x37,0x33,0x7C}, // ASCII: 51 3 (Three)
{ LIN ,0x54,0x5E,0x00}, // ASCII: 52 4 (Four)
{ LIN ,0x5E,0x18,0x00}, // ASCII: 52 4 (Four)
{ LIN_E,0x18,0x68,0x00}, // ASCII: 52 4 (Four)
{ ELP ,0x47,0x33,0xFC}, // ASCII: 53 5 (Five)
{ LIN ,0x4A,0x2A,0x00}, // ASCII: 53 5 (Five)
{ LIN ,0x2A,0x3E,0x00}, // ASCII: 53 5 (Five)
{ LIN_E,0x3E,0x7E,0x00}, // ASCII: 53 5 (Five)
{ ELP ,0x47,0x33,0xFF}, // ASCII: 54 6 (Six)
{ LIN_E,0x29,0x5E,0x00}, // ASCII: 54 6 (Six)
{ LIN ,0x24,0x7E,0x00}, // ASCII: 55 7 (Seven)
{ LIN_E,0x7E,0x1E,0x00}, // ASCII: 55 7 (Seven)
{ ELP ,0x47,0x33,0xFF}, // ASCII: 56 8 (Eight)
{ ELP_E,0x4C,0x22,0xFF}, // ASCII: 56 8 (Eight)
{ ELP ,0x4B,0x33,0xFF}, // ASCII: 57 9 (Nine)
{ LIN_E,0x7A,0x44,0x00}, // ASCII: 57 9 (Nine)
{ CIR ,0x3B,0x11,0xFF}, // ASCII: 58 : (Colon)
{ CIR_E,0x37,0x11,0xFF}, // ASCII: 58 : (Colon)
{ CIR ,0x3B,0x11,0xFF}, // ASCII: 59 ; (Semicolon)
{ CIR ,0x37,0x11,0xFF}, // ASCII: 59 ; (Semicolon)
{ LIN_E,0x46,0x34,0x01}, // ASCII: 59 ; (Semicolon)
{ LIN ,0x19,0x4C,0x00}, // ASCII: 60 < (Less than sign (< in HTML))
{ LIN_E,0x19,0x46,0x00}, // ASCII: 60 < (Less than sign (< in HTML))
{ LIN ,0x1A,0x5A,0x00}, // ASCII: 61 = (Equals sign)
{ LIN_E,0x17,0x57,0x00}, // ASCII: 61 = (Equals sign)
{ LIN ,0x1C,0x49,0x00}, // ASCII: 62 > (Greater than sign (> in HTML))
{ LIN_E,0x16,0x49,0x00}, // ASCII: 62 > (Greater than sign (> in HTML))
{ CIR ,0x3C,0x22,0x3F}, // ASCII: 63 ? (Question mark)
{ LIN ,0x3A,0x38,0x00}, // ASCII: 63 ? (Question mark)
{ CIR_E,0x35,0x11,0xFF}, // ASCII: 63 ? (Question mark)
{ ELP ,0x49,0x35,0xCF}, // ASCII: 64 @ (At-sign)
{ LIN ,0x44,0x74,0x00}, // ASCII: 64 @ (At-sign)
{ ELP ,0x4A,0x12,0xC7}, // ASCII: 64 @ (At-sign)
{ LIN ,0x5B,0x58,0x00}, // ASCII: 64 @ (At-sign)
{ ELP_E,0x59,0x21,0x70}, // ASCII: 64 @ (At-sign)
{ LIN ,0x14,0x4E,0x00}, // ASCII: 65 A (Uppercase A)
{ LIN ,0x4E,0x74,0x00}, // ASCII: 65 A (Uppercase A)
{ LIN_E,0x38,0x58,0x00}, // ASCII: 65 A (Uppercase A)
{ LIN ,0x34,0x14,0x00}, // ASCII: 66 B (Uppercase B)
{ LIN ,0x14,0x1E,0x00}, // ASCII: 66 B (Uppercase B)
{ LIN ,0x1A,0x3A,0x00}, // ASCII: 66 B (Uppercase B)
{ LIN ,0x1E,0x3E,0x00}, // ASCII: 66 B (Uppercase B)
{ CIR ,0x3C,0x22,0x3C}, // ASCII: 66 B (Uppercase B)
{ CIR_E,0x37,0x33,0x3C}, // ASCII: 66 B (Uppercase B)
{ ELP_E,0x49,0x35,0xE7}, // ASCII: 67 C (Uppercase C)
{ LIN ,0x34,0x14,0xFF}, // ASCII: 68 D (Uppercase D)
{ LIN ,0x14,0x1E,0x00}, // ASCII: 68 D (Uppercase D)
{ LIN ,0x1E,0x3E,0x00}, // ASCII: 68 D (Uppercase D)
{ ELP_E,0x39,0x35,0x3C}, // ASCII: 68 D (Uppercase D)
{ LIN ,0x6E,0x1E,0x00}, // ASCII: 69 E (Uppercase E)
{ LIN ,0x1E,0x14,0x00}, // ASCII: 69 E (Uppercase E)
{ LIN ,0x19,0x49,0x00}, // ASCII: 69 E (Uppercase E)
{ LIN_E,0x14,0x64,0x00}, // ASCII: 69 E (Uppercase E)
{ LIN ,0x6E,0x1E,0x00}, // ASCII: 70 F (Uppercase F)
{ LIN ,0x1E,0x14,0x00}, // ASCII: 70 F (Uppercase F)
{ LIN_E,0x19,0x49,0x00}, // ASCII: 70 F (Uppercase F)
{ LIN ,0x58,0x68,0x00}, // ASCII: 71 G (Uppercase G)
{ LIN ,0x68,0x64,0x00}, // ASCII: 71 G (Uppercase G)
{ ELP_E,0x49,0x35,0xE7}, // ASCII: 71 G (Uppercase G)
{ LIN ,0x1E,0x14,0x00}, // ASCII: 72 H (Uppercase H)
{ LIN ,0x6E,0x64,0x00}, // ASCII: 72 H (Uppercase H)
{ LIN_E,0x19,0x69,0x00}, // ASCII: 72 H (Uppercase H)
{ LIN ,0x3E,0x34,0x00}, // ASCII: 73 I (Uppercase I)
