Hello, I am trying to test the dfplayer mini mp3 module, but when connecting the power supply (3.3 or 5V) the led does not light up. Does it mean that the module is not working?
I tested with three modules and all of them had the same problem.
Thank you.
Welcome to the forum
Please post a schematic of your project
The LED on the "DFPlayer" only goes on when a track is being played.
Since it was just a test of the module connections, I made just these connections figuring that the LED would light up indicating the correct power supply.
Really? I imagined that the LED would light up just by plugging in the power supply.
Thanks a lot!
// ESP32dfmini01
//#include "Arduino.h"
#include "HardwareSerial.h"
#include "DFRobotDFPlayerMini.h"
const byte RXD2 = 16; // Connects to module's RX
const byte TXD2 = 17; // Connects to module's TX
HardwareSerial dfSD(1); // Use UART channel 1
DFRobotDFPlayerMini player;
Serial.begin(19200);
dfSD.begin(9600, SERIAL_8N1, RXD2, TXD2); // 16,17
delay(5000);
if (player.begin(dfSD))
Serial.println("OK");
// Set volume to maximum (0 to 30).
player.volume(17); //30 is very loud
Serial.println("Connecting to DFPlayer Mini failed!");
Serial.println("Playing #1");
player.play(1);
Serial.println("play start");
delay(5000);
Serial.println("played");
Serial.println("Playing #2");
player.play(2);
delay(10000);
Serial.println("Playing #3");
player.play(3);
delay(10000);
Serial.println("Playing #4");
player.play(4);
delay(10000);
Serial.println("played\r\n\r\n");
And -- use 5V (not 3V).
Great! Would you know if there is a minimum or optimal impedance for the speaker?
8 ohms
