I was planning to display a compass in an OLED. Now, I'm testing on it.
So if I insert a degree in Serial Monitor, I will get the O/P in OLED. i.e., the pointer of the compass will show the angle, which I inserted as I/P. I'm getting it correctly.
But, the issue is, in some angles, the pointer of the compass will be shorter and in some other it will be longer. What would be the reason?
After this I have to interface it with an IMU.
The code is -
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#include <U8glib.h>
#define OLED_WIDTH 128
#define OLED_HEIGHT 64
#define OLED_ADDR 0x3d
#define OLED_RESET 13;
Adafruit_SSD1306 display(OLED_WIDTH, OLED_HEIGHT);
//int arc;
//float rad;
String setAngle;
float angle;
float radian_angle = 0;
float adjacent;
float opposite;
float x1 = 0;
float y1 = 0;
int xcenter = 64;
int ycenter = 32;
//float Lx0 = arc * sin(angle*M_PI / 180.);
//float Lx1 = arc * sin(angle*M_PI / 180.);
//void radar(uint8_t angle)
//float x1 = sin(angle * M_PI / 180); // needle TIP position
//float y1 = cos(angle * M_PI / 180); // a more accurate calculation would be "cos(DEG_TO_RAD*angle)"
//display.drawLine(xcenter, ycenter, xcenter+x1, ycenter-y1, WHITE);
//********************************************//void setup()//********************************
display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR);
Serial.println("Enter the angle");
//*********************************************//void loop()//***********************************
display.clearDisplay();
if (Serial.available()) {
angle = Serial.parseInt();
setAngle = Serial.readStringUntil('\n');
Serial.print("the angle is:");
Serial.println(angle);
radian_angle = angle * 0.0174533;
Serial.print("the radian is:");
Serial.println(radian_angle);
Serial.print("sin:");
Serial.println(sin(radian_angle));
Serial.print("cos:");
Serial.println(cos(radian_angle));
adjacent = (cos(radian_angle) * (angle));
opposite = (sin(radian_angle) * (angle));
Serial.print("adjacent value is:");
Serial.println(adjacent);
Serial.print("opposite value is:");
Serial.println(opposite);
x1 = 64 + opposite;
y1 = 32 - adjacent;
Serial.print("Value of x1:");
Serial.println(x1);
Serial.print("Value of y1:");
Serial.println(y1);
//Lx0 = arc * sin(angle * M_PI / 180.);
//Lx1 = arc * sin(angle * M_PI / 180.);
//display.drawTriangle(63.5, 32, 63, 32, 63.5, 5, WHITE);
//*************************************************Drawing Circle**********************************************
display.drawCircle(64, 32, 30, WHITE);
//*************************************************Angle 'N'*****************************************************
display.setCursor(64, 5);
display.setTextColor(WHITE);
display.setTextSize(1);
display.println("N");
//*************************************************Angle 'S'*****************************************************
display.setCursor(63, 54);
display.println("S");
//**************************************************Angle 'W'***************************************************
display.setCursor(28, 32);
display.println("W");
//**************************************************Angle 'E'*****************************************************
display.setCursor(98, 32);
display.println("E");
display.drawLine(64, 32, 64 + opposite, 32 - adjacent, WHITE);
display.display();
display.setFont();
while (1);