{ LIN ,0x1E,0x5E,0x00}, // ASCII: 73 I (Uppercase I)
{ LIN_E,0x14,0x54,0x00}, // ASCII: 73 I (Uppercase I)
{ CIR ,0x36,0x22,0xF0}, // ASCII: 74 J (Uppercase J)
{ LIN ,0x56,0x5E,0x00}, // ASCII: 74 J (Uppercase J)
{ LIN_E,0x3E,0x6E,0x00}, // ASCII: 74 J (Uppercase J)
{ LIN ,0x14,0x1E,0x00}, // ASCII: 75 K (Uppercase K)
{ LIN ,0x64,0x19,0x00}, // ASCII: 75 K (Uppercase K)
{ LIN_E,0x6E,0x19,0x00}, // ASCII: 75 K (Uppercase K)
{ LIN ,0x64,0x14,0x00}, // ASCII: 76 L (Uppercase L)
{ LIN_E,0x14,0x1E,0x00}, // ASCII: 76 L (Uppercase L)
{ LIN ,0x14,0x1E,0x00}, // ASCII: 77 M (Uppercase M)
{ LIN ,0x74,0x7E,0x00}, // ASCII: 77 M (Uppercase M)
{ LIN ,0x1E,0x47,0x00}, // ASCII: 77 M (Uppercase M)
{ LIN_E,0x47,0x7E,0x00}, // ASCII: 77 M (Uppercase M)
{ LIN ,0x14,0x1E,0x00}, // ASCII: 78 N (Uppercase N)
{ LIN ,0x6E,0x64,0x00}, // ASCII: 78 N (Uppercase N)
{ LIN_E,0x1E,0x64,0x00}, // ASCII: 78 N (Uppercase N)
{ ELP_E,0x49,0x35,0xFF}, // ASCII: 79 O (Uppercase O)
{ LIN ,0x14,0x1E,0x00}, // ASCII: 80 P (Uppercase P)
{ LIN ,0x19,0x49,0x00}, // ASCII: 80 P (Uppercase P)
{ LIN ,0x1E,0x4E,0x00}, // ASCII: 80 P (Uppercase P)
{ LIN ,0x6C,0x6A,0x3C}, // ASCII: 80 P (Uppercase P)
{ CIR ,0x4C,0x22,0xC}, // ASCII: 80 P (Uppercase P)
{ CIR_E,0x4B,0x22,0x30}, // ASCII: 80 P (Uppercase P)
{ ELP ,0x49,0x35,0xFF}, // ASCII: 81 Q (Uppercase Q)
{ LIN_E,0x56,0x74,0x00}, // ASCII: 81 Q (Uppercase Q)
{ LIN ,0x14,0x1E,0x00}, // ASCII: 82 R (Uppercase R)
{ LIN ,0x19,0x49,0x00}, // ASCII: 82 R (Uppercase R)
{ LIN ,0x1E,0x4E,0x00}, // ASCII: 82 R (Uppercase R)
{ LIN ,0x6C,0x6A,0x3C}, // ASCII: 82 R (Uppercase R)
{ CIR ,0x4C,0x22,0xC}, // ASCII: 82 R (Uppercase R)
{ CIR ,0x4B,0x22,0x30}, // ASCII: 82 R (Uppercase R)
{ LIN_E,0x49,0x64,0x00}, // ASCII: 82 R (Uppercase R)
{ CIR ,0x4C,0x22,0xC7}, // ASCII: 83 S (Uppercase S)
{ CIR_E,0x47,0x33,0x7C}, // ASCII: 83 S (Uppercase S)
{ LIN ,0x44,0x4E,0x00}, // ASCII: 84 T (Uppercase T)
{ LIN ,0x1E,0x4E,0x00}, // ASCII: 84 T (Uppercase T)
{ LIN_E,0x7E,0x4E,0x00}, // ASCII: 84 T (Uppercase T)
{ CIR ,0x47,0x33,0xF0}, // ASCII: 85 U (Uppercase U)
{ LIN ,0x1E,0x17,0x00}, // ASCII: 85 U (Uppercase U)
{ LIN_E,0x7E,0x77,0x00}, // ASCII: 85 U (Uppercase U)
{ LIN ,0x1E,0x44,0x00}, // ASCII: 86 V (Uppercase V)
{ LIN_E,0x44,0x7E,0x00}, // ASCII: 86 V (Uppercase V)
{ LIN ,0x1E,0x34,0x00}, // ASCII: 87 W (Uppercase W)
{ LIN ,0x34,0x5A,0x00}, // ASCII: 87 W (Uppercase W)
{ LIN ,0x5A,0x74,0x00}, // ASCII: 87 W (Uppercase W)
{ LIN_E,0x74,0x9E,0x00}, // ASCII: 87 W (Uppercase W)
{ LIN ,0x1E,0x74,0x00}, // ASCII: 88 X (Uppercase X)
{ LIN_E,0x14,0x7E,0x00}, // ASCII: 88 X (Uppercase X)
{ LIN ,0x1E,0x49,0x00}, // ASCII: 89 Y (Uppercase Y)
{ LIN ,0x7E,0x49,0x00}, // ASCII: 89 Y (Uppercase Y)
{ LIN_E,0x44,0x49,0x00}, // ASCII: 89 Y (Uppercase Y)
{ LIN ,0x1E,0x7E,0x00}, // ASCII: 90 Z (Uppercase Z)
{ LIN ,0x7E,0x14,0x00}, // ASCII: 90 Z (Uppercase Z)
{ LIN_E,0x14,0x74,0x00}, // ASCII: 90 Z (Uppercase Z)
{ LIN ,0x1E,0x14,0x00}, // ASCII: 91 [ (Opening square bracket)
{ LIN ,0x1E,0x3e,0x00}, // ASCII: 91 [ (Opening square bracket)
{ LIN_E,0x14,0x34,0x00}, // ASCII: 91 [ (Opening square bracket)
{ LIN_E,0x1E,0x64,0x00}, // ASCII: 92 \ (Reverse slant (Backslash))
{ LIN ,0x3E,0x34,0x00}, // ASCII: 93 ] (Closing square bracket)
