i am trying to make a custom steering wheel for my rig. I have found a video that helps me with the buttons and all that stuff. But to connect it to my wheel, I have to use a JST 7 pin 1.25mm connector. Is there any way of doing this? if so, please let me know!
Also, which Arduino board do you recommend?
Get a connector and solder it on?
Post more helpful info if you want a more helpful answer
so for the g920, it connects its board to the wheel rig using a JST connector. can I put a JST male connector on the Arduino, to then plug it into my rig? is there a space to do that, or is it not possible.
No there isn't a JST connector on the Arduino. You will have to modify the wireing. I'd go with an Arduino UNO and a 7 pin JST (GH) connector something like this.
Chop off one of the sides of the cable since you won't need it. Then remove some of the plastic around each wire. You should probably tin each wire with a soldering iron to make thing easier. Once you have that done you can connect those wires inside the Arduino. Where you connect the wires on the Arduino depend on your software and the pin out of the g920.
