DFRobot DFPlayer Mini suddenly stops
First, congrats on making significant progress. :slightly_smiling_face:
Can you describe this 'whirring' in more detail please. I interpret the word quite differently from 'twitching', which is mentioned in some of the other suggestions. Whirring to me is constant motor action?
You say that it is working, but I cannot reproduce that. Having changed the hex codes on lines 48 and 64 to suit my own Elegoo remote, the behaviour I get is as follows:
On pressing button 1 the HiTec HS-311 servo arm rotates correctly from its normal angle 90 to 170, and plays track 1. After 10 s it corrrectly moves back to 90. But then pressing the remote's button 2 does nothing. This is not surprising from your code in lines 66 onward. Perhaps you subsequently got it working and forgot to change the sketch you posted? Anyway I recommend you get that working properly as the next step.
Hi Terrypin: Thanks for the reply. I am not sure why the code didn’t work at you rend. Using the code I posted above, it works fine here. Here is a screen shot of the serial monitor:
It works repeatedly and doesn’t fail. Curious; I guess I won’t question the magic, and I’ll take the “win” with the code. :blush:
You asked me to describe this 'whirring' in more detail. I understand your need to know more, but I struggle with how to describe it. As soon as the sketch is uploaded to the Arduino Uno, the servo makes a rhythmic (repeating) sound, that I would best describe as a series of faint clicks. It sounds (to me) like a timer you plug into the wall to turn a lamp on and off; the timer makes a rhythmic clicking sound.
The servo stops making the sound if I disconnect its signal pin from the Arduino.
Having said that, I may have a solution. I was researching the replies from forum members, and tried something that seems to work. I used “Detach” when setting up the servo, and “Attach” just before I needed it to turn. I found I need to add a command of “delay(300);” between the “Attach” command, and the command to move the servo. I assume this is to give the servo time to attach. This is the set of commands I use:
HeadTurnServo.attach(servoHeadPin); //turns servo back on
delay(300);
HeadTurnServo.write(170); //turns the head to the right
HeadTurnServo.detach(); //turns off servo to stop its jittering
Here is the whole sketch, if you want to see it, but is basically what I have been using, with the “Detach” and “Attach” lines added in a few places.
#include <SoftwareSerial.h>  //Allows us to assign different pins for serial use
#include <DFRobotDFPlayerMini.h>
#include <IRremote.h>
#include <Servo.h>
//This sketch is an upgraded sketch that adds the IR Remote triggering the MP3 player
//It tries some ideas form DeBaros video, substituting the IR remote for the PIR
//THIS WORKS - EACH BUTTON PRESS PLAYS TRACK FOR THAT BUTTON AND TEH DETACH STOPSS THE JITTERING
int rxPin = 3;
int txPin = 2;                          //Sets up the send/receive from the Mp3 player
int track = 0001;                       //This is the track number on the micro SD card
SoftwareSerial fxSerial(rxPin, txPin);  //calls the Mp3 player fxSerial
DFRobotDFPlayerMini fxPlayer;
int remoteStatus = 0;  //This sets the trigger to start the talking as zero (no talking, just shoveling).
int remoteState = 0;   //This is the label of the current remote status (on or off)
int IRPin = 11;        //for the ir remote
Servo HeadTurnServo;
int servoHeadPin = 12;  //This is the servo that rotates the head. Does this need to be a squiggly pin? NO it does not
  HeadTurnServo.write(90);  //Zeroes the head to straight ahead.
  pinMode(IRPin, INPUT);  //sets the pin from the IR Remote to input
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);    // Tells Arduino what the Mp3 pins are doing
  fxSerial.begin(9600);      //Sets up the serial function for the Mp3 player
  fxPlayer.begin(fxSerial);  //this tells Arduino that the serial path for the Mp3 player is fxSerial (the name of the MP3 player)
  Serial.begin(9600);        // Do I need this?
