I am currently building an Octobouncer. I have four Nema 17 17HS08-1004S stepper motors. Each one is controlled by a DRV8825. Each motor moves a mechanical arm composed by two PVC bars. The mechanical arms hold the platform, built with methacrylate.
The structure of the Octobouncer is built with light materials, so the motors should have enough power to move the structure individually.
I have tested a single motor moving a single small PVC bar and it does well, but when I attach the PVC bar to the whole structure, it cannot move it.
I did another test with the single PVC bar hitting an obstacle while it spins. When the PVC bar hits the obstacle, instead of keeping with the spin, the motor stops and the bar falls to the ground.
If @ahsrabrifat suggestion does not work it appears you overestimated the output capabilities of the motors. You will either have to lighten the load or use bigger motors or possibly a combination of both.
Set Vref to a certain voltage before any motor is connected.
Setting it to draw a certain current might not work as you think it does. Pololu has a good tutorial. Check if your driver has the same value sense resistors.
Leo..
Try what...
Setting Vref on the drivers should be the first thing you do, before connecting the motors. 0.5volt, assuming the sense resistors on the drivers are 0.1 Ohm.
We asked about your motor power supply (voltage and current), which you didn't answer yet. And which stepper library are you using, regarding accelleration.
Leo..
