Hello
Strange problem.
I read this:
avrdude: Version 6.0.1, compiled on Dec 16 2013 at 17:26:24
Copyright (c) 2007-2009 Joerg WunschSystem wide configuration file is "/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf"
User configuration file is "/Users/sylvainweber/.avrduderc"
User configuration file does not exist or is not a regular file, skippingUsing Port : /dev/cu.usbmodem12341
Using Programmer : arduino
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 usavrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f
avrdude: safemode: lfuse reads as 62
avrdude: safemode: hfuse reads as D9
avrdude: safemode: efuse reads as 7avrdude: safemode: lfuse reads as 62
avrdude: safemode: Fuses OK (H:07, E:D9, L:62)avrdude done. Thank you.
After I would like to put Lfuse to OxFF
I did that:
iMac-:~ abc$ avrdude -c arduino -p m328p -P /dev/cu.usbmodem12341 -U lfuse:w:0xff:m
avrdude: reading input file "0xff"
avrdude: writing lfuse (1 bytes):Writing | ################################################## | 100% 0.06s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xff:
avrdude: load data lfuse data from input file 0xff:
avrdude: input file 0xff contains 1 bytes
avrdude: reading on-chip lfuse data:Reading | ################################################## | 100% 0.02s
avrdude: verifying ...
avrdude: 1 bytes of lfuse verifiedavrdude: safemode: Fuses OK (H:07, E:D9, L:FF)
All seems to be ok but:
iMac-:~ abc$ avrdude -c arduino -p m328p -P /dev/cu.usbmodem12341 -b 19200 -v
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
avrdude: Device signature = 0xffffff (retrying)
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.avrdude done. Thank you.
Of course I put an Xtal 16MHz with 2x22pF to GND on pin 9,10
I tried with 3 different AT328 P-PU all got the same result... I also changed Xtal
Why???