  fxPlayer.volume(20);       // Volume can be 10 to 30).  Set this to 20 to use less power
  Serial.println("Enabling IRin");               //for the IR remote
  IrReceiver.begin(IRPin, ENABLE_LED_FEEDBACK);  //for the IR remote
  Serial.println("Enabled IRin");                //for the IR remote
  delay(1000);                                   //Gives things a chance to stabilize
  if (IrReceiver.decode()) {                                      //TRUE if an IR button was pressed, FALSE if not //for the IR remote
    Serial.println(IrReceiver.decodedIRData.decodedRawData, HEX); /*prints the decoded raw IR data to the serial monitor in hexadecimal format. The decodedRawData field holds the raw, unprocessed IR signal. */
    if (IrReceiver.decodedIRData.decodedRawData == 0xBA45FF00) {  //add the next rows to try other buttons
      Serial.println("Button 1 was pressed");
      delay(300);
if (fxPlayer.available()) {
    //printDetail(fxPlayer.readType(), fxPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
      fxPlayer.play(1);                                             // plays message 1 because button 1 was pressed
      delay(10000);
      HeadTurnServo.attach(servoHeadPin); //turns servo back on                                               //gives the head a short pause before turning back.
      delay(300);
      HeadTurnServo.detach(); //turns off servo to stop its jittering                                    //turns the head back to straight ahead
    }                                                               //end of IF statement
      if (IrReceiver.decodedIRData.decodedRawData == 0xB946FF00) {  //add the next rows to try other buttons
        Serial.println("Button 2 was pressed");
        //fxplayer.play(2)// plays message 2 because button 2 was pressed
    //fxPlayer.play(2);// Plays track 2
    //delay(10000); //this plays track  for 10 seconds.  The speech must be less than 10 seconds long -Does this need to be in the loop?
    IrReceiver.resume(); /*prepares the IR receiver to start listening for the next IR signal. It essentially tells the IR receiver to reset its internal state and prepare for a new incoming signal.*/
}  //End  of void loop
My limited understanding of this method is that by using the “Detach” method, the primary problem is that the servo will stop receiving the control signal and will likely lose its position. It won't maintain its last set position unless it's continuously powered and receiving the control signal. I have not found this to be a problem in my project. The servo will only be used every now and then, and it seems to hold it’s position fine when detached. I could see this as more of an issue in a project where the servo is called often and automatically by something like a motion sensor.
I think the root cause for the servo’s issues is that the Arduino Servo and SoftwareSerial libraries can sometimes conflict due to their reliance on timers and interrupts. I understand this conflict can lead to erratic servo behavior. I believe the servo library uses Timer 1 and the SoftwareSerial library uses Timer 2, but they still don’t play well with each other.
One Forum member said: “SoftwareSerial turns off interrupts while each character is sent. Usually this just causes some jitter in the Servos because the pulse length get lengthened when the timer interrupt is delayed”.
I am sorry, but this is getting beyond my knowledge here. All I know at this point is that using the “Detach /Attach” method seems to work, and is not hurting anything , so I think I will go with it.
@hauntp
By "it works" I assumed it does what you want it to do. Which you said included servo action and playing track 2 on pressing button 2. To repeat what I said yesterday, it does neither. And again, how can it possibly do so with the code you posted? There are no servo commands, and the player commands are commented out.
Hi Terrypin:
By "works" I mean when I press button 1, the servo turns, message 1 plays, and the servo turns back. If I press button 2, the serial monitor says “Button 2 was pressed". As you noted, the commands to play track 2 are commented out. That may be added later; there currently is no track 2. My goal was to get all the mechanics of the sketch working, and then I may choose to add more options, or just go with what is live in the sketch. The comments throughout the sketch are not meant to run; they are notes to me for possible additions. The servo does turn and back when button 1 is pressed on the remote, as the sketch shows.
Misleading intro then.
I didn't think it was misleading. The lines that are commented out are obviously not meant to be acted on. None the less, I am sorry if was confusing.
