I have doubts that my INA 226 is defective...
Voltages are readed fine, but current not working at all, even configuration is not set properly;
I try several INA 226 library and they have similar behavior, no matter internal or external resistor.
Limiting the current from low to high (slowly from 0.100 to 1A ) INA reads 0 or max current ("Max possible current")
ina.configure(INA226_AVERAGES_16, INA226_BUS_CONV_TIME_4156US,INA226_MODE_SHUNT_BUS_CONT);
// Calibrate INA226. Rshunt = 1 ohm, Max excepted current = 4A
ina.calibrate(1.0, 4.0);
Configuration Outoput:
Mode: Shunt and Bus, Continuous
Samples average: 16 samples
Bus conversion time: 4.156ms
Shunt conversion time: 4.156ms
Max possible current: 0.08 A
Max current: 0.08 A
Max shunt voltage: 0.08 V
Max power: 2.95 W
Juggling with config to pump up max current to 4A does not make any changes over behavior
Using 0.1ohms (original, module resistor) resistor does not make any change...
Onenote, module is it on HIGH side, don't know is there some different configuration for HIGH side.
Do post more info about your project. Voltages involved, AC or DC, which exact module used, details on the other shunt resistor used, complete sketch used, and anything else that may or may not be relevant.
This is the project I'm flowoing: uSupply, with this scheme.
I have make little changes over resistors to handle 3A and voltage input type is same as current. And shunt is moved after the power transistor
