Create.arduino.cc website is gone?
I saved a lot of create.arduino.cc websites for references of my project, and now it's gone? I have to write proposal on the project, and now all of my coding references are gone, what should I do to access them?
Hi @rahmaneymar11. Please post the link to one of those missing references so we can understand the problem better.
Obstacle Avoiding Robot using Arduino and Ultrasonic Sensor - Arduino Project Hub
Agricultural Pesticide Spraying Robot - Arduino Project Hub
two weeks ago, these websites are still available
Project hub being migrated. FAQ says all migration complete by 01feb23
Thanks. I suspected you were talking about the Arduino Project Hub, but other content might also be found under the general "create.arduino.cc" domain you mentioned before so I wanted to be sure.
As madmark2150 pointed out already. Arduino Project Hub has been reworked and the projects are being migrated from the old one:
All the projects published on the old Arduino Project Hub were also publised on hackster.io. So you should be able to find all the projects by searching on hackster.io. I believe these are the projects you linked:
Too many of those "create" pages were inaccurate, unchecked and copy/pasted (along with the inaccuracies). It was such a bandwidth hog on any search, I stopped referencing it. Maybe they are just cleaning house.
Check out dronebotworkshop, or Anas Kuzechie - they have loads of good information.
There is no indication that a clean-up will be included in the migration. Each of the projects published on Arduino Project Hub already passed a manual review:
Get your project published
For now the content you submit goes through a manual moderation process, so don't worry if you don't see it published right away. Plus, be sure to fulfill all the content guidelines.
Reviewing everything all over again would seem redundant.
I had bookmarked a number of project hub items. Are those links now permanently broken?
Hi @dougp. The team at Arduino who are handling the Arduino Project Hub have been notified about the old URLs not redirecting to the projects.
I am not involved in the migration effort so I can't say if or when the previous links might start working again (beyond leading to the Project Hub home page).
Thank you.
