Hello all,
I've been working on a project with a Controllino Maxi board, and part of it consists of using a servo motor (MG995).
My servo is connected to a 5V supply and the board to a 24V supply. The grounds have been connected to each other as well.
The board and other components are running fine. but I've been burning through servos like mad. I tried the "sweep" example for the servo on a Keyestudio Uno board and it worked fine, and I measured 0.1~0.5[v] from the PWM output pin.
However, using the same code tweaked for Controllino, the Controllino output pin shows me nearly 12 volts. The servo is rated for up to approx. 7 volts, so I imagine this is what's frying up my servos.
I'm positive this isn't a code issue, because the 12 volts also have a range of approx. 0.5[v], which makes sense for the sweep example, and is the same range as the output measured for the UNO board. Plus - the LED on the Controllino board signals that there is a varying output.
Any suggestions on what I could do to run my servo smoothly?
