distance sensor to midi cc
hi… i have to traduce tension or current (from the out of a distance sensor) to a midi signal.
i have to control a program’s parahm as a fader on ableton whit a distance sensor…
anyone can tell me how can i do this???
Try the map function
what is??? i don't know how to use arduino.. i need someone that can drive me step by step...or do it for me.. or someone that can tell me where to buy it...
Up there on the left is a link called 'Main Site.
There you'll find a reference section explaining the 'map' function, and the rest of the Arduino language
ok.. I've read map.. but i don't find anywhere which signal receive the analog imput of arduino...
analogRead
ok thanx a lot!! so.. now.. once i've mapped my signal to a value from 0 to 255 how can i convert it in a sequential 8 bit number(like the midi)??
0..255 is an eight bit number
sure.. but.. i have to send that value to a midi instrument... like an ableton fader...
Did you look at any of the MIDI references over at the Playground?
http://arduino.cc/playground/Main/InterfacingWithHardware#Communication
i don't speech a good english so.. i didn't find anything about it...
do you know if this code help me??
// by Tubedogg 12/2006; fabian at tubedogg.de
//This program reads up to 6 analog sensors / potentiometers ans converts the data to Midi-Controller messages
// define Switchpin:
#define switchPin 10
//  define LED:
#define LEDpin 13
// Variables
// define variables for the controller data
int AnalogValue[6] = {0,0,0,0,0,0};
// define the "lastValue" variables
int lastAnalogValue[6] = {0,0,0,0,0,0};
// select the midi Controller Number for each input
int midiCCselect[6] = {1,2,3,4,5,6};
// select threshold for each analog input
int thresh[6] = {1,1,1,1,1,1};
// select number of desired analog inputs (max 6)
int input_no = 6;
 //  set the states of the I/O pins:
 pinMode(switchPin, INPUT);
 pinMode(LEDpin, OUTPUT);
 //  Set MIDI baud rate:
 Serial.begin(31250);
// main program loop
for(int i=0;i<input_no;i++){
         AnalogValue[i] = (analogRead(i))/8;    // read the value from the analog input and divide by 8 for range 0-127
     // check if value is greater than defined threshold (good for resistive touchpads etc)
     if ( AnalogValue [i]>thresh[i] ) {
           // check if analog input has changed
           if ( AnalogValue[i] != lastAnalogValue[i] ) {
           //send control change on cc#i
           midiCC(0xB0, midiCCselect[i], AnalogValue[i]);
           // update lastAnalogValue variable
           lastAnalogValue[i] = AnalogValue[i];
           //End if
       //End if
//End for
//End Loop
// This function sends a Midi CC.
void midiCC(char CC_data, char c_num, char c_val){
 Serial.print(CC_data, BYTE);
 Serial.print(c_num, BYTE);
 Serial.print(c_val, BYTE);
Moderator edit: Reposted, sans italics.
Only you can answer that question.
suddendie:
it's well commented, seems like crystal clear code
