I have a digispark that I want to reprogram, soldered into a circuit. I have burned the default t85 micronucleus firmware.
This is the command I used:
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude" -C "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf" -v -pattiny85 -cstk500v1 -PCOM4 -b19200 -Uflash:w:D:\Documents\micronucleus-master\firmware\releases\t85_default.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg WunschSystem wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 8192 64 128 30000 30000 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 usavrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e930b (probably t85)
avrdude: safemode: hfuse reads as D7
avrdude: safemode: efuse reads as FF
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "D:\Documents\micronucleus-master\firmware\releases\t85_default.hex"
avrdude: writing flash (8116 bytes):Writing | ################################################## | 100% 0.07s
avrdude: 8116 bytes of flash written
avrdude: verifying flash memory against D:\Documents\micronucleus-master\firmware\releases\t85_default.hex:
avrdude: load data flash data from input file D:\Documents\micronucleus-master\firmware\releases\t85_default.hex:
avrdude: input file D:\Documents\micronucleus-master\firmware\releases\t85_default.hex contains 8116 bytes
avrdude: reading on-chip flash data:Reading | ################################################## | 100% 0.07s
avrdude: verifying ...
avrdude: 8116 bytes of flash verifiedavrdude: safemode: hfuse reads as D7
avrdude: safemode: Fuses OK (E:FF, H:D7, L:F1)avrdude done. Thank you.
I have not set any fuses (I hope the frequency is right.)
The board is recognized by my computer and I can program a sketch into it using Arduino IDE. Despite all this the program I burned into it does not run. It seems it is stuck into the bootloader section.
The sketch:
// initialize digital pin LED_BUILTIN as an output.
pinMode(0, OUTPUT);
}// the loop function runs over and over again forever
digitalWrite(0, HIGH);
Pin PB0 has never a voltage bigger than 1.7V(noise or floating). All pins have similar voltages (except PB3,PB4 which are pulled up or high)
The schematic:
The circuit works. I tested both displays previously with the atiny which I directly programmed with the Uno. The upper right connector is directly plugged into the digispark with the following pins: VIN,GND,5V. The middle connector is also plugged into the digispark.
I have tried:
- Powered by USB: I am afraid this will be detected by the bootloader and enter the programming state thus never running the schematic(shouldn't happen but you never know...)
- Powered by VIN with a 9V battery. Nothing. All voltages are in check (
5V pinhas5von it. All other pins are floating) - Powered by
5V pinusing anArduino UNOas the source. Nothing.
In all cases the voltage on PB0 stays the same. It varies between 0.6V and 1.6V.
In Arduino IDE:
- Tried Digispark 16.5Mhz
- Digispark Pro 16Mhz
- Digispark(No Usb) 16Mhz
Always a succesfull uploading.
Notes:
- After uploading in Arduino this text comes up:
Starting the user app ...
running: 100% complete
So it is supposed to run the program but the board actually resets because it gets renumerated by windows.
- It's not quite possible to de-solder it and program the sketch directly with
ArduinoasISP - I use Windows 10
- Arduino as ISP is configured properly. I burned the same sketch to an t45 with success
- Fuses used when I burned the
micronucleusL:F1H:D7E:FF. These are the default "safe" values. The actual fuses needed by the firmware areL:E1H:DDE:FE. - Difference in extended fuse: Self-programming is curently disabled...Is this the culprit?
- I managed to deconnect PB0, PB1 and PB2 from the rest of the circuit. Now I can't program it with the Arduino as ISP.
Yikes! Invalid device signature.
Question #2:
In the current configuration(soldered) would it be possible to use again Arduino as ISP to program it? PB0,PB1,PB2 are connected to Serial Clock,Serial Data and Serial Storage Clock respectively. I am trying right now to set the right fuses but every time I get this:
avrdude -C "C:\Program Files (x86)\Arduino\hardware\tools\avr\etc\avrdude.conf" -c stk500v1 -p attiny85 -U lfuse:w:0xe1:m -U hfuse:w:0xdd:m -U efuse:w:0xfe:m -B 20 -b19200 -P COM7
Reading | ################################################## | 100% 0.06s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.05s
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.avrdude done. Thank you.
make: *** [fuse] Error 1
