Converting half a garage into a woodworking area, i have a single dust extractor (4 inch hose type), and a few machines that chuck out a lot of sawdust,
the dust extractor does not have a power take off socket on it.
The woodworking half of the garage will have a single ring main feeding all tools (yes i'm in the uk)
I'd then put a couple of single sockets on a radial circuit on it's own breaker around the walls for the dust extractor to plug into,
i'd have a current sensor around one of the live wires feeding the ring main inside the breaker box (or should i have it around both live wires?)
so that whenever the current on ring main goes above say 450 watts (largest tool draws 3kw, but obviously has a large start up surge) a contactor switches the dust extractor sockets on...
BUT it does so 1/2 to 1 second or so after the tool that triggered the relay turns on, just so there's not a large current surge of 2 motors starting together.
Then when the tool turns off, current goes below say 450 watts, the relay stays on for 2 seconds, then drops out, to clear the pipe of dust as the tool spins down)
i know you can buy automated dust extractor boxes (for about £100!!!), but i really want to build this into the fixed circuits, i'd have a small box for the arduino to live in, with a suitable psu running it, and a couple of wires from that box going into the breaker box for the current transformer and contactor, i'm imagining it'd cost 20 quid to build this.
Are there current sensors that interface with an arduino easily? i imagine i don't want to be feeding in an AC signal to an analog pin, but i could be wrong.
As always with me, doing the physical wiring and that is easy, the software will stump me, so once i have the hardware, how do i go about the software that will monitor the voltage from the current transformer, and output when needed ?
