Can not find constructor for my display st7567 128x64 I2C in u8g2.
How to do?
Then it might not be supported by the u8g2 library.
Here is a similar question: How can I controll my St7567s lcd display 128x64 i2c
There are no i2c constructors there for 128x64, only SPI constructors .
However there are links that refer to working constructors but they are not present in u8g2.
any one that can help me out.
Take a look at Related Topics below, e.g. U8G2, I2C and constructor HW - Using Arduino / Project Guidance - Arduino Forum
If you mention @olikraus, you might get direct help from the author.
Looks like the .h file has quite a few possibilities:
public: U8G2_ST7567_PI_132X64_1_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_PI_132X64_1_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_PI_132X64_1_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_PI_132X64_2_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_PI_132X64_2_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_PI_132X64_2_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_PI_132X64_F_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_PI_132X64_F_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_PI_132X64_F_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_JLX12864_1_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_JLX12864_1_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_JLX12864_1_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064_1_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064_1_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064_1_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064I_1_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064I_1_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064I_1_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_OS12864_1_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_OS12864_1_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_OS12864_1_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_JLX12864_2_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_JLX12864_2_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_JLX12864_2_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064_2_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064_2_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064_2_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064I_2_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064I_2_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064I_2_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_OS12864_2_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_OS12864_2_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_OS12864_2_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_JLX12864_F_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_JLX12864_F_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_JLX12864_F_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064_F_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064_F_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064_F_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064I_F_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064I_F_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ENH_DG128064I_F_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_OS12864_F_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_OS12864_F_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_OS12864_F_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ERC13232_1_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ERC13232_1_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ERC13232_1_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ERC13232_2_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ERC13232_2_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ERC13232_2_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ERC13232_F_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ERC13232_F_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_ERC13232_F_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_122X32_1_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_122X32_1_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_122X32_1_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_122X32_2_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_122X32_2_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_122X32_2_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_122X32_F_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_122X32_F_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_122X32_F_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_64X32_1_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_64X32_1_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_64X32_1_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_HEM6432_1_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_HEM6432_1_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_HEM6432_1_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_64X32_2_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_64X32_2_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_64X32_2_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_HEM6432_2_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_HEM6432_2_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_HEM6432_2_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_64X32_F_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_64X32_F_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_64X32_F_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_HEM6432_F_SW_I2C(const u8g2_cb_t *rotation, uint8_t clock, uint8_t data, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_HEM6432_F_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE, uint8_t clock = U8X8_PIN_NONE, uint8_t data = U8X8_PIN_NONE) : U8G2() {
public: U8G2_ST7567_HEM6432_F_2ND_HW_I2C(const u8g2_cb_t *rotation, uint8_t reset = U8X8_PIN_NONE) : U8G2() {
Where have you find those constructors?
Which library have you got them from???
I have Arduino Mega to work from.
I have tried to download library u8g2-master from Olikraus/u8g2 but get error message
"specified folder/zip file does not contain a valid library"
u8g2-Arduino-master is possible to add but there is no constructor for i2c there
This is the constructors to select:
//U8G2_ST7567_PI_132X64_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=/ 13, / data=/ 11, / cs=/ 7, / dc=/ 9, / reset=/ 8); // Pax Instruments Shield, LCD_BL=6'
//U8G2_ST7567_PI_132X64_1_4W_HW_SPI u8g2(U8G2_R0, / cs=/ 7, / dc=/ 9, / reset=/ 8); // Pax Instruments Shield, LCD_BL=6
//U8G2_ST7567_JLX12864_1_4W_SW_SPI u8g2(U8G2_R0, / clock=/ 13, / data=/ 11, / cs=/ 7, / dc=/ 9, / reset=/ 8);
type or paste code hereUse code tags to format code for the forum
//U8G2_ST7567_JLX12864_1_4W_HW_SPI u8g2(U8G2_R0, / cs=/ 7, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_122X32_1_4W_SW_SPI u8g2(U8G2_R0, / clock=/ 13, / data=/ 11, / cs=/ 7, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_122X32_1_4W_HW_SPI u8g2(U8G2_R0, / cs=/ 7, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_OS12864_1_4W_SW_SPI u8g2(U8G2_R0, / clock=/ 13, / data=/ 11, / cs=/ 7, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_OS12864_1_4W_HW_SPI u8g2(U8G2_R0, / cs=/ 7, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_ENH_DG128064_1_4W_SW_SPI u8g2(U8G2_R0, / clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_ENH_DG128064_1_4W_HW_SPI u8g2(U8G2_R0, / cs=/ 10, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_ENH_DG128064I_1_4W_SW_SPI u8g2(U8G2_R0, / clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_ENH_DG128064I_1_4W_HW_SPI u8g2(U8G2_R0, / cs=/ 10, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_64X32_1_HW_I2C u8g2(U8G2_R0, / reset=/ U8X8_PIN_NONE);
//U8G2_ST7567_HEM6432_1_HW_I2C u8g2(U8G2_R0, / reset=/ U8X8_PIN_NONE);
//U8G2_ST7567_ERC13232_1_4W_SW_SPI u8g2(U8G2_R0, / clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_ERC13232_1_4W_HW_SPI u8g2(U8G2_R0, / cs=/ 10, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_96X65_1_4W_SW_SPI u8g2(U8G2_R0, / clock=/ 13, / data=/ 11, / cs=/ 10, / dc=/ 9, / reset=/ 8);
//U8G2_ST7567_96X65_1_4W_HW_SPI u8g2(U8G2_R0, / cs=/ 10, / dc=/ 9, / reset=*/ 8);
Best is to install U8g2 from the Arduino IDE library manager...
Oliver
Yes, I have done that also. Both manager and ZIP. Same result.
which example in library do you suggest to test with?
If uploading testprogram hello world I get a lot of constructor, but only two with ST7567 I2C.
And none of them is working.
Do I have to define i2c address somewhere?
address of my is 03F.
I found the error.
I have missed to define i2C address!
after this line:
u8g2.setI2CAddress(0x3F * 2);
everything works.
By the way....this constructor works also:
U8G2_ST7567_ENH_DG128064I_F_SW_I2C u8g2(U8G2_R0, SCL, SDA, U8X8_PIN_NONE);
a little confusing is that all example codes have no definition for i2c address.
