Duplicate rows on 32 x 64 LED Matrix display
I'm trying to make a countdown timer using a 32 x 64 LED Matrix and an Arduino Mega. I'm not sure why every time I send a string to the display, it duplicates it on the next row. I'd appreciate some help.
I followed this wiring diagram.
Arduino Issue
Here is my code
// testshapes demo for RGBmatrixPanel library.
// Demonstrates the drawing abilities of the RGBmatrixPanel library.
// For 32x64 RGB LED matrix.
// https://www.instructables.com/64x32-RGB-LED-Matrix-With-Arduino-Mega/
// https://learn.adafruit.com/32x16-32x32-rgb-led-matrix/library
// https://tutorial45.com/building-an-arduino-countdown-timer/
// WILL NOT FIT on ARDUINO UNO -- requires a Mega, M0 or M4 board
#include <RGBmatrixPanel.h>
// Most of the signal pins are configurable, but the CLK pin has some
// special constraints.  On 8-bit AVR boards it must be on PORTB...
// Pin 11 works on the Arduino Mega.  On 32-bit SAMD boards it must be
// on the same PORT as the RGB data pins (D2-D7)...
// Pin 8 works on the Adafruit Metro M0 or Arduino Zero,
// Pin A4 works on the Adafruit Metro M4 (if using the Adafruit RGB
// Matrix Shield, cut trace between CLK pads and run a wire to A4).
//#define CLK  8   // USE THIS ON ADAFRUIT METRO M0, etc.
//#define CLK A4 // USE THIS ON METRO M4 (not M0)
#define CLK 11 // USE THIS ON ARDUINO MEGA
#define OE   9
#define LAT 10
#define A   A0
#define B   A1
#define C   A2
#define D   A3
int S = 59; // count seconds
int M = 59; // count minutes
int H = 47; // count hours
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false,64); //add D after C,....and 64 after false,
  matrix.begin(); //this line is needed for anything to show up\
  matrix.setCursor(9,0);
  matrix.setTextColor(matrix.Color333(7,7,0));
  matrix.print("GO");
  matrix.setTextColor(matrix.Color333(7,7,7));
  matrix.print("CREATE");
  //------------------------------CHANGE TIME---------------------------------
    S--;
    matrix.fillScreen(0); //to refresh
    matrix.setTextColor(matrix.Color333(0,0,0));
    //DISPLAY MAKE 48 LOGO
    matrix.setCursor(11,0);
    matrix.setTextColor(matrix.Color333(4,7,0));
    matrix.print("MAKE");
    matrix.setTextColor(matrix.Color333(7,4,0));
    matrix.print(" 48");
    if (S<0) //if seconds are up,
      M--; // reduce minute by one
      S=59; // reset second section to 59
    if (M<0) //if minutes are up,
      H--; //reduce hour by one
      M=59; //reset minute to 59
    if (H<0){ //if hours are up, reset everything
      H=23;
      M=59;
      S=59;
    //----------------------------DISPLAY TIME-----------------------------
    matrix.setCursor(8,16);
    if (H>=32){ // Set color for time
    } else if (H <32 && H>=16){
    } else{
       matrix.setTextColor(matrix.Color333(7,0,0));
    if (H < 10){
      matrix.print(" "); //Extra space is to ensure colons are in the same spot when theres only 1 digit
      matrix.print(H);
      matrix.print(H);
    matrix.print(":");
    if (M < 10){
      matrix.print(M);
      matrix.print(M);
    matrix.print(":");
    if (S < 10){
      matrix.print(S);
      matrix.print(S);
Blockquote
@julianchee, your topic was moved to a more suitable location on the forum.
Please read How to get the best out of this forum. Pay special attention to how to post code. Next post your code.
Perhaps it has something to do with your secret code? :face_with_raised_eyebrow:
Now that's more like it, you added the code to your first post. :face_with_raised_eyebrow:
Hmm... maybe you are running code for a 1/16 matrix on a 1/8 matrix?
Hi, I'd appreciate some help as to where I can find some example code of such a conversion.
Can you please post a picture of the reverse side of the display?
Can you please post a link to where you purchased the display?
The examples in the library were made for smaller LED matrix modules. To run it on the 64x32 >module we need to modify the code.
Did you modify the code as in the "Destructible" article?
Thanks.. Tom...
