I recently bought a diecimila off of the adafruit webpage. I actually bought the starter pack as this is my first venture into the world of hardware really. Anyways it came in the mail last saturday and I excitedly tore open the box, installed the drivers and loaded the software (I had previsouly downloaded it in anticipation of the arrival) When I first tried to upload the default blink sketch I was immediately met with the avrdude out of sync message that seems to be rather common place. After a couple attempts though it worked and so I set about playing with leds and code for a few hours. (actual error posted at end of message)
When next I tried to use the arduino I met with the same error again but again after a couple of tries and a driver reinstall all was well again. The only problem is this has been a continued problem over the last 4 days. Sometimes it works sometimes it doesnt. Though I haven't actually sucsessfully uploaded anything since yesterday morning despite approx. 3 hours of continued attempts. I have attempted the solutions that I have read else where on these forums (the reset button before upload incase it has wrong bootloader, changing com port number and various other com settings, getting updated drivers from the getting started tutorials link, and I have even attempted to use an older release of the software driver package(have tried 0010 and 0011)) but to no avail.
The other thing that is peculiar that I havent seen mentioned yet is that my reset button doesnt actually seem to do anything. Sure its there and I push it and it does the little cliky thing all buttons do, but no lights go out or even flicker. Nothing. The pin 13+gnd led doesnt do anything and the surface mount led's (rx, tx and l) all do nothing.
Also when attempting an upload the rx light does a faint and fast little flicker (like its not getting enough power or something). Just the rx not the tx. But when I plug the usb cable in both have a good strong flicker.
The last peculiar occurance is that while 13+gnd do not light up period, 0+gnd does and 1+gnd lights up very weakly. (digital not analog) The last program I was running was a binary number counter running on 0-7 digital so im thinking maybe thats why but none of the others do anything period and 0 and 1 stay on constant.
Im running windows xp with arduino 0011 with the decimilia board with nothing plugged in except the led in 13+gnd occasionally out of hope. And I guess im just asking for any suggestions whatso ever because this is my first foray into this realm and am at a complete and utter loss as to what to do.
Thank you in advance and if you need any additional information i will do my best to supply it.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
//loads of compiling messages
Binary sketch size: 1096 bytes (of a 14336 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
