I am using DGUS software to design UI for my DWIN touch LCD (480x272, capacitive, 4.3 inch). I have tried uploading basic UI with nothing more than two images with ICL generated, but it is neither uploading through SD card nor the cable connection. Why is this? Has anyone faced this issue with this LCD before?
It is probably that thing you forgot to connect. More details and links to the hardware would get you a better answer and an annotated schematic // o //.
Actually it turned out that some specifications I was putting in for the UI were wrong.
Sooooo what were they?
So there is something called an ICL file which is generated for the UI. I had been naming it 32, but it needed to be named 23. It has some relation to my LCD being an 8 bit system. So why 23 and not 32? I don't know, don't really understand it. But apparently it works, so I am not too worried about "Why" right now.
Thanks,that may help another user.
