I want to create a really simple school project where I connect an arduino nano to the qwiic haptic motor and make it vibrate every so often. I would like to power it with a single CR2032 button battery since its needs to be compact. Is it okay to simply connect the battery to the 3v3 pin? I don't need the circuit to be on for long, its purely for a 'feels like' prototype and would be happy to regularly switch out batteries for the amount of time I would be using it.
Oops! Your link does not go to the technical information about your haptic motor. Without the current and voltage requirements, you question cannot be answered.
If you mean connecting the CR2032 to the 3.3V pin of the Nano, with the intention of powering the Nano from that, then definitely NO. That is a fairly low current voltage output, not an input.
You would be better off using a Pro Mini running at 8MHz, that can be run without a voltage regulator, and the clock frequency is within specs at the voltage you want to use.
The motor voltage/current are not relevant to your system. They are ALL generated and controlled by the driver. What I do not see is any reference to the maximum current drawn by that driver. So, I guess it try it and see.
ah I see! So from my understanding, the 3v3 pin is used to pass 3v3 to the driver/motor and cannot be used in reverse to power the actual microcontroller? To power that, I can only use the Vin pin, not the 5v or the 3v3? Thanks for the recommendation, i'll look into that board!
You can run the Nano with 3V to the 5V input but you should, technically, run the processor at 8 MHz instead of 16 MHz. With an ISP device, you can set the processor fuses to use the internal 8 MHz RC oscillator instead of the 16 MHz crystal/resonator.
I recommend the "USBasp" device. They are quite inexpensive. make sure you have a 10-pin to 6-pin cable adapter for it.
In ancient times the AVR processor evaluation boards used a 10-pin connector for programming. Five of those pins were Ground. The Arduino eliminated four of the Ground pins and uses a smaller 6-pin connector.
