Hi all!
I am looking for a servo motor 360 degree but non continously rotation.
I would like to control it like a 180 degree motor.
Any suggestions would be highly appreciated!
Hi all!
Hello StergiosT
Take a search engine of your choice and ask the WWW for 'servo motor 360 degree' to collect some data to be sorted out to get the needed information.
Unfortunately I didn’t find any solution about that
Try searching for RC winch servos
Dronebotworkshop shows how a servo is a DC motor with feedback.
https://dronebotworkshop.com/custom-servo-motor/
Very first hit for search using the phase "360 degree servo":
https://www.amazon.com/Readytosky-Digital-Degree-Torque-Helicopter/dp/B07Z3VGZNP
Second hit:
Sail winch servo (3.5 turns):
https://www.amazon.com/Hitec-RCD-33785S-HS-785HB-Winch/dp/B000BOGI7E/
Finally i figured out using this motor
https://www.rc-wing.com/feetech-ft6335m-steel-gear-7-4-v-35kg-cm-torque-digital-waterproof-servo.html
Thank you all!!!
Now i am wonder if there is any way to disable the quick movement when servo attached..
When you attach() the servo it will move to its default position. For a 180 degree servo that is 90 degrees. For your servo it will probably be half of its maximum angle. If you want the servo to move to a different starting position then write() that position to the servo before using attach()
