Compilation fails due to "No upload port specified"
Stemming from my post here and this comment I made I opened this Topic as a sepperate issue.
See:
Compilation fails due to no "Upload port specified". Under the regular Arduino App ther is a option under "Tools" to specify the port. In this version that option is absent. leading to this error.
Using board '328' from platform in folder: C:\Users\Developers\AppData\Local\arduino15\packages\MiniCore\hardware\avr\2.1.3
Using core 'MCUdude_corefiles' from platform in folder: C:\Users\Developers\AppData\Local\arduino15\packages\MiniCore\hardware\avr\2.1.3
Detecting libraries used...
"C:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64\\sketch\\Blink_Uno.hex.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64\\sketch\\Blink_Uno.hex.ino.cpp" -o "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++17 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_ATmega328 -DARDUINO_ARCH_AVR -Wextra -flto -g "-IC:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\MiniCore\\hardware\\avr\\2.1.3\\variants\\standard" "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64\\sketch\\Blink_Uno.hex.ino.cpp" -o "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64\\sketch\\Blink_Uno.hex.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\Developers\AppData\Local\Temp\arduino-core-cache\core_b9263c5116bb36e94e821547bda0a9e0.a
Linking everything together...
"C:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -Wl,--gc-sections -mmcu=atmega328p -w -flto -g -o "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.elf" "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64\\sketch\\Blink_Uno.hex.ino.cpp.o" "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/..\\arduino-core-cache\\core_b9263c5116bb36e94e821547bda0a9e0.a" "-LC:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64" -lm
"C:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.elf" "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.eep"
"C:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.elf" "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.hex"
cmd /C "C:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objdump" --disassemble --source --line-numbers --demangle --section=.text "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.elf" > "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino_atmega328p_16000000L.lst"
"C:\\Users\\Developers\\AppData\\Local\\arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\Developers\\AppData\\Local\\Temp\\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.elf"
Sketch uses 176 bytes (0%) of program storage space. Maximum is 32768 bytes.
Global variables use 0 bytes (0%) of dynamic memory, leaving 2048 bytes for local variables. Maximum is 2048 bytes.
Compilation complete.
Upload error: Error: 13 INTERNAL: Failed uploading: no upload port provided
Confirms as a problem as when I use the option "Upload using Programmer" All works as expected.
WhatsApp Image 2021-11-19 at 09.35.32
Compiling sketch...
Compiling core...
"C:\Users\Developers\AppData\Local\arduino15\packages\arduino\tools\avrdude\6.3.0-arduino18/bin/avrdude" "-CC:\Users\Developers\AppData\Local\arduino15\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf" -v  -patmega328p -cpickit4_isp -Pusb "-Uflash:w:C:\Users\Developers\AppData\Local\Temp\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.with_bootloader.hex:i"
avrdude: Version 6.3-20201216
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\Developers\AppData\Local\arduino15\packages\MiniCore\hardware\avr\2.1.3/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : pickit4_isp
avrdude: Found CMSIS-DAP compliant device, using EDBG protocol
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : JTAG3_ISP
         Description     : MPLAB(R) PICkit 4 in ISP mode
         Vtarget         : 4.9 V
         SCK period      : 8.00 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\Developers\AppData\Local\Temp\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.with_bootloader.hex"
avrdude: writing flash (176 bytes):
Writing | ################################################## | 100% 0.07s
avrdude: 176 bytes of flash written
avrdude: verifying flash memory against C:\Users\Developers\AppData\Local\Temp\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.with_bootloader.hex:
avrdude: load data flash data from input file C:\Users\Developers\AppData\Local\Temp\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.with_bootloader.hex:
avrdude: input file C:\Users\Developers\AppData\Local\Temp\arduino-sketch-048A8C2D1A4872B6A4167EC65472CF64/Blink_Uno.hex.ino.with_bootloader.hex contains 176 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.10s
avrdude: verifying ...
avrdude: 176 bytes of flash verified
avrdude done.  Thank you.
upload using programmer complete.
There is further discussions related this topic in the same thread linked above. Apparently it is related to the Autodetecting problem of avaiable ports.
Hope this help!
Thanks for your great efforts!
It is only absent when no ports were discovered. I have encountered a problem where it did not discover ports even though they were present, which is being tracked here:
As mentioned there, I find this issue to be intermittent, meaning that if I restart the IDE once or twice it will then show the ports. The port will also appear if I unplug and then replug the board while the IDE is running. If you try those things, do you get a port finally, or do you never get ports?
There is another report that seems to be the latter:
Thank You! Will try and play around when time allows later. I think adding back the option the set port as per the old Arduino IDE is a option as it also allows for a quick and easy testing solution whether the hardware and software system is actively communicating without compiling first.
It already has it:
Ok, yet strange indeed! On the old Arduino IDE it still shows the "port" option but greyed out, even if it cannot find any available ports.
Thats why I said it helps showing that the hardware is functioning even before compiling and uploading attempts.
For example in this my case the Uno is programmed direct via ISP mode using a Pickit4 and it must be considered that the Uno does not have to be plugged in as the Pickit4 could have supplied the target voltage directly.
Is this problem specific to minicore? If I flash back the arduino standard core would it make any difference?
I think that is the best behavior. It is confusing to the user for an expected menu item to be absent.
You can bring this to the attention of the Arduino IDE developers by submitting a request in the Arduino IDE issue tracker here:
https://github.com/arduino/arduino-ide/issues/new/choose
OK, but there is no need for a port selection in that case, as you already discovered:
No. The problem you reported in your other thread was, but not this one.
No.
If you are interested in pursuing this issue of the ports not appearing, please answer the question I asked you earlier:
Sorry. Will try now. Got caught up with other matters.
I just noticed we have almost the same randomly generated forum avatars. It's as if we were identical twins separated at birth!
LOL
:rofl:
