Hello Community!!
I'm looking forward to doing a simulation on proteus 8 of my signal that is related to my heartbeat sensor.
I'm expecting to display on the oscilloscope the same shape of the signal that is displayed on the serial plotter.
What else can I provide to get some help ?
I'm a newbie, so please just be patient!!
Here is the code that I'm working with :
/* PulseSensor Starter Project and Signal Tester
The Best Way to Get Started With, or See the Raw Signal of, your PulseSensor.com™ & Arduino.
Here is a link to the tutorial
https://pulsesensor.com/pages/code-and-guide
WATCH ME (Tutorial Video):
https://www.youtube.com/watch?v=RbB8NSRa5X4
1) This shows a live human Heartbeat Pulse.
2) Live visualization in Arduino's Cool "Serial Plotter".
3) Blink an LED on each Heartbeat.
4) This is the direct Pulse Sensor's Signal.
5) A great first-step in troubleshooting your circuit and connections.
6) "Human-readable" code that is newbie friendly."
// Variables
int PulseSensorPurplePin = 0; // Pulse Sensor PURPLE WIRE connected to ANALOG PIN 0
int LED10 = 10; // The on-board Arduion LED
int Signal; // holds the incoming raw data. Signal value can range from 0-1024
int Threshold = 550; // Determine which Signal to "count as a beat", and which to ingore.
// The SetUp Function:
pinMode(LED10, OUTPUT); // pin that will blink to your heartbeat!
Serial.begin(9600); // Set's up Serial Communication at certain speed.
// The Main Loop Function
Signal = analogRead(PulseSensorPurplePin); // Read the PulseSensor's value.
// Assign this value to the "Signal" variable.
Serial.println(Signal); // Send the Signal value to Serial Plotter.
if (Signal > Threshold) { // If the signal is above "550", then "turn-on" Arduino's on-Board LED.
digitalWrite(LED10, HIGH);
digitalWrite(LED10, LOW); // Else, the sigal must be below "550", so "turn-off" this LED.
delay(10);