{ LIN ,0x1E,0x3E,0x00}, // ASCII: 93 ] (Closing square bracket)
{ LIN_E,0x14,0x34,0x00}, // ASCII: 93 ] (Closing square bracket)
{ LIN ,0x19,0x3D,0x00}, // ASCII: 94 ^ (Caret (Circumflex))
{ LIN_E,0x3D,0x59,0x00}, // ASCII: 94 ^ (Caret (Circumflex))
{ LIN_E,0x2,0x72,0x00}, // ASCII: 95 _ (Underscore)
{ LIN_E,0x2D,0x4B,0x00}, // ASCII: 96 ` (Opening single quote)
{ ELP ,0x37,0x23,0xFF}, // ASCII: 97 a (Lowercase a)
{ LIN_E,0x57,0x54,0x00}, // ASCII: 97 a (Lowercase a)
{ ELP ,0x37,0x23,0xFF}, // ASCII: 98 b (Lowercase b)
{ LIN_E,0x1E,0x14,0x00}, // ASCII: 98 b (Lowercase b)
{ ELP_E,0x37,0x23,0xE7}, // ASCII: 99 c (Lowercase c)
{ ELP ,0x37,0x23,0xFF}, // ASCII: 100 d (Lowercase d)
{ LIN_E,0x5E,0x54,0x00}, // ASCII: 100 d (Lowercase d)
{ ELP ,0x37,0x23,0xEF}, // ASCII: 101 e (Lowercase e)
{ LIN_E,0x17,0x57,0x00}, // ASCII: 101 e (Lowercase e)
{ CIR ,0x4C,0x22,0x07}, // ASCII: 102 f (Lowercase f)
{ LIN ,0x19,0x49,0x00}, // ASCII: 102 f (Lowercase f)
{ LIN_E,0x24,0x2c,0x00}, // ASCII: 102 f (Lowercase f)
{ ELP ,0x37,0x23,0xFF}, // ASCII: 103 g (Lowercase g)
{ LIN ,0x56,0x52,0x00}, // ASCII: 103 g (Lowercase g)
{ CIR_E,0x32,0x22,0x70}, // ASCII: 103 g (Lowercase g)
{ LIN ,0x1E,0x14,0x00}, // ASCII: 104 h (Lowercase h)
{ ELP ,0x38,0x22,0xF}, // ASCII: 104 h (Lowercase h)
{ LIN_E,0x58,0x54,0x00}, // ASCII: 104 h (Lowercase h)
{ CIR ,0x2C,0x11,0xFF}, // ASCII: 105 i (Lowercase i)
{ LIN_E,0x24,0x29,0x00}, // ASCII: 105 i (Lowercase i)
{ CIR ,0x3C,0x11,0xFF}, // ASCII: 106 j (Lowercase j)
{ LIN ,0x39,0x33,0x00}, // ASCII: 106 j (Lowercase j)
{ CIR_E,0x13,0x22,0x30}, // ASCII: 106 j (Lowercase j)
{ LIN ,0x1E,0x14,0x00}, // ASCII: 107 k (Lowercase k)
{ LIN ,0x17,0x5A,0x00}, // ASCII: 107 k (Lowercase k)
{ LIN_E,0x54,0x38,0x00}, // ASCII: 107 k (Lowercase k)
{ LIN ,0x1E,0x15,0x00}, // ASCII: 108 l (Lowercase l)
{ LIN_E,0x24,0x15,0x00}, // ASCII: 108 l (Lowercase l)
{ LIN ,0x0A,0x4,0x00}, // ASCII: 109 m (Lowercase m)
{ LIN ,0x44,0x48,0x00}, // ASCII: 109 m (Lowercase m)
{ LIN ,0x84,0x88,0x00}, // ASCII: 109 m (Lowercase m)
{ CIR ,0x28,0x22,0xF}, // ASCII: 109 m (Lowercase m)
{ CIR_E,0x68,0x22,0xF}, // ASCII: 109 m (Lowercase m)
{ LIN ,0x1A,0x14,0x00}, // ASCII: 110 n (Lowercase n)
{ LIN ,0x54,0x58,0x00}, // ASCII: 110 n (Lowercase n)
{ CIR_E,0x38,0x22,0xF}, // ASCII: 110 n (Lowercase n)
{ ELP_E,0x37,0x23,0xFF}, // ASCII: 111 o (Lowercase o)
{ ELP ,0x37,0x23,0xFF}, // ASCII: 112 p (Lowercase p)
{ LIN_E,0x18,0x10,0x00}, // ASCII: 112 p (Lowercase p)
{ ELP ,0x37,0x23,0xFF}, // ASCII: 113 q (Lowercase q)
{ LIN_E,0x58,0x50,0x00}, // ASCII: 113 q (Lowercase q)
{ ELP ,0x37,0x23,0x07}, // ASCII: 114 r (Lowercase r)
{ LIN_E,0x1A,0x14,0x00}, // ASCII: 114 r (Lowercase r)
{ ELP ,0x39,0x21,0xC7}, // ASCII: 115 s (Lowercase s)
{ CIR_E,0x36,0x22,0x7C}, // ASCII: 115 s (Lowercase s)
{ LIN ,0x3E,0x35,0xE3}, // ASCII: 116 t (Lowercase t)
{ LIN ,0x1B,0x5B,0x3E}, // ASCII: 116 t (Lowercase t)
{ CIR_E,0x45,0x11,0xC0}, // ASCII: 116 t (Lowercase t)
{ LIN ,0x1A,0x16,0x00}, // ASCII: 117 u (Lowercase u)
{ LIN ,0x5A,0x54,0x00}, // ASCII: 117 u (Lowercase u)
{ CIR_E,0x36,0x22,0xF0}, // ASCII: 117 u (Lowercase u)
{ LIN ,0x1A,0x34,0xF}, // ASCII: 118 v (Lowercase v)
{ LIN_E,0x5A,0x34,0x00}, // ASCII: 118 v (Lowercase v)
{ LIN ,0x1A,0x34,0x00}, // ASCII: 119 w (Lowercase w)
