DC motor only working with battery
Hi everyone,
I'm working on an RC car and I'm using a 7.2V DC brushed motor.
When I try to power it with a 9V 1A power supply, it stutters; it turns on for roughly, stops for 1 second, and the entire process repeats.
What is weird; however, is that when I connect it to a 9V battery, it sparks, but it works! To my knowledge, 9V batteries are not very good power sources for motors, so I don't understand why it works with the battery but not the 9V 1A supply.
Kind regards,
Alex
Post a link to the motor.
Power supplies often shut down for a short period when overloaded.
Keep in mind that motor startup/stall currents are usually 5 to 10 times larger than the running current, so you probably need a power supply capable of several Amperes.
Unfortunately, I don't have a link to the motor as I bought it with an RC car a while back.
What power supply would you suggest then? Would 5 1.5V alkaline batteries in series work?
Kind regards,
Alex
Then post a link to the power supply you say is rated for 1A.
Yes, if fresh.
Those RC car motors draw a lot more than 1A. At full throttle they can draw above 10A. I think you need a much bigger PSU.
@Windoz_killa,
That depends on who's car it is. Some people
wouldn't be caught dead with a car that draws less than 50 or 60A !
True. Most of those are brushless. And boy are they fast.
I still have nightmares from the time we made DIY Arduino based quadcopters for a class project.
4 decently size BDC motor (A2212), spinning propeller blades at hundreds if not 1000+ rpm, flying uncontrollably because we sucked at PID, while tethered to a lab bench power supply running at max settings.
BDC motors are scary af.
An RC helo pilot in Texas severed his carotid artery when his helo drifted into him. He didn't make it. At least he
died doing what he enjoyed.
What does this mean ? Any load when connected to a power source will 'art' (spark) if you touch the wires together
because when the electrons get close enough to overcome the air gap the current increases exponentially which is
why jumper cables spark if you touch them together quickly. Are you referring to some other explanation for the
'sparks' ?
raschemmel:
which is why jumper cables spark if you touch them together quickly.
Not a sensible idea! :roll_eyes:
Well I don't do it myself but I've seem people doing it in the movies when they are getting ready to interrogate someone and they want to scare them into talking. From personal experience I have seen arcing when two dc wires from a sizable supply brush against each other and I have seen it when plugging in something that had the power switch left on so as the plug enters the outlet it sparks while your plugging it in. Refrigerators are notorious for that because they DON'T have an on/off switch, or if they do it's always on. When I built my first power supply I used a regulator IC with foldback current limiting (LM723 ?)and built a 5v, +/- 12V and +/- 15V regulators into a wooden cigar box using machine screws with nuts as terminals and when I tested it I ran a metal can opener back and forth shorting all the output terminals and it sparked like crazy but when I measured it with the meter, all the voltages were good. That was one of my first electronics projects. Smashing success ! (and exciting too!) Just FYI, if you are going to do the thing with the jumper cables you have to swipe sideways quick enough that it has no chance to spot weld together, which it will do if you just bring them close together. They'll stick to each other immediately which why you have to swipe downward with a glancing blow with enough force that it can't happen. (just sayin' ...)
On a more useful note, if you ever have a contactor with spot welded contacts sometimes you can knock
it loose with a small hammer.
Ah, the hammer!
I suspect at 12 V, it is not an arc, but the ejection of an incandescent speck of metal dislodged as you break that spot weld at the point of contact. :grinning:
That is the basis of the "DC 28 V" rating on relay contacts.
I hope you used the correct value of feedback capacitor - 100 to 470 pF - on your 723s and not the fatally flawed value of 0.1 µF that was published in an "Electronics Australia" project back in the 70s and "innocently" copied (rather like the contrast potentiometer mistake with the HD44780) in other articles, which in this case resulted in instant destruction of the current sensing resistor and consequently, no current limiting at all, the effects of which should be quite obvious :astonished:
That was 1979 so I'm a little foggy on the schematic. I can picture the ICs and it was the LM723C TO-100 package.
As I recall, I found them in the electronics store and bought a dozen. (I used to shop for electronic components
like most people shop for produce;("I'll take a half dozen of those, a dozen of those and two dozen of those...") ( [Datasheet ,pg-11,"Foldback Current Limiting"](https://media.digikey.com/pdf/Data Sheets/Texas Instruments PDFs/LM723(C).pdf).) I recognized the negative supply examples on the datasheet. I
used those for the +/- supplies. I built a half dozen of the examples on the datasheet. I can attest to the fold-back current limiting working like magic though. (at the time it felt like magic.) I actually found it difficult to get rid of that cigar box because it reminded me of the joy I felt when I realized it worked perfectly. Eventually I did the math and realized if I was going to stay in electronics and jeep everything I built I would need a Costco sized warehouse to store it all, so I tossed it and upgraded to a Lexan box with L-bracket corners mounted with machine screws through the holes drilled with TAP Plastics and terminal posts to replace the screws. (no smart phones back then
so I don't have a photo of it.
PLASDrills.
Ah yes, the old TO-100 723. :sunglasses:
My variable supply - one of them, I don't recall where the other one is just now - is still sitting and used on occasion on the top of the variable supply stack on my (other) desk here at home.
How do those plastic drills work?
They're called PLASDrills" (plastic drillbits) because they are designed with a very sharp point and sharper cutting
edges than regular drills. They should NOT be used for ANYTHING OTHER THAN PLASTIC because it will dull them.
The sharp point and sharper edges prevents the plastic from binding and cracking. The drilling speed should be
SLOW to MED. Fast is asking for trouble. They work perfectly. Never cracked a plastic sheet drilling holes with these.
windoze_killa:
Alright, but does this also mean that I can't use an L298N motor driver, since the peak Amp output is 2A?
Also, I have found the RC car from whence the motor came. Here it is: Dot buggy radio control car
From what I have read, it says that the motor is RC 380, but not sure what that means...
Kind regards,
Alex
From a web search.
A "380" is nominally what's called a "Speed 400" brushed motor. They can pull anywhere between 8 amps and 20+ amps, based on whether they're direct drive or geared. Direct drive uses more amps and are somewhat less efficient, except in pure speed applications, with very small props and high performance models
Most of the brushed motor DC ESCs are 10A or more. Why don't you just get an RC DC Brushed motor ESC and
use the Servo Library to control it ? The ESCs take the exact same signal as the RC servos which the Servo library
was made for. That's what I would do.
alexoort:
Kind regards,
Alex
Did you think to use the battery pack that came with this RC car? Its a 7.2V 1.1Ah NiMH pack.
That rather suggests a set of 5 AA NiMH cells could be used as a pack, but avoid unbranded
batteries - you need high power quality NiMH cells.
