kaescrat:
1 - Do you think it is a stupid idea because of something I didn't think about ?
What is it exactly you're trying to build? An electronic swiffer? A robotic dust collector? What?
I do think there are some things you haven't thought about, though...
kaescrat:
2 - Do you think it is easy to build ? Would you advice using one voltage amplifier (or many in series) ?
The fact that you are asking these questions say to me you're no where ready for this level of a project...
kaescrat:
3 - Do you know if this can be dangerous or <1KV is okay ? Because I'm new to arduino and electronics.
First off, you need a ground understanding in electricity, electrical theory, breakdown voltages, what resistance and current means, etc - before you even begin to contemplate a high-voltage system like your wanting. What you are wanting to do can easily cause death, without you even having the chance to realize you did something wrong before you hit the floor. A high voltage project such as you're describing (and it would need to be high voltage to get it to work; I would venture that 1KV may not even be enough - but then again I don't work with high voltage, because I understand the problems and hazards involved, and I want to live a long life - plus I have other projects needing to be done first) is a dangerous thing to work on, even when you do understand what you are doing.
kaescrat:
4 - Does anybody know if 100V would be sufficient to lift dust ?
I doubt it - that isn't to say, though, the 100V is somehow "safe" to play with (what kind of current can the source supply would be a relevant question in regards to safety).
I strongly suggest you find a different project to work on as your "first" project in electronics and the Arduino; keep this one, whatever it is, in the back of your head, and continue to study up on things as you work on simpler projects first. Learn how to be safe around electricity, including high-voltage systems. Develop the habits now for working with high-voltage as you work with lower voltage projects, and you'll be that much safer for if/when you -do- work with high-voltage projects (Do you know what the "one hand rule" is? Do you know how to safely use a meter on an operating circuit for test measurements? These and other safety-related questions are important when working around "high" voltage, including mains voltage sources!).
Once you have the knowledge, you can then decide if you are willing to take the risk, and you will have a much better understanding of what the risks are. Having this knowledge is critical to being safe. From what I understand, the hazards of being shocked rise as you work on such projects; in fact, expect to be shocked! The question, though, will be whether the shock you receive will be something minor (some pain, maybe some minor burns) - or something major (you wind up in the hospital - if you are lucky - or the morgue if you're not). All you can do is have understanding, and take precautions; you can be reasonably safe working with high-voltages - but you must have it ingrained into you to be ever vigilant. As soon as you let your guard down, get lazy, get complacent or be hasty in what you are doing, is the time when you might end up on the floor, wondering how you got there, and why your chest hurts (assuming you survive, of course).
