Salve, sto svolgendo un progetto di tesi magistrale che riguarda l'inserimento di un algoritmo di apprendimento all'interno di una board che colleziona, attraverso due sensori (temperatura - mlx90614 medical version e bpm - max30101) due segnali insieme e ne stampa il livello di ansia.
il codice che ho implementato è questo:
//__________________________________________________________________________________________________________________________________________________________________________
//IMPORTING LIBRARIES
#include <PlaquetteLib.h> // --> Smoothing and scaling operations [https://sofapirate.github.io/Plaquette/]
using namespace pq; // --> use plaquette library as "pq"
Smoother smoother3(3.0f); // --> third moving mean of 3 seconds for ST values
Smoother smoother2(3.0f); // --> second moving mean of 3 seconds for HR values
#include <Wire.h> // --> I2C connection
#include "MAX30105.h" // --> Sparkfun library for MAX30101 sensor [https://github.com/sparkfun/SparkFun_MAX3010x_Sensor_Library]
MAX30105 particleSensor; // --> used for BPM and ST
#include "Scaler.h" // --> Feature extraction library [https://github.com/eloquentarduino/everywhereml]
#include "Classifier.h" // --> Classification library containing Logistic Regression algorithm [https://github.com/eloquentarduino/micromlgen]
Eloquent::ML::Port::LogisticRegression clf; // --> declare classifier library
#include "heartRate.h" // --> Optical Heart Rate Detection (PBA Algorithm) [https://github.com/sparkfun/SparkFun_MAX3010x_Sensor_Library/blob/master/src/heartRate.h]
//#include <Arduino.h>
//#include <U8x8lib.h>
//U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(18, 17, 21);
//____________________________________________________________________________________________________________________________________________________________________________
//DEFINING GLOBAL VARIABLES
//hr
const byte RATE_SIZE = 3; //Averaging
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
int beatsPerMinute;
int beatAvg;
//st
float degree; // --> raw peripheral skin temperature in °C
int st; // averaged peripheral skin temperature in °C
const byte WINDOW_SIZE = 60;
byte signal1[WINDOW_SIZE];
byte signal2[WINDOW_SIZE];
byte signal1Index = 0;
byte signal2Index = 0;
//instrumental initialization
Plaquette.begin();
//Wire.begin(41, 42);
Wire.begin(4, 5);
//u8x8.begin();
//u8x8.setBusClock(1);
//u8x8.setPowerSave(0);
//hr sensor
particleSensor.begin(Wire, I2C_SPEED_STANDARD);
byte ledBrightness = 0x1F;
byte sampleAverage = 1;
byte ledMode = 3;
byte sampleRate = 50;
int pulseWidth = 411;
int adcRange = 4096;
particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange);
particleSensor.setPulseAmplitudeRed(0); //0 mA
particleSensor.setPulseAmplitudeIR(0); // 0 mA
particleSensor.setPulseAmplitudeGreen(0x19); // 1 mA
//st sensor
particleSensor.enableDIETEMPRDY();
//u8x8.setFont(u8x8_font_8x13B_1x2_r);
//u8x8.drawString(0, 4, "Initializing...");
//delay(2000);
//u8x8.clearDisplay();
//u8x8.setFont(u8x8_font_open_iconic_check_4x4);
//u8x8.drawGlyph(6, 2, 0x40);
//delay(2000);
// BPM values with MAX30101 sensor 1Hz
void hrCollection() {
* The particle sensor capture the green led emission from the inner wrist. When a blood pulse happen, the photodiode capture a pulse of light which corresponds to a heart beat.
* In order to be able to capture peaks throw the wrist, the green led has been accurately set up in the setup() section, following the instructions published by the authors
* on page 22 of the paper. [https://pdfserv.maximintegrated.com/en/an/AN6409.pdf]
* The peaks, corresponding to the BPM, are computed throw a PBA algorithm, then, they are averaged with a moving window of size 3.
long irValue = particleSensor.getGreen();
if (checkForBeat(irValue) == true)
//We sensed a beat!
long delta = millis() - lastBeat;
lastBeat = millis();
beatsPerMinute = 60 / (delta / 1000.0);
if (beatsPerMinute < 255 && beatsPerMinute > 20)
rates[rateSpot++] = (byte)beatsPerMinute; //Store this reading in the array
rateSpot %= RATE_SIZE; //Wrap variable
//Take average of readings
beatAvg = 0;
for (byte x = 0 ; x < RATE_SIZE ; x++)
beatAvg += rates[x];
beatAvg /= RATE_SIZE;
// Add beatAvg to signal1
signal1[signal1Index] = beatAvg;
signal1Index = (signal1Index + 1) % WINDOW_SIZE;
//_________________________________________________________________________________________________________________________________________________________________-
// ST values with the particle sensor 1Hz.
void stCollection() {
* Peripheral skin Temperature has been measured in degree Celsius thanks to an InfraRed thermophile that capture the emissivity of the human skin.
