Dc motor control with L293d and Arduino Uno
Hey. I wanna Control a DC motor over an Arduino with a L293d. I attached a picture of the Fritzing wiring. My question is first of all. Does this work? Second : Can i run it from a 9v Battery, Can something destroy like the Arduino? (they are connected over ground) I have most of the wiring from Youtube but they used a Powersupply and i dont have one.
@begginerineverything
Your topic was Moved to it's current location / section as it is more suitable.
Could you take a few moments to Learn and Use The Forum
  • Your OS and version can be valuable information, please include it along with extra security you are using.
  • Always list the version of the IDE you are using and the board version if applicable.
  • Use quote or add error messages as an attachment NOT a picture.
  • How to insert an image into your post. ( Thanks @sterretje )
  • Add your sketch where applicable but please use CODE TAGS ( </> )
  • Add a SCHEMATIC were needed even if it is hand drawn
  • Add working links to any specific hardware as needed (NOT links to similar items)
  • Remember that the people trying to help cannot see your problem so give as much information as you can
COMMON ISSUES
  • Ensure you have FULLY inserted the USB cables.
  • Check you have a COMMON GROUND where required. ( Thanks @Perry)
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102 or FT232 VCP Drivers - FTDI
  • There may be a problem with the board check or remove your wiring first.
  • Remove any items connected to pins 0 and 1.
COMPUTER RELATED
  • Close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE’s as ADMINISTRATOR or your OS equivalent
ARDUINO SPECIFIC BOARDS
  • CH340/341 based clones do not report useful information to the “get board info” button.
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (ALL Types) See the specific sections lower in the forum.
  • NANO (NEW Types) Install your board CORE’s.
  • Unless using EXTERNAL PROGRAMMERS please leave the IDE selection at default “AVRISP mkII”.
  • Boards using a MICRO usb connector need a cable that is both DATA and CHARGE. Many are CHARGE ONLY.
CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Ok sorry im new here i thougt ive done it in the Electronics general Topic sorry
It definitely won't work without code. And the code must match the actual components and wiring so having a picture of a joystick that you're not using connected in a way that's not what you intend isn't exactly helpful.
If your 9V battery looks like the one in your picture then it is not suitable for running a motor. Not enough power. And I can't see any power at all to the Arduino.
Steve
Yes i know that i have to code this! But im a lot better in Coding than in electronics. I know how to wire my Joystick that i bought it will be the same on the Arduino only the Joystick pins will change. Which battery would you recommend me? The Arduino will be powered over usb from a Powerbank or Computer
I made a new One with correct button wiring!
On the L293, Vcc1 (pin 16) need a connection to the logic power supply (5V).
The L293 is feeble and wastes many volts - you'd be much better off with a MOSFET H-bridge,
but it should work so long as the power source is decent, a 9V small battery is not going to
cut it, although a NiMH rechargable version would probably just about handle one motor.
Motors need lots of current, you can't skimp on this.
