Hello, I'm in a time crunch at the moment and I'm trying to lower the speed that my 12V DC motors spin at. I have them connected to a battery pack that contains 8 AA batteries. In my code I have the motors set to the lowest speed and they still spin way to fast (I ordered a 120 RPM motors and got sent 1000 RPM). I am trying to figure out a way to slow them down even more with out the use of resistors, as I would not be able to get them in time. My only thought at the moment is to take a few of the batteries out and replace them with a conductive material to bypass them and create a lower voltage circuit but I have no clue if this would even work. Any feedback would be amazing. Thank you.
Forgot to mention that I am using a motor control unit. I don't know if that changes anything.
I don't either, but at least you could try that.
How do You that?
As You use batteries PWM control is the only practical solution.
A model railroad founded 1945 for a long time used 24 volt DC and 25 Ohm power pots to control the train speed. You bet the pots were hot!
You want to run a 12V motor at 1/8 it's rated speed? 1/8 of 12 is 1.5. Put 4 AAs in parallel and see if it runs slow or catches fire.
Which? It is likely that it is amenable to control with PWM as @Railroader recommends.
The trouble with just using a proportionally reduced voltage is that you miss out on the torque the higher voltage provides.
a7