{ LIN ,0x5A,0x34,0x00}, // ASCII: 119 w (Lowercase w)
{ LIN ,0x5A,0x74,0x00}, // ASCII: 119 w (Lowercase w)
{ LIN_E,0x9A,0x74,0x00}, // ASCII: 119 w (Lowercase w)
{ LIN ,0x1A,0x54,0x00}, // ASCII: 120 x (Lowercase x)
{ LIN_E,0x14,0x5A,0x00}, // ASCII: 120 x (Lowercase x)
{ LIN ,0x1A,0x34,0x00}, // ASCII: 121 y (Lowercase y)
{ LIN_E,0x5A,0x21,0x00}, // ASCII: 121 y (Lowercase y)
{ LIN ,0x1A,0x4A,0x00}, // ASCII: 122 z (Lowercase z)
{ LIN ,0x4A,0x14,0x00}, // ASCII: 122 z (Lowercase z)
{ LIN_E,0x14,0x44,0x00}, // ASCII: 122 z (Lowercase z)
{ CIR ,0x3D,0x11,0x03}, // ASCII: 123 { (Opening curly brace)
{ LIN ,0x2D,0x2A,0x30}, // ASCII: 123 { (Opening curly brace)
{ CIR ,0x1A,0x11,0x30}, // ASCII: 123 { (Opening curly brace)
{ CIR ,0x18,0x11,0xC}, // ASCII: 123 { (Opening curly brace)
{ LIN ,0x28,0x25,0x00}, // ASCII: 123 { (Opening curly brace)
{ CIR_E,0x35,0x11,0xC0}, // ASCII: 123 { (Opening curly brace)
{ LIN_E,0x2E,0x24,0x00}, // ASCII: 124 | (Vertical line)
{ CIR ,0x1D,0x11,0xC}, // ASCII: 125 } (Closing curly brace)
{ LIN ,0x2D,0x2A,0x00}, // ASCII: 125 } (Closing curly brace)
{ CIR ,0x3A,0x11,0xC0}, // ASCII: 125 } (Closing curly brace)
{ CIR ,0x38,0x11,0x03}, // ASCII: 125 } (Closing curly brace)
{ LIN ,0x28,0x25,0x00}, // ASCII: 125 } (Closing curly brace)
{ CIR_E,0x15,0x11,0x30}, // ASCII: 125 } (Closing curly brace)
{ CIR ,0x2B,0x11,0xF}, // ASCII: 126 ~ (Tilde (approximate))
{ CIR_E,0x4B,0x11,0xF0}, // ASCII: 126 ~ (Tilde (approximate))
{ REC ,0x0E,0x74,0x00}, // ASCII: 127 DEL (Delete (rubout), cross-hatch box)
{ LIN ,0x1D,0x65,0x00}, // ASCII: 127 DEL (Delete (rubout), cross-hatch box)
{ LIN_E,0x15,0x6D,0x00}, // ASCII: 127 DEL (Delete (rubout), cross-hatch box)
{ CIR ,0x69,0x55,0xE7}, //
{ LIN ,0x9D,0xD9,0x00}, //
{ LIN ,0xD9,0x95,0x00}, //
{ LIN_E,0x39,0x99,0x00}, //
{ CIR ,0x79,0x55,0x7E}, //
{ LIN ,0x4D,0x9,0x00}, //
{ LIN ,0x9,0x45,0x00}, //
{ LIN ,0x49,0xA9,0x00}, //
{ LIN_E,0x7C,0x76,0x00}, //
uint16_t Ascii2Font[260] PROGMEM= { //bits 0-8 = Pointer into VectorFontROM, bits 9-15 = Prop Character Width
Ascii2Font[0] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[1] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[2] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[3] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[4] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[5] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[6] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[7] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[8] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[9] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[10] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[11] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[12] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[13] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[14] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[15] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[16] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[17] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[18] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[19] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[20] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[21] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