Connect 3.5inch RPi Display 420x320 Pixel with XPT2046 to Arduino Mega 2560?
I'm really a beginner but I just got an Arduino Mega 2560 for Christmas. It works fine, and it's from Elegoo with the Most Complete Starter Kit. I've already gotten a seven-segment display set up and a disconnected LED. However, I have a small display I got from Amazon.
Here is the text:
3.5inch RPi Display
CE RoHS 480x320 Pixel XPT2046 Touch Controller
I have a bunch of jumper wires that came in my starter kit. Does anyone know how to connect it to the Mega 2560? Can I have a wiring diagram? Thanks in advance.
In addition, how would I be to say Hello, world through the Arduino IDE onto this screen?
You realize it's made for the Raspberry Pi, right?
Is it possible in anyway to connect it? I know that the pinholes on the display go with the Raspberry Pi GPIO, but I need a way to translate that into arduino.
The normal procedure is to find out what display processor IC it uses, and then search for a display library to drive it.
You may have voltage level translation problems, because the Pi is a 3.3V device and most Arduino are 5V, including the Mega.
There is a 3.3v pin on Arduino Mega.
Also, what is the pin connection diagram for the jumper wires?
I guess you don't understand what "voltage level translation problems" are. It's up to you to research the pin connections. Preferably before you buy something. I suspect not very many people have used this display with an Arduino so you might be in expert project territory.
Also, I gave you some directions, and you seemed to just gloss over them. If you don't leverage the advice you get, more advice won't help much.
The kind of answer I was expecting was like, "the display processor is a ....".
The touch controller is an XPT2046. There are some chips on the back of the display labelled U1-5.
That wouldn't be enough. You need to know the identity of the display controller. Some online research might help. You'll need a map of the pins as well.
That's what I'm asking for. A pin diagram..
Why are you asking here? You have the board and the internet...
I found one answer but I cannot comprehend it that well. Can I have a simple pinout diagram from this image?
b421c0e53d336396dc0592f764d0bc27f0341032_2_500x500
Hi @ebp012
Here you will find a lot of information about your display:
http://www.lcdwiki.com/3.5inch_RPi_Display
Or fry it.
a7
Where's the pin diagram tho
here
"Interface"
hi @ebp012
On the WEB, those looking for it, find it....
One question: What text direction is the Interface section's table in? Is it left to right and then up-to-down (like English) or is it up-to-down and then left to right?
Pin 1 usually has some kind of index mark, or just the number "1" somewhere near the pin.
Hi @ebp012
maybe like this:
300px-MPI3201-RPi-901
Which pins do these go in?
DC
T_CS
LCD_CS
TP_SO
TP_IRQ
NC
LCD_SI
LCD_SCK/TP_SCK
