Control bldc motor
today, i tried to control 310v bldc motor with circuit i made. But 2 mosfets exploded.
my diagram
I tried it on 12v motor and functioning normally.
I don't have the exact motor specs so the frequency used is 3.9kHz
SET_PWM_DUTY(30); //duty = 30;
  int i = 5000;
  // motor start
  while(i > 100)
    delayMicroseconds(i);
    bldc_move();
    bldc_step++;
    bldc_step %= 6;
    i = i - 20;
I use this code to start the engine. But it's fault
Datasheet of mosfets
/* Sensorless brushless DC motor control with Arduino UNO and IR2101 (Arduino DIY ESC).
 * BLDC motor speed is controlled with a potentiometer connected to A0.
 * This is a free software with NO WARRANTY.
 * http://simple-circuit.com/
#define PWM_MAX_DUTY      255
#define PWM_MIN_DUTY      50
#define PWM_START_DUTY    100
byte bldc_step = 0, motor_speed, pin_state;
  DDRD  |= 0xE0;  // configure pins 5, 6 and 7 as outputs
  PORTD  = 0x00;
  DDRB  |= 0x0E;  // configure pins 9, 10 and 11 as outputs
  PORTB  = 0x31;
  // Timer1 module setting: set clock source to clkI/O / 1 (no prescaling)
  TCCR1A = 0;
  TCCR1B = 0x01;
  // Timer2 module setting: set clock source to clkI/O / 1 (no prescaling)
  TCCR2A = 0;
  TCCR2B = 0x01;
  // ADC module configuration
  ADMUX  = 0x60;   // configure ADC module and select channel 0
  ADCSRA = 0x84;   // enable ADC module with 16 division factor (ADC clock = 1MHz)
  PCICR  = EIMSK = 0;  // disable all external interrupts
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
// pin change interrupt 2 (PCINT2) ISR
ISR (PCINT2_vect)
  if( (PIND & PCMSK2) != pin_state )
    return;
  // BEMF debounce
  for(byte i = 0; i < 20; i++)
    if(bldc_step & 1){
      if(PIND & PCMSK2)     i -= 1;
    else {
      if(!(PIND & PCMSK2))  i -= 1;
  bldc_move();
  bldc_step++;
  bldc_step %= 6;
// BLDC motor commutation function
void bldc_move()
  switch(bldc_step)
    case 0:
      AH_BL();
      BEMF_C_FALLING();
    case 1:
      AH_CL();
      BEMF_B_RISING();
    case 2:
      BH_CL();
      BEMF_A_FALLING();
    case 3:
      BH_AL();
      BEMF_C_RISING();
    case 4:
      CH_AL();
      BEMF_B_FALLING();
    case 5:
      CH_BL();
      BEMF_A_RISING();
  SET_PWM_DUTY(PWM_START_DUTY);  // setup starting PWM with duty cycle = PWM_START_DUTY
  int i = 5000;
  // motor start
  while(i > 100)
    bldc_move();
    bldc_step++;
    bldc_step %= 6;
    i = i - 20;
  motor_speed = PWM_START_DUTY;
  PCICR  = 4;  // enable pin change interrupt for pins PCINT23..16 (Arduino 0 to 7)
  while(1)
    ADCSRA |= 1 << ADSC;    // start conversion
    while(ADCSRA & 0x40);   // wait for conversion complete
    motor_speed = ADCH;     // read ADC data (8 bits only)
    if(motor_speed < PWM_MIN_DUTY)
      motor_speed = PWM_MIN_DUTY;
    SET_PWM_DUTY(motor_speed);
void BEMF_A_RISING()
  PCMSK2 = 0x04;    // enable Arduino pin 2 (PCINT18) interrupt, others are disabled
  pin_state = 0x04;
void BEMF_A_FALLING()
  pin_state = 0;
void BEMF_B_RISING()
  PCMSK2 = 0x08;    // enable Arduino pin 3 (PCINT19) interrupt, others are disabled
  pin_state = 0x08;
void BEMF_B_FALLING()
  pin_state = 0;
void BEMF_C_RISING()
  PCMSK2 = 0x10;    // enable Arduino pin 4 (PCINT20) interrupt, others are disabled
  pin_state = 0x10;
void BEMF_C_FALLING()
  pin_state = 0;
void AH_BL()
  PORTD &= ~0xA0;
  PORTD |=  0x40;
  TCCR1A =  0;      // turn pin 11 (OC2A) PWM ON (pin 9 & pin 10 OFF)
  TCCR2A =  0x81;   //
void AH_CL()
  PORTD &= ~0xC0;
  PORTD |=  0x20;
  TCCR2A =  0x81;   //
void BH_CL()
  PORTD &= ~0xC0;
  PORTD |=  0x20;
  TCCR2A =  0;       // turn pin 10 (OC1B) PWM ON (pin 9 & pin 11 OFF)
  TCCR1A =  0x21;    //
void BH_AL()
  PORTD &= ~0x60;
  PORTD |=  0x80;
  TCCR1A =  0x21;   //
void CH_AL()
  PORTD &= ~0x60;
  PORTD |=  0x80;
  TCCR2A =  0;       // turn pin 9 (OC1A) PWM ON (pin 10 & pin 11 OFF)
  TCCR1A =  0x81;    //
void CH_BL()
  PORTD &= ~0xA0;
  PORTD |=  0x40;
  TCCR1A =  0x81;    //
void SET_PWM_DUTY(byte duty)
  OCR1A  = duty;  // set pin 9  PWM duty cycle
  OCR1B  = duty;  // set pin 10 PWM duty cycle
  OCR2A  = duty;  // set pin 11 PWM duty cycle
All code.
When there is no engine it is fine but when there is an engine it explodes.
Resistance of 2 coils is about 40ohm
What is my problem?
When you say "I tried it on 12v motor and functioning normally" do you mean that you use the same 310v motor with this diagram and 12v?
