Hi
I am using Arduino Mega Rev 3 connected to an RGB amplifier which is then connected to a 5 meters RGB LED strip (12V). I am using a 12V power supply 10A, connected to both the RGB amplifier and the Arduino Mega. I have uploded a simple code on the Arduino that makes the LED strip light with the Green colour.
However, I tried two different ways of connecting the whole thing but none of them worked perfectly, each of them does a part of the wanted output.
The first one, I tried to connect everything like this example (connecting the strip black wire to the arduino 5V):
http://justpaste.it/o18q
When I turn everything on, the LED strips blink (only blink for less than a second) with the green colour I specified in the code. but does not maintain the colour afterwards and it goes off until I turn the power supply off, then when I turn the power supply on again it blink again and goes off. but in this example the only good thing is that the led gives the colour I specified in the Arduino code.
then I tried another way to connect everything like this (the strip black wire to the power supply positive wire):
http://justpaste.it/o192
After connecting it this way, as soon as I turn the power supply on I get a bright white colour straight away. this colour does not change whatever I put in the Arduino code. it only maintains the bright white colour forever but without any change regarding to any code I tried. Moreover, if I remove the pins of the red and green colour from the Arduino (PWM) I get a full blue colour, and if I put only the green pin I get a full green colour. so apparently with this way of wiring things I get tha maximum value of colours whatever the code is.
Do you have any idea what did I do wrong? which way is better? and what shall I edit in order to get a maintainable changeable colour? knowing that I want the whole strip to light with the same colour.
Thanks all for your help.
