Controlling Coreless motor using mosfet
Hello, Im new to using the forum so I apologize for any mistakes. Im trying to control a 3.7v 10mA coreless motor using arduino, I`m using a 2n7000 mosfet, 2 18650 batteries ( adding to 8 volts).
I read that the coreless motor pwm frequency is more than 20KHz so I edited the code as such.
The setup is simple :
the gate is to pin 9
the source is to ground
the drain is to terminal of the motor
the other terminal is attached to the positive of the 8 volts
Here is the problem, at pwm 255 , the motor is reading 1.43 volts, and the mosfet heats up a bit.
I don`t understad what is wrong. TIA
#define motor 9
  pinMode(motor, OUTPUT);
  // 32 KHz
  TCCR1A = (1 << COM1A1) | (1 << WGM11);
  TCCR1B = (1 << WGM12) | (1 << WGM13) | (1 << CS10);
  OCR1A = 500;
  analogWrite(motor, 255);
10mA?
Must be the size of half a grain of rice then...
Common coreless motors used for small drones can draw up to 8Amp@4volt.
Leo..
What a coincidence!!
Even I am trying to make a drone with Coreless motors or micromotors.
  • Model: 716 coreless motor.
  • Shaft Diameter: 0.8mm.
  • Rod Length: 8.2 mm.
  • Motor Diameter: 7 mm.
  • Motor Length: 16.5mm.
  • Wire Connection (10cm): Red (Positive Pole), Blue (Negative Pole)
  • Voltage Range: 1V to 3.7V.
  • Current: 0.01 A.
  • Speed: 50000 RPM. (at 3.7V)
I am really stuck here, when I connect a dc geared motor (the yellow one) it works properly so I don`t get the problem.
My coreless motors work on 3.7v. I think the mosfet is trying to reduce voltage by turning it into heat.
which mosfet are you using?
You must have a different definition of small.
Using conservative calculations
A 250 mAH cell can
run 4 14x7 brushless cordless motors
for a 5 minutes flight
which woukd be ~4 amperes continuous current
or about 1 ampere per motor.
I would say 8 Amps at some point isn't impossible, 2 amps per motor.
I'm more curious about
Since motors don't have a "pwm frequency" other than someone's recommendation. I want to read that for myself to see who said and what else.
a7
Why are you running a 3.7V motor on 7.4V?
Could that be the problem?
She said N type but she didn't say the no.
Example- Irz44n
Tell it not to.
That is to say, that's not how MOSFETs in a circuit like this work. They do no thinking or trying, they are supposed to turn on and off.
Draw a proper schematic and say what part that is. Are you sure it is a MOSFET, and that you are meeting its gate voltage for getting a low resistance on state?
a7
Coreless motors should be used with High Frequency Multifunction Decoders . Some manufacturers recommend a PWM frequency greater than 20kHz. This increases the motor's impedance when driven by a multifunction decoder's motor drive circuits. Not all manufacturers will publish the PWM frequency in their literature.
Coreless Motor - DCCWiki.
I am using Irfz44n
I said 2n7000 in the post
Im using an arduino uno and a servo besides the motor so I have to power them up. For clarification, Im not using the srvo right now I`m just testing the brushless motor
OK, no need to be rude
I am really sorry, this wasn`t my intention. I only just meant to clarify. Sorry again.
If you are in India then you can buy from this link
https://www.amazon.in/Electron-Coreless-Magnetic-Robotic-Helicopter/dp/B0CRWRFH3K?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A3C7Z4RVM9A3G1
It's okay
Fine but what voltage are you applying to the motor 3.7V or 7.4V?
