Hey guys. I'm making a robot using 3-6V DC motors, the ones that come in robotics kits. I need my robot to move at a low speed, so that its sensors can read the colors correctly, but the torque of the motors is low, meaning that the wheels cannot move at a speed lower than 60.
Is there any way to boost this torque, or is the only solution to replace it with stepper motors?
Steppers are the way to go.
Increasing the motor drive voltage will improve performance at low PWM values. 6xAA (9V) is suggested (NOT 9V PP3 block batteries).
Also, if you are using the ancient, very inefficient L293 or L298 motor drivers, replace that with a modern MOSFET motor driver. This one will work much better.
How are you driving the motors? Please post a circuit schematic and whatever code you are using to test the motors.
a7
You can boost the torque, but reduce the lifetime of your motor. You do that by doubling or tripling the voltage and current. Your choice.
maybe you could use a reducer? Although, it can be expensive in the end... or, if you have one, maybe it can be done with a 3D printer but it won't be great...
please do not cross post
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum. It will help you get the best out of the forum in the future.
Thank you.
since you have most replies here, I locked the other thread.
"Performance" will be boosted, but this means speed. As a general rule for a motor, the voltage you apply governs the maximum speed it can reach, the current within it governs the torque it can produce. A higher voltage might let you move the motor at lower PWM values, but it won't let you actually make the minimum speed for its motion slower. The original poster probably wants a motor with a greater gearbox ratio, or to 3d print a gearbox to add on to the motor's shaft for extra reduction. They might achieve something via using a shunt resistor to monitor motor current too, but a higher driving voltage won't help low speed performance.
