Bldc speed control
Hi everyone, I'm controlling the speed of bldc motor using Simple Circuit 's instruction. But i can't control speed lower than duty cycle < 20%. i tried adding delay to interrupt but it also does not work.
/* Sensorless brushless DC motor control with Arduino UNO and IR2101 (Arduino DIY ESC).
* BLDC motor speed is controlled with a potentiometer connected to A0.
* This is a free software with NO WARRANTY.
* http://simple-circuit.com/
#define PWM_MAX_DUTY      255
#define PWM_MIN_DUTY      50
#define PWM_START_DUTY    100
long u_s;
byte bldc_step = 0, motor_speed, pin_state;
  DDRD  |= 0xE0;  // configure pins 5, 6 and 7 as outputs
  PORTD  = 0x00;
  DDRB  |= 0x0E;  // configure pins 9, 10 and 11 as outputs
  PORTB  = 0x31;
  // Timer1 module setting: set clock source to clkI/O / 1 (no prescaling)
  TCCR1A = 0;
  TCCR1B = 0x01;
  // Timer2 module setting: set clock source to clkI/O / 1 (no prescaling)
  TCCR2A = 0;
  TCCR2B = 0x01;
  // ADC module configuration
  ADMUX  = 0x60;   // configure ADC module and select channel 0
  ADCSRA = 0x84;   // enable ADC module with 16 division factor (ADC clock = 1MHz)
  PCICR  = EIMSK = 0;  // disable all external interrupts
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(4, INPUT_PULLUP);
// pin change interrupt 2 (PCINT2) ISR
ISR (PCINT2_vect)
  if( (PIND & PCMSK2) != pin_state )
    return;
  // BEMF debounce
  for(byte i = 0; i < 20; i++)
    if(bldc_step & 1){
      if(PIND & PCMSK2)     i -= 1;
    else {
      if(!(PIND & PCMSK2))  i -= 1;
  bldc_move();
  bldc_step++;
  bldc_step %= 6;
  delayMicroseconds(u_s);
// BLDC motor commutation function
void bldc_move()
  switch(bldc_step)
    case 0:
      AH_BL();
      BEMF_C_FALLING();
    case 1:
      AH_CL();
      BEMF_B_RISING();
    case 2:
      BH_CL();
      BEMF_A_FALLING();
    case 3:
      BH_AL();
      BEMF_C_RISING();
    case 4:
      CH_AL();
      BEMF_B_FALLING();
    case 5:
      CH_BL();
      BEMF_A_RISING();
  SET_PWM_DUTY(PWM_START_DUTY);  // setup starting PWM with duty cycle = PWM_START_DUTY
  int i = 5000;
  // motor start
  while(i > 100)
    delayMicroseconds(i);
    bldc_move();
    bldc_step++;
    bldc_step %= 6;
    i = i - 20;
  motor_speed = PWM_START_DUTY;
  PCICR  = 4;  // enable pin change interrupt for pins PCINT23..16 (Arduino 0 to 7)
  while(1)
    ADCSRA |= 1 << ADSC;    // start conversion
    while(ADCSRA & 0x40);   // wait for conversion complete
    motor_speed = ADCH;     // read ADC data (8 bits only)
    if(motor_speed < PWM_MIN_DUTY)
      motor_speed = PWM_MIN_DUTY;
    SET_PWM_DUTY(motor_speed);
    if(motor_speed < 50) u_s = 70000;
    else u_s = 0;
void BEMF_A_RISING()
  PCMSK2 = 0x04;    // enable Arduino pin 2 (PCINT18) interrupt, others are disabled
  pin_state = 0x04;
void BEMF_A_FALLING()
  pin_state = 0;
void BEMF_B_RISING()
  PCMSK2 = 0x08;    // enable Arduino pin 3 (PCINT19) interrupt, others are disabled
  pin_state = 0x08;
void BEMF_B_FALLING()
  pin_state = 0;
void BEMF_C_RISING()
  PCMSK2 = 0x10;    // enable Arduino pin 4 (PCINT20) interrupt, others are disabled
  pin_state = 0x10;
void BEMF_C_FALLING()
  pin_state = 0;
void AH_BL()
  PORTD &= ~0xA0;
  PORTD |=  0x40;
  TCCR1A =  0;      // turn pin 11 (OC2A) PWM ON (pin 9 & pin 10 OFF)
  TCCR2A =  0x81;   //
void AH_CL()
  PORTD &= ~0xC0;
  PORTD |=  0x20;
  TCCR2A =  0x81;   //
void BH_CL()
  PORTD &= ~0xC0;
  PORTD |=  0x20;
  TCCR2A =  0;       // turn pin 10 (OC1B) PWM ON (pin 9 & pin 11 OFF)
  TCCR1A =  0x21;    //
void BH_AL()
  PORTD &= ~0x60;
  PORTD |=  0x80;
  TCCR1A =  0x21;   //
void CH_AL()
  PORTD &= ~0x60;
  PORTD |=  0x80;
  TCCR2A =  0;       // turn pin 9 (OC1A) PWM ON (pin 10 & pin 11 OFF)
  TCCR1A =  0x81;    //
void CH_BL()
  PORTD &= ~0xA0;
  PORTD |=  0x40;
  TCCR1A =  0x81;    //
void SET_PWM_DUTY(byte duty)
  OCR1A  = duty;  // set pin 9  PWM duty cycle
  OCR1B  = duty;  // set pin 10 PWM duty cycle
  OCR2A  = duty;  // set pin 11 PWM duty cycle
I tried changing the frequency but it's probably inefficient. How should I fix it? I want the minimum speed possible to be 0.
I see nothing at that webite regarding BLDC motors.
It's a limitation of BEMF feedback and the simple circuit you are using.
BEMF is proportional to the speed of rotation, so under very low speed conditions the triggering of the LM393 may not occur at the correct points. That is why you see that special code for motor startup that does not rely on BEMF.
yes, could be bldc A2212 series. Can I reduce the frequency then increase the duty cycle to run at low speed?
You can try but I don't think it will make a big difference. Depending on the motor, below a certain speed there won't be much BEMF, it just a drawback of using BEMF. If you want to go slower you will need to use hall sensors or similar feedback
means use arduino read bemf value to switch, remove ic lm339
No. Don't use BEMF at all. Use a sensor type feedback like hall switch.
The circuit and code will be different.
But I only control small bldc. We don't have hall sensors.
Then then I have no further suggestions.
BEMF is simple to do but it is not perfect.
yes, thank you.
You are welcome.
At least now you know why you can't run at low speeds.
if i use a higher voltage motor (96VDC or higher, sensorless), do i need to change anything in the circuit? Resistors of bemf?
I can't read any of the part numbers.
Do you have the original schematic?
Also as I said your link does not have that circuit.
yes, this 's link. i don't know if i use a higher power supply, does it run?
That circuit is designed for 12V. You would need something completely different for 96V
i still use old mosfet. Vds max = 600VDC so i am not worried. can bemf circuit work? or i have to increase resistor value to protect the IC? the high side mosfets still use bootstrap capacitors to work
Datasheet says 25V
Sorry i only use old gate driver and other mosfet. How to calculate speed? do you know the formula?
No.
Is there a reason why you are trying to build your own speed controller rather than buying an off-the-shelf ESC for brushless motors?
