Hello! I'm trying to use an arduino uno to detect if a small desk lamp is turned on or off.
I've already connected a plasma ball to this arduino using an INA219 to detect the current and determine if it's currently being touched (I'm using this plasma ball as a button). Touching the plasma ball triggers a few events (this is already working correctly), now I want to use the lamp as another button, so turning on the lamp would stop these events.
I've tried to find a way to do this online but I haven't found anything useful yet and I'm also a beginner with arduino and electricity/coding in general.
If the idea is to stop receiving events from the plasma lamp when the table lamp is turned on, it sounds like the LDR idea mentioned by @Brazilino might be the safest option.
However, its not clear to me what @lat35 is trying to achieve ?
Basically I just want a way for the arduino to tell if the lamp is on or off, like a boolean. I'm not trying to stop plasma ball data from being collected, the two things can be totally independent from each other, I'm just using the same arduino for both.
The data from the plasma ball and lamp goes into touchdesigner where it is then used to control sound and lights etc
Unfortunately, the arduino (or any other tech except for the lamp and plasma ball) should not be visible in the end. But I'm definitely keeping it in mind, thanks!
Can you post some images of your project?
So we can see your component layout.
Your cut and paste image is very confusing as to the compoents you are using.
Update: I solved the issue using an optocoupler. I just bought a 220V optocoupler isolator module and it was really simple to use and does exactly what I want.
