I know this batteries are for long time using for example clocks or even PC's motherboard have one similar and they no lose they'er voltage; I also reed somewhere, I don't remember where, that the lithium cells are rechargeable for long durability.
Well it may look that I already know all about it but the true is that I'm not sure at all about it, I have some cells of this kind and they have 0 volts.
It may bee? or it is actually? or what?
Hope you all can answer me with out send me to search in Google. =(
thank you all. XD
yes the rechargeable ones are the lithium ion and they’r LIR XXXX where XXXX is the number of the model, you know like LIR2032
well this is useful because I have a mini project with RGB led lights and they many need to fit in a little space (I’ll use an attyny13) , a little porcelain home, and I’ll use a mini solar panel.
by the way my parents has a pair of glasses that has leds and they need 4 CR1632 well.
All batteries are rechargeable to some extent, the question is how well do they recharge.
In the case of a CR2023 the answer will be "terrible" - they simply aren't designed for it. You'd have to recharge very slowly (maybe a week) and it will probably only have a fraction of the charge of a new one.
I have just found a rechargeable CR2032 in the CPC (UK) Catalogue and only 89p+vat, but even so I don't think I need them as the normal cell last for years as an RTC backup, which is what I use it for, I suppose 2 could give you 6V for a very low powered stand-by application. Spec: 65mAh tagged for vertical PCB mounting, battery chemistry not stated.
That's a very expensive changer that is not really needed! unless their Lithium poly or Ion!! I would just tricke change them thro a resistor/diode, but then I'm a bit foolish at times.
fungus:
No, some are not, zinc-air and aluminium-air cells for instance cannot be recharged. Many
that are not intended to be recharged can build up explosive hydrogen gas at high
pressure if re-charging is attempted, and can explode. A rechargable (secondary) cell
is one that can be repeatedly recharged without hazard and without significant loss of
capacity. Although you can for instance recharge alkalines to some extent they don't
fit this definition. Even if the chemistry is reversible, secondary batteries require that
the plates reform in a mechanically sound condition upon recharge, repeatedly, which is
the tricky thing.
fungus:
Obviously I mean the batteries we actually own and use every day, not some exotic ones that nobody’s ever seen.
Zinc air batteries are often used in photo equipment to replace mercury batteries that are no longer available. They also get some play in the hearing aid biz.
MarkT:
I agree. Rechargeable pretty much means re-chargeable on a regular kind of basis over some substantial operating lifetime - regularly being able to recharge back up to somewhere around 'full capacity'.