[22] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[23] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[24] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[25] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[26] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[27] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[28] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[29] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[30] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[31] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[32] = 4608,// ASCII: 32 SP (Space)
Ascii2Font[33] = 2561,// ASCII: 33 ! (Exclamation mark)
Ascii2Font[34] = 3075,// ASCII: 34 " (Quotation mark (" in HTML))
Ascii2Font[35] = 4101,// ASCII: 35 # (Cross hatch (number sign))
Ascii2Font[36] = 3593,// ASCII: 36 $ (Dollar sign)
Ascii2Font[37] = 4108,// ASCII: 37 % (Percent sign)
Ascii2Font[38] = 4111,// ASCII: 38 & (Ampersand)
Ascii2Font[39] = 2580,// ASCII: 39 (Closing single quote (apostrophe)) Ascii2Font[40] = 2581,// ASCII: 40 ( (Opening parentheses) Ascii2Font[41] = 2582,// ASCII: 41 ) (Closing parentheses) Ascii2Font[42] = 4631,// ASCII: 42 * (Asterisk (star, multiply)) Ascii2Font[43] = 4635,// ASCII: 43 + (Plus) Ascii2Font[44] = 2589,// ASCII: 44 , (Comma) Ascii2Font[45] = 4639,// ASCII: 45 - (Hyphen, dash, minus) Ascii2Font[46] = 4640,// ASCII: 46 . (Period) Ascii2Font[47] = 4129,// ASCII: 47 / (Slant (forward slash, divide)) Ascii2Font[48] = 4642,// ASCII: 48 0 (Zero) Ascii2Font[49] = 4644,// ASCII: 49 1 (One) Ascii2Font[50] = 4647,// ASCII: 50 2 (Two) Ascii2Font[51] = 4653,// ASCII: 51 3 (Three) Ascii2Font[52] = 4655,// ASCII: 52 4 (Four) Ascii2Font[53] = 4658,// ASCII: 53 5 (Five) Ascii2Font[54] = 4662,// ASCII: 54 6 (Six) Ascii2Font[55] = 4664,// ASCII: 55 7 (Seven) Ascii2Font[56] = 4666,// ASCII: 56 8 (Eight) Ascii2Font[57] = 4668,// ASCII: 57 9 (Nine) Ascii2Font[58] = 3646,// ASCII: 58 : (Colon) Ascii2Font[59] = 3648,// ASCII: 59 ; (Semicolon) Ascii2Font[60] = 3651,// ASCII: 60 < (Less than sign (< in HTML)) Ascii2Font[61] = 3653,// ASCII: 61 = (Equals sign) Ascii2Font[62] = 3143,// ASCII: 62 > (Greater than sign (> in HTML)) Ascii2Font[63] = 3657,// ASCII: 63 ? (Question mark) Ascii2Font[64] = 4684,// ASCII: 64 @ (At-sign) Ascii2Font[65] = 4689,// ASCII: 65 A (Uppercase A) Ascii2Font[66] = 4180,// ASCII: 66 B (Uppercase B) Ascii2Font[67] = 4186,// ASCII: 67 C (Uppercase C) Ascii2Font[68] = 4187,// ASCII: 68 D (Uppercase D) Ascii2Font[69] = 4191,// ASCII: 69 E (Uppercase E) Ascii2Font[70] = 4195,// ASCII: 70 F (Uppercase F) Ascii2Font[71] = 4198,// ASCII: 71 G (Uppercase G) Ascii2Font[72] = 4201,// ASCII: 72 H (Uppercase H) Ascii2Font[73] = 3692,// ASCII: 73 I (Uppercase I) Ascii2Font[74] = 4207,// ASCII: 74 J (Uppercase J) Ascii2Font[75] = 4210,// ASCII: 75 K (Uppercase K) Ascii2Font[76] = 4213,// ASCII: 76 L (Uppercase L) Ascii2Font[77] = 4727,// ASCII: 77 M (Uppercase M) Ascii2Font[78] = 4219,// ASCII: 78 N (Uppercase N) Ascii2Font[79] = 4734,// ASCII: 79 O (Uppercase O) Ascii2Font[80] = 4223,// ASCII: 80 P (Uppercase P) Ascii2Font[81] = 4741,// ASCII: 81 Q (Uppercase Q) Ascii2Font[82] = 4231,// ASCII: 82 R (Uppercase R) Ascii2Font[83] = 4238,// ASCII: 83 S (Uppercase