Hi, there is an other tread by a different person with a similar problem.
I have the same stepper and driver board and I had trouble with the sketch you are using.
Try this code, I can't remember where I got it, I have moded it so that the value of val is set in the code and not by a potentiometer as it was originally intended.
Stepper Motor Control - speed control
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 2 - 5 of the Arduino.
A potentiometer is connected to analog input 0.
The motor will rotate in a clockwise direction. The higher the potentiometer value,
the faster the motor speed. Because setSpeed() sets the delay between steps.
int IP1;
int IP2;
int IP3;
int IP4;
int val;
int ddelay;
int dddelay;
// nothing to do inside the setup
IP1=2;
IP2=3;
IP3=4;
IP4=5;
pinMode(IP1,OUTPUT);
pinMode(IP2,OUTPUT);
pinMode(IP3,OUTPUT);
pinMode(IP4,OUTPUT);
// val = analogRead(0);
val=1000; // Sets speed 0 to 1000
ddelay = map(val, 0, 1006, 500, 3);
dddelay =constrain(ddelay,3,500);
Serial.print(dddelay);
Serial.print(" ");
Serial.println(val);
digitalWrite(IP1, HIGH);
digitalWrite(IP2, HIGH);
digitalWrite(IP3, LOW);
digitalWrite(IP4, LOW);
delay(dddelay);
Serial.print(" ");
digitalWrite(IP1, LOW);
delay(dddelay);
Serial.print(" ");
digitalWrite(IP3, HIGH);
delay(dddelay);
Serial.print(" ");
digitalWrite(IP2, LOW);
delay(dddelay);
dddelay=constrain(dddelay,3,500);
Serial.print(ddelay);
Serial.print(" ");
digitalWrite(IP4, HIGH);
delay(dddelay);
dddelay=constrain(ddelay,3,500);
Serial.print(" ");
delay(dddelay);
Serial.print(" ");
delay(dddelay);
Serial.print(" ");
delay(dddelay);
Note that I use pins 2 to 5, but you can change the code to use 8 to 11.
Tom.....
PS note that this stepper has a gearbox in it so it will not turn very fast.
