Designing A Laser Tag System : IR Problems
So a "point and smear the opponent with a beam" scheme would be likely to score most often then?
You are not getting it.
The led is fired for a very short time at high current, the time is measured in microseconds, with a cooldown time between pulses in milliseconds..
Manual operation is not an option as firing at full power for milliseconds will destroy the emitter
Re reading your origional post.
30 m range is a little optimistic, i think you need to consider using 3 emitter diodes for that.
Here is a useful reference
http://www.lasertagparts.com/mtoptics.htm
Well, my backyard is about 25m by 30m, so I figure that's the range.
As for firing times, I was using those variables as examples. Of course, I can set up the laser to fire longer for effect. The IR will only transmit very briefly, like you said, for no more than a few microseconds. I guess the arduino will be constantly checking.
CrossRoads, I don't exactly get what you mean. The laser is just to give the shooter a visual of where they hit in the event they missed. The IR, as stated above, only transmits very briefly, a few microseconds.
I didn't realize you were using both together.
In pre arduino days i built a shooting range of that sort of range using a 555 timer , led , and a toilet roll holder.
The link i gave gives a lot of useful information.
In your case the targets are closer together though, so as said you will need to experiment with the optical arrangements.
Using a 555 at the reciever you could stretch the recieved puls so the arduino does not have to poll so often.
Thanks for the advice, Boardburner2. I haven't looked into using a timer with this yet.
So is this game being played in the dark or during bright, sunny days? The reason I ask is sunlight has a lot of IR in it and can blind your IR detectors.
Yes quite.
Mine used toilet roll holders on the recievers as well to improve sn ratio and range.
However sun is a dc component signal is ac, they are easy to separate provided the reciever does not saturate.
The gamers near me generally play indoors, outdoors in day tends to be paintball.
You mean barrel photon baffles painted black to look like silencers ?
http://www4.uwm.edu/usa/safety/chem/laserman.cfm
raschemmel:
Yes
I cannot claim this to be my idea though.
Its based on captured BOrG technology
