Confusing TFT LCD 3.9 ", how to connect?
(Непонятный TFT LCD 3.9", как подключить?)
Bought on the LCD Alliexpres and cant hook it,
arduino conclusions do not match,
I had a part of solder,
on the labeling of the conclusions there,
I can not find the library,
All white screen,
give what you can.
(Купил LCD на Alliexpres и немогу его подключить,
выводы с arduino не совпадают,
пришлось часть припаивать,
на выводах маркировки нет,
не могу подобрать библиотеку,
всё время белый экран,
помогите чем сможете.)
Foto (Фото)
Your photos show a MEGA2560 Shield with 8-bit interface. (5 resistor-packs)
It looks as if the 8-bit interface is using PORTC instead of PORTA. Just test continuity between RP1 and D28 for PORTC (or D22 if PORTA)
Regarding your poor mating experience:
  1. Nature makes boys and girls
  2. Every male pin should be inserted into the corresponding female socket.
I suspect that you need to straighten the JP4 male header and the female socket. Then Nature will be satisfied.
David.