S) Ascii2Font[84] = 4752,// ASCII: 84 T (Uppercase T) Ascii2Font[85] = 4755,// ASCII: 85 U (Uppercase U) Ascii2Font[86] = 4758,// ASCII: 86 V (Uppercase V) Ascii2Font[87] = 5784,// ASCII: 87 W (Uppercase W) Ascii2Font[88] = 4764,// ASCII: 88 X (Uppercase X) Ascii2Font[89] = 4766,// ASCII: 89 Y (Uppercase Y) Ascii2Font[90] = 4769,// ASCII: 90 Z (Uppercase Z) Ascii2Font[91] = 2724,// ASCII: 91 [ (Opening square bracket) Ascii2Font[92] = 4263,// ASCII: 92 \ (Reverse slant (Backslash)) Ascii2Font[93] = 2728,// ASCII: 93 ] (Closing square bracket) Ascii2Font[94] = 3755,// ASCII: 94 ^ (Caret (Circumflex)) Ascii2Font[95] = 4269,// ASCII: 95 _ (Underscore) Ascii2Font[96] = 3246,// ASCII: 96 (Opening single quote)
Ascii2Font[97] = 3759,// ASCII: 97 a (Lowercase a)
Ascii2Font[98] = 3761,// ASCII: 98 b (Lowercase b)
Ascii2Font[99] = 3251,// ASCII: 99 c (Lowercase c)
Ascii2Font[100] = 3764,// ASCII: 100 d (Lowercase d)
Ascii2Font[101] = 3766,// ASCII: 101 e (Lowercase e)
Ascii2Font[102] = 3256,// ASCII: 102 f (Lowercase f)
Ascii2Font[103] = 3771,// ASCII: 103 g (Lowercase g)
Ascii2Font[104] = 3774,// ASCII: 104 h (Lowercase h)
Ascii2Font[105] = 2753,// ASCII: 105 i (Lowercase i)
Ascii2Font[106] = 2755,// ASCII: 106 j (Lowercase j)
Ascii2Font[107] = 3782,// ASCII: 107 k (Lowercase k)
Ascii2Font[108] = 2249,// ASCII: 108 l (Lowercase l)
Ascii2Font[109] = 5323,// ASCII: 109 m (Lowercase m)
Ascii2Font[110] = 3792,// ASCII: 110 n (Lowercase n)
Ascii2Font[111] = 3795,// ASCII: 111 o (Lowercase o)
Ascii2Font[112] = 3796,// ASCII: 112 p (Lowercase p)
Ascii2Font[113] = 3798,// ASCII: 113 q (Lowercase q)
Ascii2Font[114] = 3800,// ASCII: 114 r (Lowercase r)
Ascii2Font[115] = 3802,// ASCII: 115 s (Lowercase s)
Ascii2Font[116] = 3804,// ASCII: 116 t (Lowercase t)
Ascii2Font[117] = 3807,// ASCII: 117 u (Lowercase u)
Ascii2Font[118] = 3810,// ASCII: 118 v (Lowercase v)
Ascii2Font[119] = 5860,// ASCII: 119 w (Lowercase w)
Ascii2Font[120] = 3816,// ASCII: 120 x (Lowercase x)
Ascii2Font[121] = 3818,// ASCII: 121 y (Lowercase y)
Ascii2Font[122] = 3308,// ASCII: 122 z (Lowercase z)
Ascii2Font[123] = 2799,// ASCII: 123 { (Opening curly brace)
Ascii2Font[124] = 2293,// ASCII: 124 | (Vertical line)
Ascii2Font[125] = 2806,// ASCII: 125 } (Closing curly brace)
Ascii2Font[126] = 3836,// ASCII: 126 ~ (Tilde (approximate))
Ascii2Font[127] = 4350,// ASCII: 127 DEL (Delete (rubout), cross-hatch box)
Ascii2Font[128] = 6913,//
Ascii2Font[129] = 7429,//
Ascii2Font[130] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[131] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[132] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[133] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[134] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[135] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[136] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[137] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[138] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[139] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[140] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[141] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[142] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[143] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[144] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[145] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[146] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[147] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[148] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[149] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[150] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[151] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[152] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[153] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[154] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[155] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[156] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[157] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[158] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[159] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[160] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[161] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[162] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[163] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[164] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[165] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[166] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[167] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[168] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[169] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[170] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[171] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[172] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[173] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[174] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[175] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[176] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[177] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[178] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[179] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[180] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[181] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[182] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[183] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[184] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[185] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[186] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[187] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[188] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[189] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[190] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[191] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[192] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[193] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[194] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[195] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[196] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[197] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[198] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[199] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[200] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[201] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[202] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[203] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[204] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[205] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[206] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[207] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[208] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[209] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[210] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[211] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[212] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[213] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[214] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[215] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[216] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[217] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[218] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[219] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[220] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[221] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[222] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[223] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[224] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[225] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[226] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[227] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[228] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[229] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[230] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[231] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[232] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[233] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[234] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[235] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[236] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[237] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[238] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[239] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[240] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[241] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[242] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[243] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[244] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[245] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[246] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[247] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[248] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[249] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[250] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[251] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[252] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[253] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[254] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
Ascii2Font[255] = 4860,//No symbol defined in FontROM. As a diagnostic helper, show a TILDE symbol
#endif /* VECTORFONTROM_H_ */
