Hello,
While playing with exceptions recently (on my ESP32-S3) I wrote a small example sketch which shows how to intercept CPU exceptions (that “Guru Meditation“ thing) and skip them :). This is just an example. For me, personally, division by zero was interesting part, so the example is about division by zero. However it should work with any other exception.
Everything is in comments. No assembler or ESP-IDF API calls are involved.
// This is an example for ESP32, ESP32-S2 and ESP32-S3 boards: detect and catch CPU exceptions,
// skip failed CPU instruction and continue execution as if nothing happened
#include <Arduino.h> // gotta include this, otherwise it's off-topic!
static const uint8_t xt_insn_len[] = { XCHAL_BYTE0_FORMAT_LENGTHS };
// Exception number we wanna catch.
// There are 64 exceptions in total, but we're just gonna mess with divide-by-zero here.
// You can change this number to any other exception number (Access to NULL pointer,
// IllegalInstruction, UnalignedMemoryAccess, calling a function by wrong pointer etc)
#define EXCEPTION_NUMBER 6
// This struct gets passed to our exception handler.
// You can poke at it to change the processor state.
struct exc_frame {
uint32_t unknown0; // Have no idea
uint32_t pc; // Pointer to the current instruction (Program Counter)
uint32_t known[20]; // Bunch of registers a0–a15 plus some special ones
// Table of exception handler pointers - one per core, 64 entries each.
// Set up when the system boots.
// Handlers get called by the core whenever something nasty happens.
// Most exceptions hit the same function, which eventually calls panic(),
// shows "Guru Meditation", dumps registers, and your program freezes.
// Some exceptions are handled quietly - like unaligned memory access (DRAM only).
// The core fixes the access and keeps going.
typedef void (*funcptr_t)(struct exc_frame *);
extern funcptr_t _xt_exception_table[];
// Our custom exception handler: just skip the offending instruction.
// Instruction length is determined from the first byte.
// Xtensa instructions can be weird (3 bytes, anyone?), so PC might be unaligned.
// To grab that first byte from the IBUS , we do a little trick:
// read the aligned 32-bit word and then extract the byte we need.
// The function gets a pointer to the Exception stack frame - all the registers at the
// time of exception and the instruction pointer (pc) that caused it.
// We just tweak PC to point to the next instruction and return.
// Division result? Who knows. But the program keeps running.
// Don't try calling delay() or anything scheduler-related here.
// Printing is okay, but do it carefully via extern ets_printf(const char *, ...)
static void exception_handler(struct exc_frame *f) {
uintptr_t pc = (uintptr_t)f->pc;
// Align the address to 4 bytes
uint32_t aligned = pc & ~3;
// Read 32 bits from the aligned address
uint32_t word = *(volatile uint32_t*)aligned;
// Shift to get the byte we actually want
uint32_t shift = (pc & 3) * 8;
// Grab that first byte of the instruction
uint8_t opcode = (word >> shift) & 255;
// Move PC to the next instruction
f->pc += xt_insn_len[opcode];
// Divider. We will set it to zero a bit later
volatile int j = 1;
// Hook up our exception handler in the table.
// Do it for both cores if we have more than 1 core.
// Comment these lines out and the sketch will hang, like it normally would.
_xt_exception_table[EXCEPTION_NUMBER * portNUM_PROCESSORS + 0] = exception_handler;
#if portNUM_PROCESSORS > 1
_xt_exception_table[EXCEPTION_NUMBER * portNUM_PROCESSORS + 1] = exception_handler;
#endif
// Set the bomb
j = 0;
// Moment of truth. Inside the loop.
// Will it crash or not? Let's find out.
for (int i = 0x61; i < 0x6e; i++)
Serial.printf("%% %x\r\n", i / j);