degree = particleSensor.readTemperature();
st = degree >> smoother3;
// Add st to signal2
signal2[signal2Index] = st;
signal2Index = (signal2Index + 1) % WINDOW_SIZE;
// Feature Extraction
void extraction(float* features) {
// Calculate minimum, maximum, mean, median, standard deviation, variance, skewness, and kurtosis for signal1 (beatAvg)
int beatMin = INT_MAX;
int beatMax = INT_MIN;
float beatSum = 0.0;
float beatSumSquares = 0.0;
float beatSkewness = 0.0;
float beatKurtosis = 0.0;
byte sortedSignal1[WINDOW_SIZE];
for (byte i = 0; i < WINDOW_SIZE; i++) {
if (signal1[i] < beatMin) {
beatMin = signal1[i];
if (signal1[i] > beatMax) {
beatMax = signal1[i];
beatSum += signal1[i];
beatSumSquares += pow(signal1[i], 2);
sortedSignal1[i] = signal1[i];
float beatMean = beatSum / WINDOW_SIZE;
std::sort(sortedSignal1, sortedSignal1 + WINDOW_SIZE);
byte middle = WINDOW_SIZE / 2;
byte beatMedian;
if (WINDOW_SIZE % 2 == 0) {
beatMedian = (sortedSignal1[middle - 1] + sortedSignal1[middle]) / 2;
beatMedian = sortedSignal1[middle];
float beatStdDeviation = sqrt((beatSumSquares / WINDOW_SIZE) - pow(beatMean, 2));
float beatVariance = pow(beatStdDeviation, 2);
float deviation = signal1[i] - beatMean;
beatSkewness += pow(deviation, 3);
beatKurtosis += pow(deviation, 4);
beatSkewness /= (WINDOW_SIZE * pow(beatStdDeviation, 3));
beatKurtosis /= (WINDOW_SIZE * pow(beatStdDeviation, 4));
// Calculate minimum, maximum, mean, median, standard deviation, variance, skewness, and kurtosis for signal2 (st)
float stMin = FLT_MAX;
float stMax = FLT_MIN;
float stSum = 0.0;
float stSumSquares = 0.0;
float stSkewness = 0.0;
float stKurtosis = 0.0;
float sortedSignal2[WINDOW_SIZE];
if (signal2[i] < stMin) {
stMin = signal2[i];
if (signal2[i] > stMax) {
stMax = signal2[i];
stSum += signal2[i];
stSumSquares += pow(signal2[i], 2);
sortedSignal2[i] = signal2[i];
float stMean = stSum / WINDOW_SIZE;
std::sort(sortedSignal2, sortedSignal2 + WINDOW_SIZE);
byte stMedian;
stMedian = (sortedSignal2[middle - 1] + sortedSignal2[middle]) / 2;
stMedian = sortedSignal2[middle];
float stStdDeviation = sqrt((stSumSquares / WINDOW_SIZE) - pow(stMean, 2));
float stVariance = pow(stStdDeviation, 2);
float deviation = signal2[i] - stMean;
stSkewness += pow(deviation, 3);
stKurtosis += pow(deviation, 4);
stSkewness /= (WINDOW_SIZE * pow(stStdDeviation, 3));
stKurtosis /= (WINDOW_SIZE * pow(stStdDeviation, 4));
// Store the calculated features in the features array
features[0] = beatMin;
features[1] = beatMax;
features[2] = beatMean;
features[3] = beatMedian;
features[4] = beatStdDeviation;
features[5] = beatVariance;
features[6] = beatSkewness;
features[7] = beatKurtosis;
features[8] = stMin;
features[9] = stMax;
features[10] = stMean;
features[11] = stMedian;
features[12] = stStdDeviation;
features[13] = stVariance;
features[14] = stSkewness;
features[15] = stKurtosis;
//_____________________________________________________________________________________________________________________________________________________________________________
Plaquette.step();
hrCollection();
stCollection();
float features[16]; // Create the features array
extraction(features);
if (!processor.transform(features))
return;
Serial.print(beatAvg); Serial.print(","); Serial.print(st); Serial.print(","); Serial.println(clf.predictLabel(processor.X));
//char heart[3];
//char temperature[2];
//u8x8.setFont(u8x8_font_open_iconic_embedded_2x2);
//u8x8.drawGlyph(4, 1, 0x46);
//u8x8.setFont(u8x8_font_lucasarts_scumm_subtitle_r_2x2_f);
//itoa(beatsPerMinute, heart, 10);
//u8x8.drawString(7, 1, heart);
//itoa(st, temperature, 10);
//u8x8.drawString(7, 3, temperature);
//u8x8.drawString(0, 5, clf.predictLabel(processor.X));
Sono incerta see I miei due sensori contengano o no delle internal pullup. I sensori sono collegati in parallelo, il sensor di temperature riceve 3.3V e il sensore che individual I BPM riceve 5V.
Il mio problems è che, usando una heltec wifi kit v3 e attivando il mio OLED preinserito di fabbrica, utilizzando la libreria u8x8, il segnale rallenta drasticamente. Questo non consent all'algoritmo di individuare I corretti BPM, che raggiungono un Massimo di 20 BPM (un algoritmo interno legge I valori di luce verde che vengono riflessi sul polso, ne individua i picchi e calcola i BPM).
Mi chiedo se il problems fossero le resistenze pullup, come faccio a capire se i sensori possiedono o no le resistenze? (dai datasheet ho capito che i sensori non le hanno, il sito web ufficiale della sparkfan annuncia che il sensore ne possiede uno ma non riesco ad utilizzarlo) Inoltre, mi chiedo cosa dovrei modificare nel codice per fare funzionare i pullup. Se magari ho sbagliato qualcosa che genera degli errori di comunicazione di tanto in tanto.
